Lower control arm bolts stuck - Mustang Evolution
Old 12-31-2015, 05:13 PM   #1
Any tricks out there to free up the bolts? I'm trying to install my eibach springs. I got the nut off and the bolt to turn but I think the bushing is spinning with the bolt.
I don't have an impact gun to spin it fast. I've been soaking the bolts all day in penetrating oil... I'm stuck. I'd prefer not to cut the bolts if I can avoid it.
Quadracer18 is offline   Reply With Quote
Old 12-31-2015, 05:45 PM   #2
parkerz28's Avatar
The bolt is likely rusted inside the bushing sleeve. The front one is easy to cut the back one is a *****. Also sounds like your bushings are toast. I would replace those since you are pulling it apart. If getting a bigger hammer wont get them out you'll have to cut or torch them.
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 12-31-2015, 05:47 PM   #3
Does anyone sell individual bushings and bolts? I'm only going to need two if I cut those ones out. I see kits going for $70. At that rate, I'd sooner buy new lower control arms
Old 12-31-2015, 06:42 PM   #4
The bolt where you drop the spring right? Not the one closer to the front of the car right? Smack it with a hammer. I've never turned it trying to get it out, when lined up perfectly the bolt should be able to just slide out, but usually doesn't so smack it with a hammer a lot. Done that at least like 6 times now.
Old 01-01-2016, 12:42 AM   #5
infamous281's Avatar
Either use your jack to position the arm the correct spot to remove the bolt.
Use a hammer and a punch or screw driver to punch the bolt through the hole.
Impact the bolt out , or use a small pry bar to pop the bolt out with some tension from a jack on the arm.
Sent from my SM-N910T using Mustang Evolution mobile app
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
rear control arm bolts foxbox 1979-1995 Mustang GT 6 05-12-2013 12:16 PM
bolts bolts bolts! bcosta56 1979-1995 Mustang GT 8 10-10-2012 03:08 PM
Control arm bolts? Tbird232ci 1979-1995 Mustang GT 2 03-19-2006 07:33 AM
Lower control arm bolts Monkey Pre-2005 V6 Mustang 1 07-15-2003 10:37 AM
11:02 PM
