Compression tested - Mustang Evolution
Old 01-24-2016, 05:18 PM   #1
XSlashDashX's Avatar
Compression tested
So as many of y'all know my timing chain was rattling and making noises. Got it fixed and at the last moment heard a very loud pop noise. Figured hey new engine time. No, not yet. Spark plug from cylinder 3 i believe blew out causing popping noise. But no check engine light other then MAF sensor. Did a compression checked and cylinder 3 was at 60. Tested again and bump to 125 then again at 80. All other cylinder range from 180 to 200. So is my rings bad or valves? Or could it be a head gasket issue? I have been white smoking a lot since I had the car but no coolant loss? Cylinder 4 spark plug was moist but didn't smell like coolant.
Old 01-24-2016, 05:19 PM   #2
The spark plug that blew out.
Old 01-24-2016, 05:21 PM   #3
The only 2 spark plugs that were bad. The broken one is obviously the one that blew out and the dark one is from the cylinder with low compression. I have no idea if my car is tune or not. Been running 87 octane. Any detonation issue?
Old 01-24-2016, 05:21 PM   #4
Also this plug. Where does it go? It's been unplugged since I ve had the car
Old 01-24-2016, 05:23 PM   #5
Different view from the low compression plug.
Old 01-24-2016, 05:24 PM   #6
Just a reminder. Car is 04 GT 5 speed with 103k miles. Before I had the chain and tensions replaced it ran like a beast. Pulled hard and ran great. Only mods are cams slp long tubes and catless x pipe wield in 40s. And msd coils. Which are horrible by the way.
Old 01-24-2016, 07:13 PM   #7
oxfordwhite's Avatar
First thing that concerns me is where did the rest of that spark plug go with that missing electrode? Also, if that's the one with low compression, the looks of it says a lot. Nothing good I'm afraid.
oxfordwhite is offline   Reply With Quote
Old 01-24-2016, 09:52 PM   #8
It all came off with the MSD Coil pack. As soon as I pulled the Spark Plug and the Coil apart it shattered.
Tested a gt Villero1834 2011-2014 Mustang GT 85 09-20-2012 09:06 AM
Tested for SSGT just now USAF_stang The Bar 2 07-31-2011 01:43 PM
MM&FF (Muscle Mustangs & Fast Fords) V6 Bolt Ons Power Parts Tested Seph Pre-2005 V6 Mustang 22 05-28-2004 02:22 PM
tested my MM lca's today tire The Bar 7 03-20-2004 05:03 AM
Cryogenic Air Intake Dyno Tested Dan The Bar 14 11-20-2003 09:27 AM
12:14 PM
