Well 3rd gear just started grinding - Mustang Evolution
Old 02-03-2016, 09:29 PM   #1
alecas447's Avatar
Shifting from 2nd to 3rd is grinds kinda bad. Probably a such to?
Mac o/r H pipe. Flow master super 44s. Accufab 70mm throttle body. Pro comp intake manifold. MSD coils
alecas447 is offline   Reply With Quote
Old 02-03-2016, 10:11 PM   #2
Does it grind even when shifting at "normal" RPM's?
And I assume that you have done the drain/refill with 3.2 quarts of synthetic transmission fluid?
Old 02-03-2016, 10:30 PM   #3
alecas447's Avatar
Only when shifting at high Rpms it does it. And yea about ~10k miles ago
Old 02-04-2016, 04:22 AM   #4
Strange Mud's Avatar
sorry
Old 02-04-2016, 06:44 AM   #5
Classic 3650 shift fork issue. Rebuild with all the TSBs done or get a new one. You can get a brand newly rebuilt one to your door for $1400 including the core charge.
Old 02-04-2016, 04:35 PM   #6
fenixignition's Avatar
stock shifter?
2002 GT 5sp. 16x,xxx miles
Old 02-04-2016, 04:55 PM   #7
alecas447's Avatar
Originally Posted by fenixignition View Post
stock shifter?
Yeap. Why?
3v, 05, 3rd gear grinding 05pegasus 2005-2010 Mustang GT 0 10-10-2014 12:45 AM
3rd gear grinding Kstangs2002 1996-2004 Mustang GT 8 02-02-2013 04:07 PM
Help! 1st gear issue / 5th gear grinding Missxalii General Mustang Discussion 2 06-06-2012 01:18 PM
Grinding into 3rd gear tedness 1996-2004 Mustang GT 9 01-19-2010 06:32 AM
Well well well England, you are turning into the country of the FATTIES Seph The Bar 10 02-28-2007 04:10 PM
06:36 AM
