help please!!! - Mustang Evolution
Old 01-05-2016, 11:47 AM   #1
help please!!!
i just replaced my intake manifold. got new plugs and cables and new orings on the injectors. now i start my car and it dies unless its warmed up for a minute. when its running it idles at about 450 rpm and the entire car shakes. i give it gas and the runs cleaner but not what it should be. the rpm drop pretty normal when i let off the gas( car is in park). im guessing a big vacuum leak somewhere, hopefully not anywhere on the manifold. and i had 4 codes P1116 engine coolant temp sensor, P0353 ignition coil C, P0505 idle air control valve system fault and P0121 throttle position sensor circuit failure. i erased codes and p1116,p0353 and p0505 came back. where should i start from here?
perkins562 is offline   Reply With Quote
Old 01-05-2016, 01:01 PM   #2
Bgrimes1's Avatar
What is your throttle position reading at idle
Bgrimes1 is offline   Reply With Quote
Old 01-05-2016, 03:22 PM   #3
jeno's Avatar
I would look at the idle air first that make it idle rough if its bad
Sent from my Nexus 6 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 01-06-2016, 08:10 AM   #4
If its a FRPP replacement intake and nothing else changed I would chalk this up to an install error. Something not seated right, something not torqued right or something got messed up at some point during the process.
My advice is to pull it back apart and re-do it going real slow, making sure all the O-rings are good and the injectors are all seated and every COP is plugged in and make sure the intake is properly torqued in the right sequence. Also make sure all vac lines are hooked up and sensors are all plugged back in.
2000 Mustang GT Steeda #0048
My 92 mustang died please help please wont start HybridTruth93 1979-1995 Mustang GT 2 05-04-2014 04:07 PM
Please help me! Please!! 98StangKid SVT Mustang 0 05-17-2013 10:40 PM
PLEASE, PLEASE HELP!!! Zoe 2005-2010 V6 Mustang 6 03-11-2012 02:19 PM
MT82 Transmission Issue...Please Read and Please HELP DannyDoright 2011-2014 V6 Mustang 5 03-02-2012 09:46 AM
Sold a Car Please, please help!!? booth General Mustang Discussion 9 03-20-2010 10:29 AM
10:13 AM
