Best spark plug ? - Mustang Evolution
Old 01-28-2016, 06:17 PM   #1
alecas447's Avatar
Best spark plug ?
Sup guys just changed the cracked manifold and got 8 new MSD coils but the car is still misfiring. In planning on replacing all plugs. What's the best bang for buck for spark plugs? Does the price difference really matter? Just looking to get rid of the misfires . Thanks in advance!
Mac o/r H pipe. Flow master super 44s. Accufab 70mm throttle body. Pro comp intake manifold. MSD coils
alecas447 is offline   Reply With Quote
Old 01-28-2016, 06:38 PM   #2
oxfordwhite's Avatar
Uh-oh, I bet somebody says something about those MSD COP's
oxfordwhite is offline   Reply With Quote
Old 01-28-2016, 06:46 PM   #3
natestang07's Avatar
Might Suddenly Die?
Old 01-28-2016, 06:48 PM   #4
alecas447's Avatar
I kept my stock coils. Just need some suggestions for plugs
Old 01-28-2016, 07:24 PM   #5
Bgrimes1's Avatar
I would go with iridium plugs. Last longer and better spark
04 GT
Bgrimes1 is offline   Reply With Quote
Old 01-28-2016, 08:36 PM   #6
jeno's Avatar
Just go with OEM plugs and maybe you misfire might be those msd coils
Sent from my Nexus 6 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 01-28-2016, 08:52 PM   #7
Ubnbit's Avatar
Motorcraft
Old 01-28-2016, 09:10 PM   #8
04 GT
Last longer yes, better spark no.
Copper will give you the best spark.
Alecas, just get some copper autolite 104s from Rockauto for $1 each. Change every 30k miles and you can also read coppers when you pull them. Plugs take like an hour max to change anyway on a 2V.
2000 Mustang GT Steeda #0048
Old 01-28-2016, 09:34 PM   #9
alecas447's Avatar
Best spark plug ?
Read coppers? I'm good on time just want to do it right. I'm hearing mixed on the whole iridium vs copper vs platinum
---------- Post added at 11:34 PM ---------- Previous post was at 11:33 PM ----------
Good one but the misfires were there before I put the new coils in
Old 01-28-2016, 10:42 PM   #10
jeno's Avatar
When you put the coils in did you change the coil boots and springs
Old 01-28-2016, 10:52 PM   #11
alecas447's Avatar
Yea everything new except plugs
Old 01-28-2016, 11:18 PM   #12
XSlashDashX's Avatar
Go with Autolite 103s 👍
Old 01-28-2016, 11:20 PM   #13
103s are one range cooler than stock just FYI.
Old 01-28-2016, 11:27 PM   #14
alecas447's Avatar
Copper or platinum?
Old 01-28-2016, 11:28 PM   #15
Both. Stock is 104.
Old 01-28-2016, 11:35 PM   #16
alecas447's Avatar
Also the car hasn't thrown any misfire codes which is why I don't think it's the spark plugs
Old 01-29-2016, 12:21 AM   #17
JOberlander's Avatar
There's a reason they use copper in electrical wires. After it gets out of the smelters and is made into ingots, it is 99.99% pure. This is the same copper that's made into literally everything and virually all alloys use. It's also inexpensive.
The different types of plugs are mostly marketing. Save your money.
JOberlander is offline   Reply With Quote
Old 01-29-2016, 12:23 AM   #18
I use NGK V power, the $20 for 8 ones. I killed 3 Autolite Platinums before changing to the NGK and have not had a single issue since.
Old 01-29-2016, 12:27 AM   #19
alecas447's Avatar
Best spark plug ?
Is it possible for bad plugs to misfire without throwing any check engine lighter codes ?
Old 01-29-2016, 01:20 AM   #20
jeno's Avatar
Yes same for coil packs can have a misfire without codes
Old 01-29-2016, 01:21 AM   #21
jeno's Avatar
Had a misfire for a while on mine
without any codes ended up being a bad coilboot
Old 01-29-2016, 05:55 AM   #22
fenixignition's Avatar
i also have the v powers in my car. no complaints. very inexpensive. that would be your bang for your buck. i havent tried the irridiums myself. didnt want to invest higher than 5 bucks a plug for 8 cylinders just to find out if theres a difference. from my understanding of them, the metal just erodes less and lasts longer.
2002 GT 5sp. 16x,xxx miles
Old 01-29-2016, 08:22 AM   #23
Correct. Doesn't the engine run better with a cooler range?
Old 01-29-2016, 08:43 AM   #24
It runs better at what it is spec'd for. It's when you mod it or add boost that you change the heat range usually
Sent from my SM-G920V using Mustang Evolution mobile app
Old 01-29-2016, 09:05 AM   #25
alecas447's Avatar
Right now I'm down to 103s vs ngk v power
Old 01-29-2016, 09:25 AM   #26
torchdNblazen03's Avatar
Just had to replace my intake manifold as well, They used the 104's and my car runs so much smoother and pulls a lot harder now.. All misfires are gone now and just seems to run a lot better..
torchdNblazen03 is offline   Reply With Quote
Old 01-29-2016, 09:39 AM   #27
alecas447's Avatar
Copper?
Old 01-29-2016, 11:09 AM   #28
alecas447's Avatar
No 103s or ngk v at my local auto parts. I went with 104s
Old 01-29-2016, 12:19 PM   #29
I don't think you'll be disappointed
Old 01-29-2016, 12:38 PM   #30
alecas447's Avatar
Does the fuel rail have to be removed ? Becuase one plug is giving me headache to remove
Old 01-29-2016, 12:39 PM   #31
I've been using autolite for literally 15 years in everything I own. Zero issues ever and the price is right, not changing unless they give me a good reason. Going with the $1 per plug coppers for the Steeda as well. All the plat/iridium stuff is gimmicky. It does last longer than copper but you can read copper plugs and plugs on a 2V take an hour to do max. 1 hour and $8 every 30k miles is not an issue. If it is... Lease.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 01-29-2016, 12:45 PM   #32
ngk
newedge01 is offline   Reply With Quote
Old 01-29-2016, 12:58 PM   #33
Motorcraft for me. Never had an issue with them. Run Motorcraft in my old 50 pan also. I had a set in the pan for 15 years. That's right, I said 15 yrs, cause every-time I pulled them to check or replace they looked new. So I decided to see how long they would go. Finally changed em just cause. I still carry those in my saddle bags for spares. I know they are gonna work if I have trouble.
Old 01-29-2016, 01:32 PM   #34
Always been a motorcraft person. 40k on them still running well. Probably will change them before my smog check
Sent from my LG-H634 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 01-29-2016, 02:16 PM   #35
alecas447's Avatar
Auto lite 104s for $17. Just finished no misfires... For now
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 09:42 AM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 10:45 AM
Best choice for spark plug (ignition) wires? Akiiki General Mustang Discussion 10 04-03-2010 10:13 PM
Spark Plug Wires Shahrum Pre-2005 V6 Mustang 10 02-05-2004 11:09 AM
Spark plug change Rellik The Bar 7 08-20-2003 07:04 PM
12:34 AM
