Bent wheel - Mustang Evolution
Old 02-06-2016, 03:00 PM   #1
alecas447's Avatar
Bent wheel
So just noticed this on my drivers side front wheel. Tire has less air than the rest and looks pretty bad. Time for a new rim?Click image for larger version
Name:	ImageUploadedByMustang Evolution1454796025.227752.jpg
Mac o/r H pipe. Flow master super 44s. Accufab 70mm throttle body. Pro comp intake manifold. MSD coils
alecas447 is offline   Reply With Quote
Old 02-06-2016, 04:06 PM   #2
BLKBETTY13's Avatar
Bent wheel
You can try a block of wood and a hammer. Should take most of it out.
It'll buy some time anyway...
BLKBETTY13 is offline   Reply With Quote
Old 02-06-2016, 04:41 PM   #3
A wheel and drive line shop should be able to fix that very easily. The rim is not cracked is it?
Old 02-06-2016, 05:25 PM   #4
alecas447's Avatar
No the rim isn't cracked
Old 02-06-2016, 06:26 PM   #5
jeno's Avatar
Have it repaired it's not that bad
Sent from my SAMSUNG-SM-G928A using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 02-06-2016, 06:34 PM   #6
kona010's Avatar
How do you not recall hitting something that hard? That doesn't just happen by itself.
kona010 is offline   Reply With Quote
Old 02-06-2016, 06:37 PM   #7
alecas447's Avatar
Most likely a pothole the other day
Old 02-06-2016, 08:10 PM   #8
Have you checked to see what the damage on the inside of the wheel is as well? The outside may just be the best side............
Old 02-06-2016, 11:12 PM   #9
Steve96's Avatar
Getting it repaired can sometimes be as costly as ordering a new wheel in my experience. But mine was an alloy wheel. Try bending it out yourself if its not cracked and order a new wheel IMO. Discount Tire here in MI has fixed steel wheels for me before, they bang them straight. But you can still tell they were damaged, may not bother you though. Didnt you get the wheels over this past summer?
1996 GT
Old 02-07-2016, 07:43 AM   #10
alecas447's Avatar
Yea I got them 7 months ago
Old 02-07-2016, 08:18 AM   #11
fwalck's Avatar
It will probably be cheaper to just buy a new wheel. With it being on the outside the wheel will probably have to be refinished because they would have to heat the wheel to get the bend out and it will mess up the finish. I was looking into refinish a wheel and it was cheaper to just replace the wheel.
fwalck is offline   Reply With Quote
Old 02-07-2016, 10:37 AM   #12
alecas447's Avatar
I took it some place yesterday before work last night and they used a hammer . Looks a lot better I'll upload some pics in a bit
Old 02-07-2016, 12:32 PM   #13
alecas447's Avatar
Name:	ImageUploadedByMustang Evolution1454873496.688403.jpg
ID:	196744Click image for larger version
Name:	ImageUploadedByMustang Evolution1454873511.508420.jpg
This is how it is now
Old 02-07-2016, 02:27 PM   #14
jeno's Avatar
Not perfect but way better
Old 02-07-2016, 08:04 PM   #15
alecas447's Avatar
You think it's risky
Old 02-07-2016, 08:38 PM   #16
jeno's Avatar
Well you got it rebalanced right ? Holds air then your ok
Old 02-07-2016, 08:58 PM   #17
Steve96's Avatar
Looks better than I thought it would. Good ole precision instrument....HAMMER!
1996 GT
Old 02-07-2016, 09:42 PM   #18
alecas447's Avatar
Holds air haven't rebalanced it
Bent lip twotone01 Mustang Wheels & Tires 3 07-05-2012 06:02 AM
Looking for pre-bent brake kit Jake walking to 1979-1995 Mustang GT 1 03-19-2012 01:06 PM
Bought with bent axle..and intro Bryangb7 1996-2004 Mustang GT 1 12-12-2011 04:31 AM
Bent rims?? Stang02seth Mustang Wheels & Tires 19 02-19-2011 03:41 PM
Why Bent Exhaust Valves? jwyche 1979-1995 Mustang GT 5 03-17-2007 07:59 AM
02:10 PM
