Suspension issue? - Mustang Evolution
Old 12-23-2015, 09:34 AM   #1
Suspension issue?
I'm driving around today doing some Christmas shopping. I noticed a creaking sort of sound on the passenger side tire area. Happens with any kind of movement. Turning, accelerating and braking. Any ideas on what might cause this. Oh, its a 2001 GT Convertible
Sent from my LG-H810 using Tapatalk
Woody3 is offline   Reply With Quote
Old 12-27-2015, 11:59 AM   #2
rdwelch's Avatar
Could be a body or control arm bushing in need of replacement.
rdwelch is offline   Reply With Quote
Old 12-28-2015, 10:50 AM   #3
Front or back?
And honestly if everything is stock from 2001 I'd be looking to overhaul all my control arms, bushings, endlinks etc...
Old 12-28-2015, 11:10 AM   #4
It's the front. I haven't had the car long so I guess I should just assume none of that stuff was done
Old 12-28-2015, 11:42 AM   #5
XSlashDashX's Avatar
Sounds like a ball joint.
Old 12-29-2015, 12:55 AM   #6
Steve96's Avatar
I would say it sounds like a ball joint. Mine would creek too before i got them replaced.
1996 GT
Old 12-29-2015, 05:28 AM   #7
x10 on the balljoint if that's the symptoms and its coming from a front wheel. Get the Steeda X2 units and if you want to get 1/2" drop install them without the spacers. You'll need an alignment anyway with new balljoints so might as well. Also do both sides when you do it because the other one will start making noise soon most likely.
It would also be a good time to replace the A arm bushings which don't last forever in these cars. If you have any sort of steering wheel shake or pulsing on the highway its a safe bet the A arm bushings are dry rotted.
Old 12-29-2015, 05:46 AM   #8
Thanks for all of the info guys. I'll have all of that checked out
Old 12-29-2015, 11:56 PM   #9
Steve96's Avatar
I used Moog ball joints in mine, they are good too but not quite as good as the Steeda X2s, especially if you are or plan to lower your car. I wish I would have known of these at the time, i would have ordered them instead to get the extra 1/2" drop. The extra 1/2" on the front of my car would make a big difference to me as ive never been super happy with my front drop.
1996 GT
Old 12-30-2015, 06:35 AM   #10
Well that's just an excuse to pull the A arms to change the balljoints to the better ones. And then if you are going to pull the A arms you might as well upgrade them to tubular. And if you are doing that you might as well convert to coilovers. And doing that you might as well just buy the whole entire front Max Motorsports K member/A arm/coilover kit so you don't have to remove anything twice.
Old 12-30-2015, 11:29 AM   #11
fomoco4life's Avatar
Just a heads up, thought my squeak was balljoints, turns out it was outer tie rod end. Lots of squeaky component possibilities, including notorious steering rack sleeve
fomoco4life is online now   Reply With Quote
Old 12-30-2015, 10:38 PM   #12
As old as these cars are now, all that stuff is going to start to fail if they are drivers even if the car is well maintained.
Old 12-31-2015, 07:33 AM   #13
rdwelch's Avatar
Let us know what you find out.
Old 12-31-2015, 08:03 AM   #14
Thanks for all the info. You guys are great. Unfortunately, I'm the furthest thing from a mechanic so I'll probably have to take it somewhere to be looked at
Old 01-19-2016, 03:30 PM   #15
Bgrimes1's Avatar
Did you check the stabilizer bushings, or even the LCA
04 GT
Bgrimes1 is offline   Reply With Quote
Old 01-22-2016, 04:21 AM   #16
I didn't. I'm the furthest thing from a mechanic. I wouldn't even know what I am looking for
Old 01-22-2016, 06:35 AM   #17
Bgrimes1's Avatar
Let us know when u get it checked out
04 GT
« Clutch noise | Cams »
Suspension Issue - HELP Gammer2015 2011-2014 V6 Mustang 18 11-16-2015 07:47 PM
Fuel issue? Ignition issue? jriccard 1979-1995 Mustang GT 7 07-04-2015 12:42 AM
Suspension Upgrades/issue paintmann111 2011-2014 V6 Mustang 11 03-11-2014 10:58 AM
Suspension issue 13 stang22 2011-2014 V6 Mustang 15 02-22-2014 06:18 AM
BMR Suspension parts with 1 issue Coyote 5 2011-2014 Mustang GT 26 10-03-2012 10:10 AM
05:47 AM
