Trick flow valve covers - Mustang Evolution
Old 02-15-2016, 02:36 PM   #1
XSlashDashX's Avatar
What are y'alls thought on the 2v valve covers? My stockers has a crack so I plan to just go ahead and replace them.
Old 02-15-2016, 03:56 PM   #2
They look nice. I have a friend with some.
Old 02-15-2016, 06:54 PM   #3
keeney35's Avatar
That's what I'm getting for mine for my build, just to make the engine all nice and pretty lol
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
---------- Post added at 07:54 PM ---------- Previous post was at 07:54 PM ----------
Make sure you order the right bolt covers tho, 11 bolt is a Romeo block 13 is Windsor
keeney35 is offline   Reply With Quote
Old 02-17-2016, 11:09 AM   #4
Right, probably not going with the black covers though.
Old 02-18-2016, 06:55 AM   #5
I had them on the 98. They're valve covers... not sure what else there is to say about them. Will not be getting them for the 2000 because the stockers work just fine.
Old 02-18-2016, 08:26 AM   #6
I've read on other forums people had problem with them leaking. Plus my stocker is cracked. Might as well go with new covers. None of the junk yards in my area has 4.6 covers.
Old 02-18-2016, 01:10 PM   #7
Had that 98 for 3 years, never one oil leak. They were installed with new hardware and new gaskets.
Old 02-18-2016, 01:45 PM   #8
Sounds good. Ordered the silver coated covers. Waiting for the head to come back from the machine shop and should be good to go. I have all new fel pro gaskets.
Old 02-19-2016, 05:59 PM   #9
Just got my valve covers in and I was going through the instructions and ended with this.
"Due to the location of the PCV valve and the oiling system in the 4.6L heads, oil is consumed and discharged through the PCV valve. The factory system vents these vapors and residual oil back into the intake and may lead to detonation and oil deposits in the intake track and on the valves. This problem is inherent to a stock 4.6L engine, but can be made worse depending on the modifications made to the stock engine, including the installation of these valve covers. TrickFlow highly recommends running an air-oil separator or catch can between the PCV valve and the vacuum source to help eliminate this issue."
Do I need a catch can? I only have a few bolt ons.
Will 98 cobra valve cover screw fit on 04 cobra valve covers??? Xplicitstangs General Car Discussion 0 01-29-2016 11:49 PM
331 with trick flow top end kit or stock 302 with the truck flow h/c/i kit Muller 1979-1995 Mustang GT 6 10-23-2013 07:28 AM
Trick flow top end kit 01 PR RAGTOP 1996-2004 Mustang GT 6 04-19-2010 05:17 PM
Trick Flow Stage 2 clearance joseandmarilyn 1979-1995 Mustang GT 0 04-14-2008 02:00 AM
trick flow valve covers?? bluestang1724 1979-1995 Mustang GT 7 10-01-2007 08:04 AM
08:57 AM
