Leaking coolant - Mustang Evolution
Old 12-06-2015, 08:30 PM   #1
alecas447's Avatar
Leaking coolant
Hi guys just came to my car and saw a river of fluid on the drive way. And out of curiosity I checked my coolant fluid level and it was all gone i fill it back up with back up coolant I had I moved the car forward and backward an boom all gone
Update: Seems to be leaking from a bracket. Is this even possible?
Name:	ImageUploadedByMustang Evolution1449459047.695135.jpg
alecas447 is offline   Reply With Quote
Old 12-06-2015, 08:31 PM   #2
alecas447's Avatar
Seems to be leaking from that black hole at the bottom of the pic. Any idea what this is/ could be??? I'm stranded
Old 12-06-2015, 08:33 PM   #3
alecas447's Avatar
Better shotClick image for larger version
Name:	ImageUploadedByMustang Evolution1449459225.838658.jpg
Old 12-06-2015, 09:41 PM   #4
alecas447's Avatar
That's from the front left of the car at the bottom
Old 12-06-2015, 11:46 PM   #5
The lower radiator hose maybe. Or perhaps the radiator.
straybullitt is online now   Reply With Quote
Old 12-06-2015, 11:49 PM   #6
alecas447's Avatar
The hoses are fine. It's literally leaking from the bracket which I don't see how it's possible
Old 12-06-2015, 11:53 PM   #7
It's not possible.
How about the the hose connecting the coolant reservoir to the radiator? Or the coolant reservoir itself?
Old 12-06-2015, 11:59 PM   #8
alecas447's Avatar
It's leaking from the bottom.my dad has some blue devil I'm going to try that tomorrow
ATTACH]194482[/ATTACH]
Name:	ImageUploadedByMustang Evolution1449471547.370375.jpg
Old 12-07-2015, 12:04 AM   #9
keeney35's Avatar
Pull the radiator put a water hose to it and watch where it leaks from lol or leave it on and leave he hoses connected, unbolt it and lift it where you can see the bottom then put water thru it
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 12-07-2015, 05:31 AM   #10
Get a flashlight and telescoping inspection mirror to track exactly where that leak is coming from. You might think it's coming from that bracket but in all honesty, it could be leaking from somewhere higher up and just falling/dripping on that part giving it the appearance it is the culprit.
Sent from my SM-N910P using Mustang Evolution mobile app
Old 12-07-2015, 08:17 AM   #11
alecas447's Avatar
It was dark I'm going to be checking agaim
Old 12-07-2015, 12:47 PM   #12
alecas447's Avatar
It leaks when the car is off as well while it's not even running
Old 12-07-2015, 01:15 PM   #13
alecas447's Avatar
Originally Posted by straybullitt View Post
It's not possible.
Neither. I think it might be the radiator
Old 12-07-2015, 07:10 PM   #14
alecas447's Avatar
Name:	ImageUploadedByMustang Evolution1449540614.400055.jpg
ID:	194524Click image for larger version
Name:	ImageUploadedByMustang Evolution1449540630.769672.jpg
ID:	194525Click image for larger version
Name:	ImageUploadedByMustang Evolution1449540641.814963.jpg
Old 12-07-2015, 07:30 PM   #15
Slater2111's Avatar
It looks like it's leaking from the tank where the aluminum crimps to the plastic.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 12-07-2015, 07:32 PM   #16
alecas447's Avatar
I already bought the radiator but it was all over in the top part to so I just went ahead and bought it
Old 12-08-2015, 05:18 AM   #17
Slater2111's Avatar
Did you upgrade while you were at it.
Old 12-08-2015, 10:20 AM   #18
Once these aluminum/plastic radiators start leaking, they cannot be repaired like the copper radiators of years gone by... They must be replaced.
Old 12-08-2015, 06:39 PM   #19
alecas447's Avatar
Sadly no I had no time to waste so I just went with the autozone radiator not really sure what kind it is.
Old 12-08-2015, 06:40 PM   #20
alecas447's Avatar
I replaced today. Now I'm getting white smoke during out of the exhaust ??? What can this be??
Old 12-08-2015, 06:49 PM   #21
Is there white smoke even after the engine is completely up to operating temperature and after you have driven around for a while?
Old 12-08-2015, 07:27 PM   #22
Slater2111's Avatar
Sounds like burning off coolant to me.
Old 12-08-2015, 09:42 PM   #23
alecas447's Avatar
It only did for a few minutes after I turned it on. I hadn't turned it on for a few days so could it be that?
Old 12-08-2015, 09:51 PM   #24
Yes. It was probably just the normal condensation that collects in the exhaust system.
Make sure that you"burp" the air out of the cooling system by squeezing up and down the upper radiator hose. Then top off the reservoir to the full line and keep an eye on it for a few days.
Old 12-09-2015, 12:43 PM   #25
alecas447's Avatar
Thanks man
Leaking coolant when parked rollo1987 1996-2004 Mustang GT 5 08-25-2014 06:27 PM
Leaking coolant denises08 2005-2010 V6 Mustang 3 07-26-2013 06:24 PM
Leaking Coolant 88gtCc 1979-1995 Mustang GT 14 05-14-2012 03:47 PM
lower intake manifold leaking coolant shustwit Pre-2005 V6 Mustang 4 06-17-2011 11:28 AM
Coolant leaking 08v6 1979-1995 Mustang GT 2 06-05-2011 03:42 PM
12:22 AM
