Check engine light codes - Mustang Evolution
Old 02-02-2016, 04:53 PM   #1
P0453, P0403, P0113 those are the codes that I remember from check it with a scanner there like 9 of them. I have a 04 Mustang gt. Could I have a bad EGR?
Lainez1217 is offline   Reply With Quote
Old 02-03-2016, 10:21 PM   #2
It would be helpful to know all of the codes, but multiple trouble codes can be indicative of an electrical problem with the PCM. Such as a corroded connection at the PCM, wiring problem, or a failed PCM.
Old 02-04-2016, 04:55 PM   #3
try using www.obdcodes.com for help
captchas is offline   Reply With Quote
check engine
Check engine light codes, Misfire & ignition coil. BeasGT 1996-2004 Mustang GT 5 06-01-2013 02:00 PM
Check engine light-codes P2197,P2195 The Darkside Pre-2005 V6 Mustang 35 12-11-2008 10:12 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
05:34 AM
