Loose/flimsy gas pedal - Mustang Evolution
Old 12-11-2015, 08:43 AM   #1
LeoGMR4558's Avatar
Any tips or trick on fixing this? I fixed it once by putting a lot of tape around the cable where the pedal was but eventually the tape gave out. I felt more power when I would floor and better response. Much appreciate any help or pointers!
LeoGMR4558 is offline   Reply With Quote
Old 12-11-2015, 09:00 AM   #2
What exactly is the problem? You have too much slack in the cable or something is loose where it bolts to the floor?
For the slack problem a common fix is to just get a nylon spacer and install it on the cable.
Old 12-11-2015, 09:15 AM   #3
LeoGMR4558's Avatar
Yeah it has too much slack
Old 12-11-2015, 09:30 AM   #4
JudenInduven's Avatar
I think replacing the whole throttle cable helps, since it'd be a new cable with little/no slack. Or, some put spacers up in the gas pedal, but I don't know anything about that
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
JudenInduven is offline   Reply With Quote
Old 12-11-2015, 09:54 AM   #5
LeoGMR4558's Avatar
But how does the slack happen?
Old 12-11-2015, 09:57 AM   #6
General wear on the system/cable, I believe. The throttle cable eventually stretches out. In my case, it's not really stretched out, since I can still do WOT, but the pedal is really loose, and I have to replace the whole cable to adjust it, because of how bad the bolts and whatnot on the old one are
Old 12-11-2015, 12:37 PM   #7
Replace the cable. Temp fix is a nylon spacer you can get from any hardware store.
Old 12-13-2015, 04:16 PM   #8
fenixignition's Avatar
i used a rubber hose and sliced it down the center, pushed the cable into it to use it as a spacer, then zip tied it to keep it secure. im sure one of these days it will fall apart, but its held since 2013 so far.
2002 GT 5sp. 16x,xxx miles
Old 12-14-2015, 11:02 AM   #9
^That'll work too. There are a few of these cars I've gotten into and go to push the gas pedal and I have to fight the carpet too, like... wth. What is the point of even having one of these cars with a messed up gas pedal.
Loose steering and soft brake pedal on my 2013 v6 racemamxx 2011-2014 V6 Mustang 3 08-09-2015 12:55 PM
Shaking clutch pedal until pedal is pushed GHO5T5NIPER 1996-2004 Mustang GT 78 05-03-2015 11:47 PM
Gas pedal loose robin_gt 1996-2004 Mustang GT 3 04-08-2015 01:22 PM
Gas pedal fix OR_Red98 Pre-2005 V6 Mustang 2 08-18-2003 06:59 PM
10:23 PM
