Bolt on HP - Mustang Evolution
Old 02-16-2016, 09:04 PM   #1
Ddejesus523's Avatar
Bolt on HP
I have an 04 GT and what was wondering what RWHP I would be at with the following mods. TIA
LT headers
O/R x pipe
Mac exhaust
78mm TB
TB spacer
Accel super coils
BBK CAI
Steeds UDP
24lb injectors
4:10 gears
And the race tune from Bama
Ddejesus523 is offline   Reply With Quote
Old 02-16-2016, 09:17 PM   #2
Steve96's Avatar
Most with full bolt ons that you listed with a good dyno tune around 248-255hp depending on the dyno at the rear wheels.
Dont waste your money on the CAI, the stock one is good or better than the metal BBK, if you want to get the better CAI get a JLT, even then I would save my money. Put the money you save from the CAI towards a upper intake plenum, get the Summit tb/plenum combo made by Trickflow, best deal. Also forget the intake spacer and the Accel coils they wont add anything, if anything those coils can cause issues. If you need new coils get OEM or rebuild the springs and boots for cheap.
Anyway, I would not buy the intake spacer, CAI, or the Accel coils. Thats a little bit of coin to save if you add all of them up. The UDPs you mentioned are also something I would probably skip on too some say they net you a few HP from the accessorie drain but its less than 2-3 HP from what Ive seen in real life. Get the tb/plenum from Summit instead. Get a tune from MPT or somewhere that data logs and gives you a true custom tune if not doing it local on an actual dyno.
The 410 gears are a great addition and probably the one you feel the most seat of your pants improvement and they dont add any HP.
If you want the CAI, pullies, spacer for some under hood bling for shows etc then thats up to you but Id skip on them if your after HP.
Using this forum and others Im glad I learned about what works and what doesnt so I didnt waste any money. Is your car a stick? If so get a Steeda Triax or MGW shifter. Then work on suspension when you're done with your bolt ons, full length welded in sub frames, rear lower control arms, lowering springs, and a good set of wheels and tires.
1996 GT
Old 02-16-2016, 09:20 PM   #3
keeney35's Avatar
Maybe 290, but probably closer to the 275 range
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 02-16-2016, 09:21 PM   #4
Ok sweet thanks for the input as far as suspension. I've already lowered it, strut tower brace, shock tower brace, rear upper and lower control arms, subframe connectors and I'm running the factory cobra wheels wrapped in 275/40/17 all the way around
Old 02-16-2016, 09:22 PM   #5
keeney35's Avatar
I was full bolt on, cammed and such. With the mods in my sig I broke 300 but if you want anything more your going to need a power adder
Old 02-16-2016, 09:31 PM   #6
Steve96's Avatar
You have suspension taken care of sounds like. Id be careful with the upper control arms in the rear depending on how hard you launch. 290 is pretty high to the wheels without changing the cams, with bolt ons and cams with a good dyno tune you can see 290-310ish rwhp from what Ive seen anyway, Im sure every set up can be diff or how aggressive the tune is etc.
1996 GT
Old 02-16-2016, 09:43 PM   #7
I would love to see 275-280 with those bolt ons.. And it would probably be just over 300 in tq I'm assuming?
Old 02-16-2016, 10:15 PM   #8
I had SR CAI, BBK 78mm TB, stock coils, stock injectors, SR Pulleys then but steeda pulleys now, no headers but SLP catted X pipe and LM1 catback, Bama 93 octane custom tunes (used the race tune) and put down 255rwhp and 290tq. You should look at 270rwhp+ and around 300tq.
lyonschoice is offline   Reply With Quote
Old 02-18-2016, 06:41 AM   #9
I'm burnt out on typing corrections to lists like the OP posted. Steve pretty much nailed it. If he wants to waste all his money he can get all that stuff. PPl need to actually do research. Car comes stock with #21 injectors (example) and even #19s would be fine. 24s are a complete waste of his money.
To keep it short and sweet for the original poster. There is very little you can do power wise besides exhaust before you have to get into the internals of the motor. Almost nothing you listed will do anything.
Full bolt on/tune PI car is about 250rwhp.
Old 02-18-2016, 06:58 AM   #10
Thanks for the input. I've just come across so many inputs from different people but you guys sum it up. Gonna have to do cams if I wanna see any actual power
Old 02-18-2016, 07:00 AM   #11
You do cams and you'll still get your doors pulled off by a bolt on F body and it'll cost a solid $1500-$2k if you have to pay for labor. Not to say its not a fun car in bolt on or cammed form but you will not be actually fast without a power adder.
Old 02-18-2016, 07:19 AM   #12
I've read that you build a SC for less than 2k (used Kenne bell) buying the parts separately. Would that be worth it in terms of money well spent?
Old 02-18-2016, 07:44 AM   #13
You can do the charger itself used as a whole kit for $1500 or so depending on where you get it from. But then you also need fuel and a tune and then the rest of the car needs to be able to handle the power.
Old 02-18-2016, 07:49 AM   #14
Ok, I'm going to do what Steve96 said and just save for a power added and do it right
Old 02-18-2016, 07:50 AM   #15
Do a mid pipe, catback, shifter and a tune. Then work on suspension and enjoy it.
Obviously do a tune up if you have not yet. New COP boots/springs, new plugs, fresh fluids etc...
