Rear Brake Caliper - Mustang Evolution
Old 12-27-2015, 06:00 PM   #1
escottcarp's Avatar
Rear Brake Caliper
Today I disassembled my rear brakes just to check that my slide pins were sliding easily. I've had a problem with that and was just doing some Sunday-afternoon PM.
However. The caliper piston on the passenger side had rotated 90 degrees. The two notches were horizontal rather than vertical in relation to the caliper. Is this a problem?
Something else. I could not turn the piston. Problem?
I changed the other rear caliper about two years. I don't suspect this caliper is dragging as I check my wheels for excessive heat occasionally. The brake pads had normal wear. So, i believe that caliper is functioning normally.
Any ideas? Thanks.
escottcarp is offline   Reply With Quote
Old 12-27-2015, 06:09 PM   #2
Slater2111's Avatar
Rear Brake Caliper
The Pistons screw in to compress and don't just compress like normal Pistons. They are designed this way. It's normal operation unless I'm missing something.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 12-27-2015, 06:26 PM   #3
escottcarp's Avatar
Check. I was trying to turn the piston.
Old 12-27-2015, 06:55 PM   #4
Slater2111's Avatar
You can get a caliper key that attaches to a 3/8 drive. That will turn it in no problem.
Old 12-27-2015, 07:04 PM   #5
Slater2111's Avatar
Rear Brake Caliper
Double post. But I attached mine to my electric impact and turned it that way. One side of mine was really stuck and it made short work of it.
Old 12-27-2015, 07:59 PM   #6
There is a special kit you can rent from Autozone or just buy it for like $15 from Harbor freight that turns the pistons in via those notches. The universal cube thinger does not work on Mustang pistons.
Old 12-27-2015, 09:58 PM   #7
escottcarp's Avatar
In the past, I have used a needle nosed vice grip to turn the piston each time I needed to. I had not checked Harbor Freight for that tool. I'll do that.
This brake seemed to be working correctly while taking a test drive. I heard the clicking sound when I backed up the first two times. So, I guess the auto-adjust functioned correctly. I had no idea how the piston turned itself or why I can't turn it now.
Old 12-28-2015, 06:14 AM   #8
If you come across one that is very stubborn or has been pushed all the way out just loosen the bleeder valve and compress. Remember to bleed brakes afterwards
Sent from my XT1045 using Tapatalk
Old 12-28-2015, 10:25 AM   #9
escottcarp's Avatar
Nice tip, lowflyn.
I had unscrewed the master cylinder cap (and laid the cap on its opening).
Your tip will be better.
Thanks
Old 01-01-2016, 07:13 AM   #10
Because the parking brake is built into the rear caliper the piston has a compress and rotation motion to it. When I bought my mustang one of the first things I did was a brake job and noticed that the previous owner had them changed or replaced them himself and the pins on the pads were not properly lined up with the pistons and they destroyed them. I ended up getting rebuild calipers and the proper tool to lined them up and fixed it. It is a nice tool to have and with proper maintenance your brakes will work great.
Lone Wonderer is offline   Reply With Quote
Rear brake caliper problems. Speed_Mister 1996-2004 Mustang GT 14 05-12-2015 03:02 PM
Rear Brake Caliper Compression gweze001 Mustang DIY and Technical 0 02-16-2015 09:00 AM
Rear Brake Caliper Issue jaymjohnson 2005-2010 Mustang GT 12 11-05-2012 10:33 PM
Rear brake caliper anchor bolt size/help CakeOrDeath? Pre-2005 V6 Mustang 5 09-01-2007 12:04 AM
Brake Caliper Paint? FloMasta24 Mustang Audio & Video 21 09-12-2004 04:06 PM
11:06 PM
