Does anyone offer kits for 32v swaps? - Mustang Evolution
Old 01-16-2016, 08:03 AM   #1
dwbrand's Avatar
I found a bargain on a 97 Lincoln 4.6 DOHC and am contemplating swapping it into my 03 GT or selling it and making some money on it.
I've read through 32nomad's write up a few times and am wondering if anyone sells kits to help with this (such as extending wires).
I also want all my ducks in a row before doing the swap. This motor has B heads, do I need to upgrade them? (Such as the heads from newer Lincoln Continentals)
When I look for Mustang parts for this motor, do I need to look for 96-98 Cobra or newer like a Mach 1?
I'm in no hurry to do this- if I do it I want everything ready before starting since this is typically my daily ride.
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 01-16-2016, 09:55 AM   #2
oxford5pointoh's Avatar
Can't really help you but I'd like to see it happen! Got my popcorn
Vote Ox Mustang of the Year 😬👍🏻
Old 01-16-2016, 07:32 PM   #3
dwbrand's Avatar
Thanks man! I hope it happens too...
Something else- I'd like to find someone to source the fuel rails from to make it return less.
1968 Mercury Cougar
Old 01-18-2016, 10:00 AM   #4
The swap is a 90-95% drop in so its not really going to be cost effective for anyone to make a kit. Even the 2V computer can run the 4V. Wire extension is just cutting and soldering and switching the injector wire polarity is also a pretty easy DIY.
B heads are good heads, the newer heads you are talking about are C heads which came on Continentals and 99/01 Cobras. You will also need a 99/01 Cobra or a Mach intake for those heads. You can keep the B heads or upgrade, your call/budget.
If you are going to keep the B head setup you will want engine parts from a 96-98 Cobra, if you go with the C heads you'll want 99/01 Cobra or Mach engine parts depending on what you are talking about. For body/driveline/suspension etc... stuff a lot of it is compatible throughout the 94-04 SN95 format run.
If this is your first time doing this I would not recommend doing it to your daily unless you have a beater lined up or someone you can rely on to get you from point A to point B when gremlins/issues come up.
If you are looking for a PnP kit and a better OEM replacement motor I'd say maybe do the 3V kit and 3V swap but TBTH... fresh 2V out of a 04+ Crown Vic and a power adder is probably your best bet.
Old 01-18-2016, 11:50 AM   #5
dwbrand's Avatar
Thanks Scotty.
I knew about extending the wires and that's the part that bugs me, along with modifying the fuel rail to a return less style.
I still have my pickup so I won't be afoot if something came up.
Will the harness and fuel rail from a Mach or Cobra work instead of extending those wires?
1968 Mercury Cougar
Old 01-18-2016, 11:53 AM   #6
dwbrand's Avatar
Also... I'd love to go 3v but this 4v motor was DIRT cheap. There's nothing wrong with my 2v so I can take my time and make sure the 4v is in great condition. The bargain I got on this motor is the only reason why I'm even considering it.
1968 Mercury Cougar
Does MPT offer any discounts to this group? JR4288 2011-2014 V6 Mustang 8 12-01-2014 10:08 AM
Why does American Muscle not offer Comp. Orange pre painted parts? richg93 Mustang Paint, Appearance & Detailing 6 01-07-2014 08:38 AM
does am offer a military discount o8gt AmericanMuscle 14 09-10-2013 07:54 AM
Fantasy Coyote swaps LbarJ 2011-2014 Mustang GT 38 02-04-2011 12:57 AM
Body Kits, Body Kits, Body Kits! *DUW* *WW* Dom Mustang Audio & Video 75 02-01-2004 07:11 PM
12:54 PM
