Pieceing together a procharger kit? - Mustang Evolution
Old 01-04-2016, 10:11 PM   #1
XxFLoridaboYxX's Avatar
Name:	ImageUploadedByMustang Evolution1451970501.211128.jpg
ID:	195460Click image for larger version
Name:	ImageUploadedByMustang Evolution1451970520.383699.jpg
ID:	195461 Click image for larger version
Name:	ImageUploadedByMustang Evolution1451970539.452174.jpg
ID:	195462 Click image for larger version
Name:	ImageUploadedByMustang Evolution1451970554.803705.jpg
ID:	195463 just made the 4 hour drive got a good deal on it . Got to find out what else I need. will do some more research before I start asking just thought I would throw a few pics up
XxFLoridaboYxX is offline   Reply With Quote
Old 01-04-2016, 10:26 PM   #2
Steve96's Avatar
Nice. I hope to do this one day!
1996 GT
Old 01-05-2016, 07:23 PM   #3
Yeah I've been looking for awhile started to lose hope on finding a used kit and then this popped up .
Old 01-05-2016, 09:20 PM   #4
Not too familiar myself but you might want to do some searching online. I'm sure there are some fairly complete lists from other forums.
It might also be worth contacting Procharger and talking to them about what you will need to successfully get it working.
Old 01-06-2016, 07:07 AM   #5
Hope you got a hell of a deal on the headunit, its very often not much more expensive to just buy the whole kit new especially procharger since they don't sell parts on superchargersonline.com.
I'd post want ads in forum classifieds or maybe call procharger and see if they'll sell you loose parts.
Old 01-06-2016, 07:35 AM   #6
1/6th of the price of the kit new I would say that's pretty good .
Old 01-06-2016, 01:23 PM   #7
AsUMING YOU have all the tubing you will need 42 lb injectors , 255 lph fuel pump, 90mm MAF & a tune
WAR HORSE is offline   Reply With Quote
Old 01-06-2016, 01:26 PM   #8
I see you already got the MAF saves you about $240
Old 01-06-2016, 01:27 PM   #9
Looks like he has a MAF tube already. If that one won't work for whatever reason, he should be getting a slot MAF in a 3" sample tube. That'll be optimal for up to the 600-700hp range. The old element MAFs are holdovers from the fox days and any good tuner will greatly prefer the 05+ style slot.
Old 01-06-2016, 01:31 PM   #10
what do you think about a Ford Racing 90mm ?
Old 01-06-2016, 03:24 PM   #11
Yeah I have the maf tube and looks like I have most of the pipping to the intercooler . Just need injectors and a pump and probably a few other small things .
Old 01-06-2016, 03:35 PM   #12
do you have the radiator hose ? It is shaped differant from stock to give you clearance. there is a air intake tube for the SC unit with a bypass hose & sensor port & filter
Old 01-06-2016, 03:40 PM   #13
Should be able to use most other parts from the Vortech systems, except the mounting bracket. But piping and intercooler and fuel system should be interchangeable as long as the couplers are right sizes.
Old 01-06-2016, 04:06 PM   #14
you can contact Pro Charger ATI & get any part you need , you just have to give them the serial # on your unit to prove you own 1
Old 01-06-2016, 04:17 PM   #15
Alright thanks for the info
Old 01-06-2016, 04:22 PM   #16
they will give you a PDF file of the Users Manual if you ask
Old 01-06-2016, 05:14 PM   #17
None of the 04-down style MAFs are a good idea anymore. 05+ slot style. PAS sells a full kit with a bung and wiring for $199 shipped. Weld it directly into the middle of the straight shot from the final turn to the throttle body turn unless you need bigger than 3"/78mm which 99% of ppl on this forum will not.
Old 01-06-2016, 06:04 PM   #18
parkerz28's Avatar
I would also suggest 47lb ford injectors... cheap and can buy any where new. Just make sure you buy the normal length not shorts. I have a serial # if you need it 😘
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 01-06-2016, 06:11 PM   #19
Yeah send me the serial number any info I can get helps me out. The guy also gave me this said it came off his friends car Click image for larger version
Name:	ImageUploadedByMustang Evolution1452129066.874259.jpg
Old 01-07-2016, 03:16 AM   #20
looks like another MAF , I wouldnt use that .. I had a pro charger on my 98 & never seen that part
Old 01-07-2016, 06:20 AM   #21
I was going to say the same thing, that piping looks jacked. That said the MAF itself might work... might. Again, just get the slot MAF and never have to buy another one.
