2002 mustang gt bushing question ? - Mustang Evolution
Old 01-24-2016, 01:00 PM   #1
smsstang's Avatar
I'm wanting to put new bushings on my car I had it on a lift the other day and noticed my front lower control arms bushings were pretty bad looking . I was wanting to know what bushings to get that are good for the job
smsstang is offline   Reply With Quote
Old 01-25-2016, 12:11 PM   #2
Just buy new a arms. They will have new bushings, new balljoints and it will be much easier.
If you still want to just do the bushings... Check out Rockauto or see if MM has any poly bushings that go in stock A arms. For balljoints get Steeda X2 units if you are doing them separately. You will need an alignment.
If you can still find a set, 03/04 Cobra a arms are the best oem ones.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 01-25-2016, 12:18 PM   #3
smsstang's Avatar
Okay probly gonna get just bushings and new ball joints unless the price between the two would be close .
Old 01-25-2016, 01:29 PM   #4
https://lmr.com/item/LRS-3079E-K/Mus...-Arm-Kit-94-04
You're going to have to pay a shop to press the new balljoints in if you don't have a press. I seriously doubt between bushings and balljoints and the labor and having to do the bushings yourself it'll be any easier than just getting a refurb'd set like this.
Old 01-25-2016, 02:22 PM   #5
smsstang's Avatar
Yeah your right on that one ! And there not really that bad in price probly just gonna go do that then . Thanks Scotty
Old 01-26-2016, 12:51 PM   #6
Hellish Horse's Avatar
Lower Control Arm Bushings are a B**** to change. I did it on my 04. You have to use an Air Hammer to get them out & a Ball Joint Press to get them back in. Took the whole day to do it.
You're much better off if you change out the whole control arm. Just a heads up on what you're getting into.
Hellish Horse is offline   Reply With Quote
Old 01-26-2016, 12:59 PM   #7
smsstang's Avatar
Thank you and yes I have decided I'm gonna buy whole new arms
Old 01-26-2016, 01:29 PM   #8
Rockauto also has the Moog units for $78 each.
More Information for MOOG RK620900
More Information for MOOG RK620899
You have to pay shipping but with 5% off using the code in the general forum (just google "rockauto discount mustangevolution") it is probably still going to be cheaper even with $25-$30 shipping.
Moog is a really good brand in case you are not aware.
That said, the LRS ones would be fine too if you already got them.
Old 01-26-2016, 01:55 PM   #9
smsstang's Avatar
Ok let me check it out ! Thank you sir
2002 mustang
UCA bushing replacement + Steeda trans bushing install Voltwings 2011-2014 V6 Mustang 0 10-11-2015 05:09 PM
Bushing question jake01roushv6 Pre-2005 V6 Mustang 1 04-01-2015 08:45 PM
Whiteline bushing question Jstorm 2011-2014 Mustang GT 10 03-08-2015 07:56 PM
Porthane shifter bushing question Pat12p 2005-2010 Mustang GT 2 01-02-2014 01:04 AM
2002 mustang gt vs 2002 eclipse gt? diwali General Car Discussion 3 08-22-2009 05:58 AM
05:16 PM
