Automatic Transmission Advice/Questions - Mustang Evolution
Old 01-08-2016, 11:38 AM   #1
04beautyGT's Avatar
Ok, so I was just about to do a tranny flush (even tho alot of people say not to on a 200k vehicle), but my transmission started jacking with me and now I'm scared to. I have a 2004 GT with 200500 miles, BAMA Tune, and the 4r75W transmission BTW. It will not shift into 3rd unless under heavy load [3000-3500 RPM] (I realized how bad this problem is when I spun the tires on a damp road upshifting!!) Occasionally the tranny will slip if the load is really high [above 4000RPM]. On stock tune, it will shift into 3rd from 2nd, and then briefly shift into 4th, on the tune it will go straight to 4th from 2nd when I almost completely let off the throttle (I think the tune does that because I am going over 40mph at that point). I can get it to not skip 3rd if I turn off O/D and it downshifts from 4th to 3rd just fine. I'm worried that I may need a rebuild, so what are y'alls thoughts on this plan, and putting a manual in it is not an option:
Step 1: Drop the pan, check for significant metal debris, if minimal, pull the solenoids and test them with an DMM (should read between 20-30 ohms, correct?). If any are faulty, replace them, replace the filter, refill the pan, bolt it up, and drive on.
Step 2: If not, buy a rebuilt tranny and a stall torque converter. Unless, this problem could be caused by a dirty filter and I should replace the filter first to see if that fixes it before going the rebuilt route.
If I need to get a rebuilt tranny, what type/brand of converter would y'all recommend? 2k, 3k, 3.5k stall converter? This is a daily driver, and I have no idea of how a stall converter will effect its drivability. I can get a rebuilt transmission for $475 allegedly on craigslist with a 3 year warranty.
04beautyGT is offline   Reply With Quote
Old 01-09-2016, 04:21 PM   #2
Call Circle D and talk to them about a converter. If you are on a shoestring budget, call Freakshow Performance in Abilene, TX.
It is rebuild time for your trans.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 01-10-2016, 05:01 PM   #3
04beautyGT's Avatar
Thanks, I figured it was rebuild time, 200k isn't too bad anyway.
Sadie- '04 GT Auto- RMR#4837, 4-Point-SEXY
Old 01-11-2016, 07:27 PM   #4
Mfore33's Avatar
I've got a 2000 gt auto with the p0782 2-3 shift error. Some people tell me to replace the accumulator and solenoid. Any other thoughts?
Old 01-16-2016, 02:51 PM   #5
04beautyGT's Avatar
I don't know about the accumulator, but there are multiple solenoids in these transmissions. That's what's hard about electronic transmissions, there are multiple possible problems, but there is no good way (that I know of) to be able to diagnose with 100% confidence.
Old 01-16-2016, 03:04 PM   #6
Mfore33's Avatar
Well I guess I'll try the accumulator and solenoid first before dropping the cash in a new transmission
automatic transmission questions 1998 mustang gt y95stang 1996-2004 Mustang GT 3 05-06-2015 10:39 AM
non automatic headlights/automatic turn off silverskoundrel General Mustang Discussion 11 09-07-2013 09:13 AM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
WOT with an automatic...need advice Ghostbuster Pre-2005 V6 Mustang 14 04-09-2005 07:15 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
04:13 PM