PAS Xtreme Slot Style Mass Air Sensor w/ Universal Harness & Flange - Power Adder Solutions, Inc. - Mustang Performance Parts
I paid $199 shipped with a corral forum discount.
Old 01-07-2016, 12:49 PM   #22
parkerz28's Avatar
Name:	ImageUploadedByMustang Evolution1452196005.125059.jpg
This is the 47lb fuel injectors serial #. You will need ev6 to ev1 adapters but ford also makes the part and they are like 25 bucks.
Old 01-07-2016, 12:53 PM   #23
parkerz28's Avatar
And about the mass air and tubing you posted...not sure if the mass air sensor will work but the position of the sensor is not good. You want around 6" of straight pipe before and after it. Otherwise it will make it more difficult to tune.
Old 01-07-2016, 01:14 PM   #24
For a blow thru. For a draw through most of them are setup with the MAF as the first damn thing in the intake tract right behind the filter or like 6" behind the filter.
But this is why I said in an earlier post to get a slot MAF and weld the bung dead center in the straight shot of piping coming from the front of the car to the TB. That'll give a solid 6" on both sides and you don't even need a sample tube because most intercooler/blower piping is going to be 3" and that's good enough for 800hp.
And hopefully this is not the start of a roller coaster for piecing a kit together. The bracket and a few other things will be procharger specific but I think the rest he could get from superchargersonline or used.
Old 01-07-2016, 03:00 PM   #25
So after looking around online and at pictures I don't think I have all the piping I need and instead of trying to find a few pieces I might need I was looking at the cxracing intercooler kit ? You guys like their product or recommend a different one?
Old 01-07-2016, 05:31 PM   #26
parkerz28's Avatar
I wasn't disagreeing with ya... If you ever finish your car I'll bet the blower set up will look very similar to mine. Of course I actually finished mine months ago. Get off your a$$ and finish it bro we are all waiting lol 😘
Old 01-07-2016, 07:56 PM   #27
I have the CX Kit in my garage waiting to go on. Really nice kit. Don't buy it from their website, buy it from their store on ebay its way cheaper there.
Lol yeah right... Dude noone is more pissed at how long its sat than me. I am forcing myself to work on it this weekend no matter the temp or how bad I'm feeling. I'm hoping to have it close to ready to hook up the load leveler. I've got 4 months before I should be guaranteed to not have to worry about road salt so that's the deadline.
Old 01-07-2016, 08:54 PM   #28
Steve96's Avatar
The anticipation is killing me!
1996 GT
Old 01-08-2016, 06:32 PM   #29
CRX universal tube kit will be fine but before you spend any $$$ go online to ATI Pro Charger,
get the serial # off your SC unit , when you register with them tech help will be available, any part you need you can get & they will email you a PDF of the owners manual , it has step by step install instructions , will make install alot easier
Old 01-08-2016, 07:13 PM   #30
Already did all that got the installation manual the guy said they don't sell all the piping as a kit
Old 01-08-2016, 07:17 PM   #31
Just get the CX racing kit then as long as the procharger mounts in the same spot as the vortech and paxton on the passenger side of the motor. Piping problem solved.
Old 01-08-2016, 07:51 PM   #32
Let us know how you make out , like I said I had 1 , my Brother has a Vortech, better low end power than a turbo....FUN FUN FUN
Old 01-09-2016, 02:56 PM   #33
DO you have a Blow Off Valve ?
Old 01-09-2016, 03:02 PM   #34
Name:	ImageUploadedByMustang Evolution1452376956.821757.jpg
Old 01-09-2016, 03:46 PM   #35
The CX racing kit includes a holy **** loud one that works well so you could make a little money back selling that one and I'd also sell that maf too.
Sent from my LG-D801 using Mustang Evolution mobile app
Procharger stage 2 kit Black5.0 2011-2014 Mustang GT 0 05-20-2012 08:15 AM
looking for a procharger kit kirpy 2005-2010 V6 Mustang 0 01-16-2012 04:02 PM
ProCharger Kit Injectors 05cobra Pre-2005 V6 Mustang 8 04-17-2010 08:24 PM
F/S: Procharger P1SC Kit 99-04 V6 Mustang!! afinley11 Mustang Parts for Sale and Wanted 3 08-01-2008 03:35 PM
P-1SC ATI Procharger Supercharger Kit 99-04 V6 Mustang V6Pak Mustang Parts for Sale and Wanted 6 01-18-2005 03:38 PM
12:03 AM
