02' Roush 360R Help - Mustang Evolution
Old 01-11-2016, 12:37 PM   #1
Joshy's Avatar
02' Roush 360R Help
My Roush is giving me this code and I don't really know where to begin or if the code might just be false as did use a cheap diagnostics tool. The car doesn't have cats according to the previous owner but I am seeing no codes for the 02' sensors.
Possibly related, when the car gets under half a tank it will cut out under hard acceleration. This only happens when it's under half a tank and closer to a quarter tank. I never let it go far below half and always run premium. From what I understand, the car uses a special dual fuel pump so I hope that's not the issue. Thank you in advance. I am stumped.
www.petom.biz
Joshy is offline   Reply With Quote
Old 01-11-2016, 02:30 PM   #2
Jbone007's Avatar
Any way you can check the fuel pressure? From what you are saying it sounds like it is not getting the fuel it needs under hard acceleration. So I am thinking fuel pump or possible clogged fuel filter! (Half a tank of fuel or below could be related to the Fuel level sensor also) Your, fuel pressure sensor, throttle position and fuel tank pressure are all on the same circuit that the code identifies as "bad"
Jbone007 is offline   Reply With Quote
Just purchased 02 Roush 360R Joshy 1996-2004 Mustang GT 25 06-06-2015 06:30 PM
2002 roush 360r pulley upgrade dgossey82 General Mustang Discussion 0 12-09-2014 07:31 PM
2002 roush 360r pulley upgrade dgossey82 1996-2004 Mustang GT 7 12-05-2014 06:01 PM
2002 Roush 360R 2002VertGT FYI Ads | Recently Listed 4 06-18-2013 07:00 AM
Roush 360R Jcastro7608 1996-2004 Mustang GT 7 03-11-2013 02:30 PM
11:56 AM
