What gauges should I put in pillar? - Mustang Evolution
Old 01-13-2016, 06:37 PM   #1
Region: South Dakota
2004 gt need to know what kind of gauges I should put in that I could use in a 3 gauge pillar. Thinking air/fuel ratio, trans temp, and possible a diff temp gauge or a vacuum gauge. Any suggestions would be great guys. thanks for reading.
MustangGTNewbie is offline   Reply With Quote
Old 01-13-2016, 07:15 PM   #2
Steve96's Avatar
Maybe wideband as you mentioned, oil temp, water temp? There are several different ones you could go with. Can always use a faux boost gauge.
1996 GT
Old 01-13-2016, 07:34 PM   #3
Wideband should go in your line of sight where you can see it easy so yeah that'd work. Boost/Vac and fuel pressure are the other big ones.
Get a cluster bezel for oil pressure and water temp.
But to be honest, the 3 pillar pods look like a bucket of ***. Speed of Sound takes stock pillars and makes the pods look SWEET but the problem is you can only get them with 2 pods. You can always get an over the column pod for the 5th gauge or just not worry about boost/vac till you get a power adder.
Old 01-13-2016, 08:19 PM   #4
Bgrimes1's Avatar
Wideband for sure and fuel pressure or boost
Bgrimes1 is offline   Reply With Quote
Old 01-13-2016, 10:23 PM   #5
phatspeed7x's Avatar
I know Auto Meter makes the bezel for the add a gauge to your steering column. I want to do a wideband gauge there on my Stang.
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 01-14-2016, 12:25 PM   #6
KryptonKnight's Avatar
My 2c's. The OEM gauges only provide an about reading at best. The only OEM gauge that ever actually changes is the temperature and fuel needle. If you want actual numbers to monitor the oil pressure and charging circuit you'll need to buy and add those gauges. They may not seem all that flashy but they are basic information. I have a triple Autometer pod on my "A" pillar. Easy install & easy to read but when getting in, you will have to remember to lean your head back or get bumped in the face.
CAI,6pt.Cage,FRPPSprings,Raptor,UDP,Hurst,SiliconeHoses,BossStrutBar,LoudMouths,Plenum,Cam,Brake,Battery,StrutCovers,FRPP PC.ValveCovers,Chin Spoiler,Hood Scoop&Pins,painted 10"Stripes & Pins,EleanorGrill,Chin Spoiler,"C" Scoop,1/4 Side Scoops,Rear Fascia,PJ Rear Louvers,Roush Skirts & Rear Wing,Triple Pod & Gauges,CF Dash,2010Projector lights,2014Taillights, Real Carbon Fiber full kit,19" 2014 GT rims.
KryptonKnight is offline   Reply With Quote
Old 01-14-2016, 01:07 PM   #7
Slater2111's Avatar
@phatspeed Click image for larger version
Name:	ImageUploadedByMustang Evolution1452802068.401875.jpg
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 01-14-2016, 02:58 PM   #8
oxfordwhite's Avatar
Don't put em on the pillar. That's my 2cnts.
oxfordwhite is offline   Reply With Quote
Old 01-15-2016, 01:04 AM   #9
Mile high JDF's Avatar
Unless you have a 99-00 then there aren't exactly a lot of options for gauge placement.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-15-2016, 05:33 AM   #10
What putting them under the radio? Screw that noise I want a touchscreen lol.
2 or 3 on the pillar, 2 in the cluster, 1 on the column and then you can always get the south florida cluster that goes where the clock used to on the 97-down cars. Just gots to be ok with cutting a hole in the 98-up vehicles. That gives you 3 more and they still have a few NOS units for sale.
Old 01-15-2016, 07:28 AM   #11
That or swap the HVAC controls down to the bottom.
Old 01-15-2016, 10:32 AM   #12
Originally Posted by Slater2111 View Post
@phatspeed Attachment 195788
Yes! Perfect!
Sent from my LG-H900 using Tapatalk
Old 01-15-2016, 01:22 PM   #13
I've got the same wideband as slater does except mine is whiteface. Only like $130 on Amazon and they come with a bung too. Not running one on a vehicle with a tune is pretty damn stupid.
Old 01-15-2016, 04:57 PM   #14
Slater2111's Avatar
You're the reason why I got that model, Scotty. It plain works and was easy to install.
Old 01-17-2016, 10:31 AM   #15
Speed_Mister's Avatar
Region: Arkansas
Get oil pressure gauge, wideband the two are the only ones really needed.
2004 Mustang GT 5 Speed
Full Bolt Ons
370RWHP 470RWTQ
12.1 @ 117.9
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Wanted: Gauges, pods, pillar roushMarlon831 Mustang Parts for Sale and Wanted 13 11-13-2015 11:47 PM
Base gauges to premium LCD screen gauges alucard3600 2011-2014 V6 Mustang 15 04-27-2015 02:17 PM
For Sale: Aerofroce gauges 2011 pillar Moto111 Mustang Parts for Sale and Wanted 7 09-05-2013 07:04 PM
Triple pillar gauges RVAStang05 Mustang Paint, Appearance & Detailing 6 02-19-2012 06:08 AM
A-Pillar gauges Matt@StangMods Mustang Parts for Sale and Wanted 1 06-28-2005 01:56 PM
08:58 PM
