02 GT throttle problem - Mustang Evolution
Old 01-04-2016, 06:04 PM   #1
Romes02GT's Avatar
I just started having a problem with my 02 GT, as soon as the engine warms up the car feels like its running out of gas, but only when it is in gear and on the throttle. I checked all the fluids, and intake/filter for anything and looked fine. any ideas what it could be?
Romes02GT is offline   Reply With Quote
Old 01-04-2016, 06:46 PM   #2
Clogged fuel filter? O2 sensor? When was the last time the car had a tuneup and you'll also need to scan for codes. Even if your CEL is not on there might be codes. Very hard to diagnose anything over the internets.
Old 01-04-2016, 07:07 PM   #3
Romes02GT's Avatar
i bought it with about 86k on it, its at 103. Ive only had oil changes done. ok cool i have a buddy with a code reader, ill give him a call. thanks
Old 01-04-2016, 08:19 PM   #4
Code reader for codes, if you didn't do plugs thats something that probably should have been done at 86k. Factory plugs say 100k maintenance... but you have no idea what the previous owner did. APP104s gapped to .054 and torqued to 15ft lbs for the plugs. Rebuild the COPs while you are at it, $30 for a boot/spring kit, don't waste money buying $400 worth of new coils.
Air filter, fuel filter and then fix whatever is throwing a code. You also will probably want to clean the MAF element so get a can of MAF cleaner (not carb cleaner MAF cleaner) and clean that as well.
If you have some sort of aftermarket MAF setup in there that could cause issues too, it did with my friend's 04.
Old 01-04-2016, 08:19 PM   #5
Think I found the problem to all my issues. Throttle body? skylaar10 Pre-2005 V6 Mustang 8 07-18-2013 12:46 AM
Throttle body problem Stang.racr 2005-2010 Mustang GT 9 06-05-2012 11:49 AM
Throttle Problem jjsg09 1996-2004 Mustang GT 11 04-17-2012 05:44 PM
06 Throttle Body Problem Snake 42 2005-2010 Mustang GT 2 11-02-2007 01:55 PM
Throttle problem reply asap mustangmike524 Pre-2005 V6 Mustang 4 11-17-2004 10:31 PM
07:59 PM
