extra bolt on intake manifold replacment - Mustang Evolution
Old 12-29-2015, 01:26 PM   #1
i just replaced my intake manifold on my 1998 gt. i have a bolt left over about 4 inches long and dont know where it would go. i recieved new bolts but the job was done over a period of time so i dont remember what new bolts i got. pleeeaaassee help i want my car back! i checked alternator and thermostat housing i dont know where else it could go.
perkins562 is offline   Reply With Quote
Old 12-29-2015, 04:20 PM   #2
infamous281's Avatar
If it's starts and runs fine .. don't worry lol
Sent from my SM-N910T using Mustang Evolution mobile app
Old 12-29-2015, 05:15 PM   #3
started up fine but i have to keep giving gas or it dies. smelled gas while it was running then i shut the car off. just barely damp around where the injector meets the manifold. but just barely
Old 12-29-2015, 06:12 PM   #4
jeno's Avatar
Your injectors arnt seated correctly or the orings where its damp are bad make sure there seated all the way down or replace the o rings you should have no dampness that means there's a leak at the injector or injectors
Sent from my Nexus 6 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 12-30-2015, 12:29 AM   #5
Steve96's Avatar
Yes, no dampness at all should be present. Like the others have said that sounds like your issue. You can get new o rings to be sure. May be a good time to clean and rebuild your current injectors or upgrade to the 21lb ones
1996 GT
Old 12-30-2015, 08:32 AM   #6
If you have an extra 4" long bolt its one of the manifold bolts. Check to make sure all your manifold bolts are there. Look up the manifold bolt pattern on google for a diagram, IIRC the longest ones go on either side of the tstat housing.
And yes you have a fuel leak somewhere, most likely an injector is not seated right. Remove the rail, check all the O rings, re-seat them and make sure the rail is seated down on all the injectors. There will be no dampness or fuel smell if it is done right.
Why did you do a 2-3 hour job over the course of many days?
2000 Mustang GT Steeda #0048
Old 12-30-2015, 12:25 PM   #7
fomoco4life's Avatar
I'd definitely pull rails and tb and check all intake bolt holes, there's a tough almost hidden bolt behind hoses and crap at firewall. If all ur bolts are actually in, ur fuel rail or an injector isn't seated properly, as stated before. Hope u torqued ur bolts to spec too, or there lies another possibility
fomoco4life is online now   Reply With Quote
Old 12-30-2015, 08:22 PM   #8
Yep, torqued to spec, in the proper sequence and in a 3 step pattern. You can't just go 22ft lbs on each bolt and call it good. I went 10, then 18, then 22 to finish going around the sequence. Then after 3 heat cycles I went back and re-torqued.
Jl c3-570 drop in replacment for mach 460? 99redgt Mustang Audio & Video 2 09-30-2012 11:56 AM
bumper replacment bluegrassfever6 1996-2004 Mustang GT 2 09-21-2012 02:38 AM
Front upper A arms replacment Ahmed ali khan 1996-2004 Mustang GT 9 05-10-2012 05:59 PM
1999 Cobra replacment Tires jgarey SVT Mustang 4 11-07-2011 12:01 PM
clock on dash gauge holder replacment 96mustangv8 1996-2004 Mustang GT 7 05-16-2011 11:46 AM
12:14 PM
