Cams, cams, cams... - Mustang Evolution
Old 02-08-2016, 09:12 AM   #1
Region: New Hampshire
Send a message via AIM to ChaudMasterFlex Send a message via Yahoo to ChaudMasterFlex
Cams, cams, cams...
So after perusing the forums for the last few days I still can't decide which cams to go with. I have a 2003 GT 5spd with 83k miles. It's N/A, and I plan on keeping it that way. The only mods are; an Airraid intake, underdrive pulleys, Accufab 70mm throttle body and plenum, and an SLP exhaust. I've been seeing people mention Cushman and Modular Motorsports? I don't take the car to the track and put around 5k miles on it a year. I really like that "lopey" cam sound, and I would like to get as much power out of them as I can without sacrificing reliability and piston clearance. Also, will I need to purchase adjustable cam gears? So any suggestions would be greatly appreciated, thanks.
ChaudMasterFlex is offline   Reply With Quote
Old 02-08-2016, 09:44 AM   #2
Steve96's Avatar
Cushman Motorsports like you mentioned work very well on the 2v. Ive seen a lot of guys use their stage 2 cams on a stock 4.6 2v. There are also a lot who use Comp Cams stage 1 and 2. You can get the "lopey" idle youre wanting by just going with a stage 1 cam set up though. Supposedly you can use most "stage 1" cams with stock valve springs but I would probably just replace them anyway if it was me. Most of them you wont lose driveability along as you dont go too big. You will need a tune right away. Many will say the gains arent worth the money especially if not doing the install DIY. But Im like you, I long for that lope! MHS uses Bullit cams and Ive heard good things about them too.
---------- Post added at 11:44 AM ---------- Previous post was at 11:43 AM ----------
If degreed properly you shouldnt have any PTV issues either, but will have to shell out more money for a degree service.
1996 GT
Old 02-08-2016, 09:47 AM   #3
Thanks, from what I've read I'd be an idiot if I chose not to have them "degreed."
Old 02-08-2016, 10:06 AM   #4
Slater2111's Avatar
Yup get the degree service. Cushman stage 1 are your best bet and will give you a nice bump in power. There's the least amount of risk with a degree service and stage 1 should just drop right in.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
For Sale: Used Comp Cams Xtreme Energy Stage 1 Cams(96-04 4.6 2V) fasternu_674 Mustang Parts for Sale and Wanted 2 12-04-2015 08:23 AM
4.6l Cams Black00GT 1996-2004 Mustang GT 14 11-17-2008 08:19 AM
Cams and drag racing... Exit_In_Red Pre-2005 V6 Mustang 7 02-07-2005 03:51 PM
Mustang Cams ttpancakes Pre-2005 V6 Mustang 48 08-07-2004 12:38 PM
explanation of 1.73/1.8rr's with/without custom cams? tire Pre-2005 V6 Mustang 5 12-29-2003 10:18 AM
02:05 PM
