Abs causing car to bog? - Mustang Evolution
Old 12-28-2015, 09:31 AM   #1
keeney35's Avatar
I just got new wheels and tires, weld pro stars, 15x10 in the back and 15x3.75 in the front..
Sometimes, (mostly at highway speeds) the abs light will come on, causing my traction control to turn off..
Then once I stop and start it back up or slow down the light will go off but the car will be really doggy under 20-30 mph then it's fine once I'm going faster than that.
What is causing that?
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 12-28-2015, 07:47 PM   #2
After this occurs, and the ABS light turns off, have you tried turning off the TC and seeing if the bogging still happens?
straybullitt is online now   Reply With Quote
Old 12-28-2015, 11:00 PM   #3
keeney35's Avatar
No I'll have to try that next time I get a decent day to take it out before the actual winter weather comes along
Old 12-29-2015, 06:04 AM   #4
If your actual tire diameter difference between the front and the back is off by too much you can trip the ABS which is my guess. What diameters are you at front and back?
Old 12-29-2015, 12:09 PM   #5
keeney35's Avatar
15x10 in the back 15x3.75 in the front
Old 12-29-2015, 03:08 PM   #6
Ok... But what is the actual tire diameter? That tells me nothing.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 12-29-2015, 03:26 PM   #7
keeney35's Avatar
Sorry didn't see "tire" misread your post I'll double check when j get back home
Old 12-29-2015, 05:14 PM   #8
jeno's Avatar
Come on Scotty I thought you could tell over the Internet's lol
Sent from my Nexus 6 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 12-29-2015, 11:25 PM   #9
Steve96's Avatar
You are not ALLOWED to make mistakes on here!! Didnt you know that!!???? JK. But that probably is the issue i would bet. Had this happen on a Jeep Liberty once, fronts were about a 1/4" taller in the front than the rear (same tire size different manufacturer), it tripped the ABS a couple times and also made the trans feel at times like it was slipping. Driveshaft wasnt lined up correctly from that small amount and caused the slipping feeling here and there. Also like i said, a couple times it made my ABS light up too. Took a bit to figure out what it was at the time, thought the trans was going.
1996 GT
Old 12-30-2015, 06:42 AM   #10
I have not experienced ABS issues with a half inch tire diameter difference but it might just depend on the car. Its not really supposed to start to matter until you near the 1" difference range and even then I have heard of ppl getting away with it.
You can always just disable and remove all the ABS components. I'm not a huge fan of it anyway and will probably be trashing mine for a multitude of reasons.
Old 12-30-2015, 10:53 AM   #11
My abs light is always on with my drag setup. No issues with sluggish feel.
Sent from my XT1045 using Tapatalk
Old 12-31-2015, 09:53 AM   #12
keeney35's Avatar
Tires up front are 165/80/15's and rear are 275/60/15's
Old 01-01-2016, 06:49 AM   #13
Your front tires are spinning at 794.6 rev/mile compared to your rear tire spinning at 720.9 rev/mile. Overall diameter of front vs rear is 25.4 inches in the front vs 28 inches in the rear. So if you are going 80 mph your front might be going 80 but your rear tires want to go at 88. Your ABS pump must be going out of it's mind.
Lone Wonderer is offline   Reply With Quote
Old 01-01-2016, 06:51 AM   #14
Found info in this site https://tiresize.com/calculator/
Old 01-01-2016, 11:19 AM   #15
keeney35's Avatar
So would a 17" wheel up front and taller tire help? I don't think j could find a taller front tire for that wheel size
Old 01-01-2016, 12:51 PM   #16
Try using this web site https://tiresize.com/calculator/ you can play with tire numbers and combinations to find the right fit for you.
Old 01-01-2016, 01:08 PM   #17
I wasn't going to do his homework for him after asking him how tall his rear and front tires were like 3 times lol. Not hard using tirerack or any other calculator where you punch in your tire specs and get the diameter.
Anyway, yeah if he is over 2" difference in diameter... well yeah no **** that'll make your ABS freak out. This is one of the main things to consider when buying big/littles with ABS. I'd just delete the ABS with a skinny setup up front anyway. There are places that make delete blocks or just make your own delete lines.
Old 01-01-2016, 10:06 PM   #18
keeney35's Avatar
I found a company that makes delete blocks that don't require any flaring of the lines or anything..
So I guess I'll just delete the ABS since I don't ever drive the car in bad weather and it's pretty much strictly a drag car and some weekend cruising to shows and meets..
And I'll pull the bulb for the ABS in the dash
Old 01-02-2016, 10:12 AM   #19
Yeah these guys
PRB Machining! Home Of The Original 94-2010 Mustang ABS Delete Manifold!
I'd recommend deleting your ABS anyway with skinnies up front even if there wasn't any issue.
Old 01-02-2016, 10:14 AM   #20
keeney35's Avatar
Sounds like a plan plus getting that abs out of the way allows more room for piping for my on3 kit
Old 01-02-2016, 10:24 AM   #21
I may have to pull mine out of necessity due to the intercooler piping for my Paxton. We shall see.
Old 01-02-2016, 10:27 AM   #22
keeney35's Avatar
Plus it drops like 13 lbs off the front end.
Question tho, is the abs box up by the front of the car all that's involved and needs to be pulled or is there more you can pull with it
Old 01-02-2016, 10:39 AM   #23
That's really all you need to do. You can delete all the sensors in the wheels to clean that up too. IIRC you need to pull the bulb out of the cluster because even a tuner won't get it to turn off. I dont THINK you will throw any codes that would keep the car from passing inspection but that might be something to consider. I know in NJ all we have is emissions and a fuel cap test but some states are cray.
Old 01-02-2016, 11:02 AM   #24
keeney35's Avatar
I'll pull the sensors as well then, and I planned on pulling the bulb, and as for the inspection I have my inspectors license so it'll pass lmao
Abs rear to non abs rear? misterpancho95 Pre-2005 V6 Mustang 0 01-21-2015 09:29 AM
Intake manifold installed today, little big of a bog when i hit the gas Jdunx98GT Classic Mustangs 3 05-30-2012 06:06 PM
New intake manifold installed , little bit of a bog when i step on the gas. Jdunx98GT 1996-2004 Mustang GT 9 05-03-2012 03:41 PM
1 st gear bog down. 1ijack 1996-2004 Mustang GT 12 12-21-2010 04:13 AM
abs on non abs sledgehammer General Mustang Discussion 4 01-28-2010 11:30 PM
05:31 PM
