Opinion on what to do - Mustang Evolution
Old 02-16-2016, 01:19 AM   #1
xrsfx's Avatar
I am at a stock height with the ugliest wheels. I am planning to build the car up to pushing boost. But I don't know where to start. I have a friend that is associated with steeda & is offering me a discount on steeda suspension package stage 1. I also have the worst wheels. I was thinking about just getting the 18" staggered wheel set from AM with nitto tires. Should I get wheels first or the suspension package? Or just focus on performance mods ?
If anyone knows a website that offers a good wheel kit or even some better tires ? I was thinking about going 1 inch spacers & run 275 or 285 on the back & 255 in the front
xrsfx is offline   Reply With Quote
Old 02-16-2016, 01:23 AM   #2
xrsfx's Avatar
Suspension package comes with steeda sport springs for 1 1/4 inch drop, camber plates, strut tower brace & a g bar
Old 02-16-2016, 05:16 AM   #3
Mile high JDF's Avatar
Personally, I would skip the strut tower brace and the rear shock tower bar. Instead I would do full length subframe connectors.
What sort of driving do you plan on doing (Road course, drag strip etc)? Do you prefer to have the car looking good first or would you rather have it perform better first?
Ride height is all personal opinion, I love a really low car so those Steeda springs wouldn't really do it for me.
Do you plan on doing the spacers with the new wheels? Most aftermarket wheels will have an aggressive enough offset to not need spacers unless you plan on going flush. I would go with an 18X9 and 18X10 staggered setup with some 255s up front and 295s in rear. If ordering through AM I would spring for the Mickey Thompsons instead of the Nittos.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-16-2016, 08:24 AM   #4
xrsfx's Avatar
I do plan on getting the MM subframe connector. So I was thinking getting that with the eibach springs that drop 1.7 on the back & 1.5 in the front. This is my daily so I never really wanted it that low. Yeah I plan on using the spacer with the new wheels.
On my old v6 I had it perform better rather than look better. I don't know if I want to do that again.
Old 02-16-2016, 09:17 AM   #5
fomoco4life's Avatar
Wheels are always a good first mod, as u benefit visually immediately. I'd do them first, you'll be happier with the look of ur car. I'm loving the 1" spacers out back as well, I'd u go staggered however, u shouldn't need them
Old 02-16-2016, 10:07 AM   #6
BLKBETTY13's Avatar
I say suspension 1st for sure. Your car will look and handle better. New wheels may not impress in 4X4 mode yet a good suspension setup gives you appearance and performance.
Just my suggestion but I'm one that puts icing on after the cake is done.
BLKBETTY13 is offline   Reply With Quote
Old 02-16-2016, 01:39 PM   #7
xrsfx's Avatar
I think you're right. I think I'm going to get the wheels first then see how they fit too see if I want a spacer or not
Old 02-16-2016, 01:49 PM   #8
I vote suspension. Simply because the suspension will improve handling performance regardless of wheels on the car. Also it will force you to get your geometry correct after lowering/altering your suspension.
Then when you do invest in some more expensive rubber, you won't have a half ****d setup wearing down tires every 5k miles.
Old 02-16-2016, 02:43 PM   #9
xrsfx's Avatar
Do you think I should go with the steeda package or eibach with a MM subframe connector ?
Old 02-16-2016, 02:51 PM   #10
i did suspension first.do your tires really look that bad or could you plasti dip the wheels for now,or do you not like the style of wheel you have? i have a 5 spoke cobra style wheel that i did in black.they look pretty damn good for now. wheels replicas has some nice wheels and tires you should check out and steeda is an outstanding product but i went with h&r lowering springs and to me it gave my newedge the perfect stance. inch and a half all around but the car does have a couple steeda parts installed. cant go wrong with steeda no matter what it is.
newedge01 is offline   Reply With Quote
Old 02-16-2016, 03:23 PM   #11
I am not a huge fan of Eibach, just too many inconsistencies with their products. I rarely hear about Steeda, Maximum Motorsports or H&R having major product issues, which is why I only use them on my cars, and most importantly, they perform.
What is nice about packages like the Steeda one you listed is that all the components are meant to work well with each other. I believe Maximum Motorsports offers a similar package with their products.
If you are looking for a moderate drop 1-1.5", go with the Steeda package. This is probably better for a daily driver. Depending on mileage and condition, it might be worth it to upgrade shocks/struts too.
If you are wanting a more aggressive drop ~1.5-2" using drop springs, not coilovers, get H&R Super Sports, Maximum Motorsports 4 bolt Caster Camber plates, ideally Bilstein HD's, but they are pricey, so at a minimum Koni STR.T's, Steeda X2 ball joints, and a bumpsteer kit. Then add in the tower braces and subframe connectors.
Old 02-19-2016, 11:01 AM   #12
TheJigShow's Avatar
+1 with the H&R springs. I had them on my old car along with Bilsteins and the Maximum Motorsports caster camber plates and it handled great. I didn't think it was too harsh, but it was so much fun taking corners. I sold my old car but made sure I kept those parts for the next one
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
Old 02-19-2016, 11:03 AM   #13
Famine's Avatar
Region: South Dakota
I would do suspension first if it were me. Functional and to me if you have nice wheels and 4wheeler wheel gap, it just looks terrible.
Famine is offline   Reply With Quote
Old 02-20-2016, 11:30 AM   #14
it would be best to model your suspension after what you will actually be using the vehicle for that way it works best for you
what are your goals with the car?
decipha is offline   Reply With Quote
Old 02-20-2016, 01:01 PM   #15
xrsfx's Avatar
This is my daily + my project car. I drive about 10 miles front & back everyday. Weekends I attend meets & do photo shoots, I'm an automotive photographer. I'm planning to do bolt on mods for now & a full suspension. After that is all set up I'm going to try to run turbo.
will everyone give me there opinion and maybe some pics? Blue232 Mustang Audio & Video 9 02-26-2004 06:34 PM
So whats everyones opinion on this? Brent The Bar 42 02-15-2004 07:53 PM
Need an opinion n8r The Bar 23 01-29-2004 03:01 PM
Your opinion wanted :) Brent Mustang Audio & Video 6 12-03-2003 11:59 AM
Opinion on rims wiarumas Mustang Audio & Video 19 11-14-2003 02:46 PM
03:44 PM
