Tailpipe Fitment/Identification - Mustang Evolution
Old 12-27-2015, 03:15 PM   #1
I want to install a muffler delete and 3" tailpipes.
-Has anyone identified a set of 3" tailpipes that have fit over the axle, proper clearance?
__________________________________________________________________
Can anyone identify these tailpipes that merge??
Thanks,
Old 12-27-2015, 07:56 PM   #2
parkerz28's Avatar
That looks nothing like the exhaust system of any 96-04 I've ever seen to be honest. I'm not familiar with the side exhaust options but unless they changed the side exhaust out and put tailpipes on I'm at a loss
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 12-27-2015, 07:58 PM   #3
I've seen a 3" IRS kit... which is the only possible thing I could see that kit fitting is the IRS. Getting 3" pipes over the axles would be really tricky tho, not saying it can't be done but I'd go dumps or sidepipes TBTH. You could always have a really good shop custom bend you something which is probably the route I'd go if you are dead set on a 3" overaxle setup.
Old 12-28-2015, 06:18 AM   #4
Pictured is a Ford Racing M55 catback. If you can find one it will be well over $1500.
You can fit a 3" IRS catback under your SRA.
Sent from my XT1045 using Tapatalk
Old 12-28-2015, 06:53 AM   #5
Yep but then you have to remove the catback if you ever have to unload the rear suspension if you run an IRS catback with a SRA. I've seen it done before and it looks just as good as it does on the IRS but its a PITA maintenance wise.
Old 12-28-2015, 09:01 AM   #6
I've been doing it for 3 years. Really isn't as annoying as you would think.
Old 12-28-2015, 09:31 AM   #7
Yeah I guess I mean how often do you need to jack up the rear of the car? Especially with a staggered wheel/tire setup that you can't rotate.
Wandering exhaust tailpipe... Edd2016 2011-2014 Mustang GT 9 09-24-2015 07:42 PM
More smoke from tailpipe XSlashDashX 1996-2004 Mustang GT 21 12-17-2013 09:40 AM
Black liquid from tailpipe ForsakenProto Pre-2005 V6 Mustang 7 10-25-2011 11:33 AM
LF tailpipe, yes just 1 LMAO Otlaw80 Mustang Parts for Sale and Wanted 1 06-15-2009 09:16 AM
tailpipe hangers... 232stang01 Pre-2005 V6 Mustang 32 11-30-2004 11:00 PM
04:28 PM
