Tein lowering springs?? - Mustang Evolution
Old 12-11-2015, 11:16 PM   #1
superdrift's Avatar
Says on stangmods that it will drop the car 2.5in. So questions are what else needs to be done to run em and are they a decent part? SKG94-AUB00 Tein S. Tech Lowering Springs 99-04 Mustang
superdrift is offline   Reply With Quote
Old 12-12-2015, 06:45 AM   #2
Project Pony's Avatar
At a 2.5 drop you will definitely need CC plates and an alignment. I'd also make sure your struts and shocks are good, and replace any suspension bushings that are worn. Don't forget ball joints if they are worn as well. Throw in a bump steer kit to finish it off.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 12-12-2015, 08:07 AM   #3
keeney35's Avatar
I've used tein before on my eclipse, very very nice springs, good quality
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 12-12-2015, 10:25 AM   #4
superdrift's Avatar
So basically i should go for another spring setup untill i have the money for a full suspension?
Old 12-12-2015, 12:51 PM   #5
Shocks/struts
CC Plates
Bumpsteer kit
Ball Joints
I personally wouldn't go that low without coil overs.
Old 12-12-2015, 01:03 PM   #6
superdrift's Avatar
Shocks/struts
CC Plates
Bumpsteer kit
Ball Joints
Would you recomend h&r springs then with camber bolts?
Old 12-12-2015, 01:25 PM   #7
Personally i'm a huge advocate against camber bolts. Even if the car is never driven hard i wouldn't use bolts.
Old 12-12-2015, 04:03 PM   #8
superdrift's Avatar
Yeah car is basically going to be daily driven, goto shows, and maybe see a dragstrip at mustangweek.
Old 12-12-2015, 04:13 PM   #9
Mugeismo's Avatar
Tein is very common on japanese. From my experience they are worthwhile. H&R is more common on euro. Also very highly recommended. I can't speak to mustangs specifically, but the rule of thumb I learned was this:
1" drop or less - no need for camber adjustment or new shocks. Unless you're going for negative camber or your shocks are very old, don't bother.
More than 1" - shocks and springs with camber adjustment. Better safe than sorry. Not sure what other mustang specific parts are recommended.
My last Honda had a lot of suspension work done. Camber adjustment was necessary with the 2" drop. I did fully adjustable camber arms instead of just the bolts. Gave me far more fine tuning ability. With all I had done, the car handled light a go kart. A track monster.
Mugeismo is offline   Reply With Quote
Tein S-techs? Tociko dampers? Rynarok 2011-2014 Mustang GT 0 05-10-2014 12:57 PM
For Sale: Feeler thread: tein s tech lowering springs comporange Mustang Parts for Sale and Wanted 1 05-01-2014 04:23 PM
Tein s tech lowering springs Burkeys96GT Pre-2005 V6 Mustang 11 03-10-2013 04:16 PM
TEIN S Tech lowering springs mustang06gt 2005-2010 Mustang GT 5 12-28-2012 02:27 PM
Anyone know about Tein Suspension 1995boss 1979-1995 Mustang GT 8 03-06-2012 09:52 AM
04:02 PM
