License plate light issue - Mustang Evolution
Old 02-08-2016, 06:39 PM   #1
superdrift's Avatar
It wont turn on, the bulbs were shot the socket was a little burnt, and even after replacing the bulbs with lmr leds they wouldnt come on. How do i fix this?
superdrift is offline   Reply With Quote
Old 02-08-2016, 07:32 PM   #2
BLKBETTY13's Avatar
Any corrosion?
Try to clean up the contacts.
BLKBETTY13 is offline   Reply With Quote
Old 02-08-2016, 07:37 PM   #3
superdrift's Avatar
Originally Posted by BLKBETTY13 View Post
Any corrosion?
Maybe, how do i clean it?
Old 02-08-2016, 08:07 PM   #4
BLKBETTY13's Avatar
I'd say to look in the socket and see if there is corrosion. If so you can try some electronics cleaner. Hobby stores should have it as well as other places. Even battery terminal cleaner from parts store should work. May have to use small scrap piece of wire to scrape/loosen any corrosion or debris. Repeat the process until it appears clean. Disconnect your negative battery terminal before doing this!
Old 02-08-2016, 08:13 PM   #5
superdrift's Avatar
Well ima try that, also is there any wiring or something that isnt on the trunk that would cause it not to work? Every light works except for the plate
Old 02-08-2016, 08:13 PM   #6
BLKBETTY13's Avatar
Also make sure the socket is dry and add a dab of dielectric grease before installing your new bulbs.
Old 02-08-2016, 08:16 PM   #7
BLKBETTY13's Avatar
If its corroded then my guess is that's your problem. It may have worked itself into the wiring itself but it don't hurt to try cleaning them up 1st. Go from there....
Old 02-08-2016, 08:25 PM   #8
superdrift's Avatar
Yeah the housings were cracked and painted over by the previous owner, im also gonna see if any of the wiring behind the side carpet thing came loose
Old 02-08-2016, 10:52 PM   #9
NewMtang's Avatar
Or.....make the wife sit in the trunk with a flashlight.
Old 02-09-2016, 05:27 AM   #10
superdrift's Avatar
Dang that would be great...... if i had one 😭😭😭😭😭😂😂😂😂
Old 02-09-2016, 02:49 PM   #11
rear License plate light?
Hi, Want me to drop my wife off there!! Any how,a small piece of emery or sand paper will work nice to clean it up. Check your fuses, someone could have put a larger size fuse in there. good luck
goman is offline   Reply With Quote
Old 02-09-2016, 03:56 PM   #12
superdrift's Avatar
All my fuses were ok and looked normal, and i havent had the time yet lol
Old 02-09-2016, 10:17 PM   #13
NewMtang's Avatar
All you need now is a flashlight!
Old 02-11-2016, 11:48 AM   #14
superdrift's Avatar
I cleaned them and used the grease and got my passenger side to work
License Plate Light Housing Replacement aleXXXps General Mustang Discussion 1 06-18-2015 07:14 PM
LED License Plate Lights and Trunk Light Rubenfran26 Pre-2005 V6 Mustang 3 05-09-2015 02:58 PM
Third brake light and license plate light problems bkh1994 Pre-2005 V6 Mustang 20 09-05-2013 08:34 PM
License plate light question Jareds65 Classic Mustangs 4 08-19-2011 05:47 AM
License plate Falcon The Bar 3 11-09-2003 11:34 AM
07:01 PM
