Vibration issue - Mustang Evolution
Old 01-13-2016, 08:47 AM   #1
XSlashDashX's Avatar
Vibration issue
03 auto gt. Vibration starts around 30 mph and 40. Goes away anything after that. Tires are balanced. Would a transmission or motor mount cause the vibration? Feels like I'm going over a lot of tiny bumps.
Old 01-13-2016, 09:36 AM   #2
jeno's Avatar
Yes check the trans mount mine was bad same issue replaced it issue solved
Sent from my 2003 rocketstang using Mustang Evolution
jeno is offline   Reply With Quote
Old 01-13-2016, 11:21 AM   #3
I'd honestly do both motor mounts and the trans mount. Energy suspension poly is the ONLY thing I will ever use. Can't remember if the auto trans mount is the same as the stick but the motor mounts will be. The stock rubber motor mounts are completely pathetic even if they aren't bad.
Could also be a U joint. If you grab the DS at both U joints and can feel any play in it at all that's bad. They don't fail very often tho.
Old 01-13-2016, 11:41 AM   #4
Sitting at 130k miles. I'm sure nothing has been changed out. I'll check the mounts and DS today.
Old 01-13-2016, 11:46 AM   #5
The stock mounts use these little rubber wafers in between the metal pieces, its really sad. The stock trans mount is actually decent TBTH, way better than the newer cars where it lets the tailshaft move all over the damn place without an insert. But over 12-15 years... yeah...
And if you do replace all the mounts... I will say there is a good reason Energy suspension is more $$$ than the AM ones. I've had cheap poly mounts/bushings before. Never again.
Fuel issue? Ignition issue? jriccard 1979-1995 Mustang GT 7 07-04-2015 12:42 AM
Vibration issue BA68 mustang Classic Mustangs 3 03-13-2014 04:31 AM
94 cobra vibration issue fredericcobra 1979-1995 Mustang GT 10 05-30-2008 06:55 PM
Torque specs for vibration dampener ridelikehell Pre-2005 V6 Mustang 4 02-20-2004 05:45 AM
Vibration Dampener Torque Specs ridelikehell The Bar 2 02-17-2004 05:39 AM
06:24 PM