Old 02-18-2016, 06:07 PM   #16
Steve96's Avatar
What I listed is what I basically plan for my 03. Nothing crazy for the time being. Once I get that stuff done including the suspension stuff and a Jmod (mine is an auto) much much further down the road, at least it seems Ill go FI or sell it and upgrade. At my current pace it will be 2020 and Ill be able to buy a used Coyote for 7-8k, lol. Ill always be a step behind, but it does not bother me to live within my means and have a nice poor mans "hot rod" to cruise around in and not feel like I sunk too much money in it or its a money pit. I dont care about being the fastest car on the road, if I can add a little power, make it sound good, look good, and run good I will be happy for now. If I wanted the fastest thing I wouldn't have got the 2 Mustangs I have, haha. Dont get me wrong I enjoy "fast" and making people look dumb by wasting them, and Ive had cars that were more in that category, but Im good for now. I enjoy these cars and for the most part they look really good when done right and you don't have to spend a ton
1996 GT
Old 04-02-2016, 08:15 AM   #17
phatspeed7x's Avatar
https://youtu.be/_M74OffhdB0
My dyno runs from last year on a stock tune and "bolt ons"
Sent from my LG-H900 using Tapatalk
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 04-04-2016, 10:23 AM   #18
XSlashDashX's Avatar
I'm sitting at LT, Cams, And a Throttle body lol. As long as I break 300 hp, I'll be happy with the little 2v.
Old 04-04-2016, 07:38 PM   #19
I ordered Cushman motorsports stage 1 na cams for my mustang. Those and a good tune I'm hoping will get me closer to 300rwhp.
Old 04-04-2016, 07:45 PM   #20
I said screw it and bought a whole ****load of 4V stuff...
Old 04-04-2016, 10:36 PM   #21
Steve96's Avatar
Hahaha you win, screw the 2V!
1996 GT
Old 04-04-2016, 10:38 PM   #22
Steve96's Avatar
You should be able to get damn close to 300 whp with that set up. "Full" bolt ons, cams, dyno tune you should hit it, if not be a little under. All dependent on your tuner at that point. Lucky!
1996 GT
Old 04-05-2016, 05:31 AM   #23
Cushman himself has said in the past on forums (and his site I think) that "my cams don't always make the best dyno numbers but will not be outperformed".
Old 04-05-2016, 10:16 AM   #24
Hopefully they ship soon. Still says order is waiting to be filled.
Old 04-05-2016, 06:44 PM   #25
Steve96's Avatar
Looking forward to that mod on yours. I want to do cams in one of my 2..just so much money since I don't have the know how to tackle something that large
1996 GT
Old 04-06-2016, 05:37 AM   #26
You can always do the HP292 cams. They are stock regrinds so you can send your cores off to be done and then drop them right back in as they came out. No spring change or anything and they sound amazing. Look up some vids on youtube.
Old 04-06-2016, 06:56 AM   #27
Steve96's Avatar
I will do that for sure. I didnt know about having this done until you mentioned it in your thread. Thanks as always for the info
1996 GT
Old 04-06-2016, 08:42 AM   #28
I'm just glad I didn't push purchase when I posted that I had bought everything. That was right when I started to kick around going 4V and I held off on the shopping cart.
Old 04-06-2016, 10:55 AM   #29
Cushman motorsports said it could be 3 weeks before my cams are done and ready to ship. Sounds like they are busy.
Old 04-06-2016, 01:05 PM   #30
This time of year coincides with all the buildups for the race season and also tax returns. The shop I'm having look at my heads and blocks has about a 2 week turnaround for all orders right now they are so backed up but they expect it to slow down drastically in mid May.
Old 04-07-2016, 10:24 AM   #31
Emailed them and requested to have my grind on the cams changed from stage 1 to stage 2. Also ordered a set of their aftermarket valve Springs since they say springs are required for the cams.
Old 04-07-2016, 11:26 AM   #32
Springs are a giant hooker on these cars just FYI. Especially with the motor in the car. I'm going to have the springs on the 4V heads done when they get gone though by the shop.
Old 04-07-2016, 11:27 AM   #33
Hooker?
Old 04-07-2016, 12:35 PM   #34
They're a whore. They suck. Blah...
Old 04-07-2016, 02:44 PM   #35
jeno's Avatar
He said giant hooker so 6 foot plus on the cheap lol
UPR X Pipe, UPR CAI, Ford Racing C Springs, Mach 1 grill delete, Chin Spoiler, Magnaflow exhaust, SCT 4 Bama Tuned
jeno is offline   Reply With Quote
Broken bolt on UCA mount (rear/passenger bolt). ... slimguns 2011-2014 Mustang GT 15 06-24-2015 09:09 AM
3 bolt or 4 bolt camber plates Venomouz831 Pre-2005 V6 Mustang 9 12-22-2011 01:34 AM
What is the bolt pattern/bolt circle on a 1978 mustang II? booth Classic Mustangs 1 12-14-2011 10:08 PM
wtt or sell 6 bolt aluminum flywheel for 8 bolt Everett Mustang Parts for Sale and Wanted 32 02-19-2011 09:22 PM
Bolt Ons ERICK Pre-2005 V6 Mustang 1 05-10-2003 11:22 PM
11:46 AM
