Where to get an alternator? - Mustang Evolution
Old 02-20-2016, 10:51 PM   #1
bkh1994's Avatar
I originally had a PA Performance alternator that crapped out on me, but I'm not the original buyer so no replacement from them. I needed a quick replacement so I got a remanufactured one from advance auto. The battery light started coming on occasionally after about a month then it came on more and more. So I replaced it under warranty Tuesday. Just now on the way home the battery light stayed lit so I am going to get another replacement again until I can get a good one shipped out here. So I'm looking for suggestions on what alternator to get and where to get it. Just a little info, I have an aftermarket head unit, mach 1000 system, 20 amp boost a pump, and a 2.1 kenne bell at 14 psi revving up to 6500
bkh1994 is offline   Reply With Quote
Old 02-22-2016, 02:28 PM   #2
Had to pick up an Ultima Altenator from orielys. 225 after the core. Works well. 1000watt amp powering a 12" sub and aftermarket head unit.
Sent from my LG-H634 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 02-22-2016, 06:54 PM   #3
If they keep frying on you are you sure there isn't a short in the system somewhere?
Sent from my LG-D801 using Mustang Evolution mobile app
2000 Mustang GT Steeda #0048
Old 02-22-2016, 07:02 PM   #4
keeney35's Avatar
^^^^. There's a reason they keep going out. Check your wiring, grounds, fuses, and relays
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 02-22-2016, 09:53 PM   #5
bkh1994's Avatar
I just assumed it was crappy replacements. I'll start checking it out
Old 02-22-2016, 10:31 PM   #6
keeney35's Avatar
I would, alternators aren't cheap, it would suck if it was one wire that was just shorted
Old 02-24-2016, 03:10 PM   #7
bkh1994's Avatar
Could a really tight belt cause them to keep failing? The belt is so tight that I have to push it on the supercharger pulley a rib at a time. Pushing on it doesn't flex it at all. I know it needs to be swapped out, I just ordered the next size up for it
Sent from my SPH-L710 using Mustang Evolution mobile app
Old 02-24-2016, 03:59 PM   #8
keeney35's Avatar
It should flex some, can't remember exactly how much tho
Battery or Alternator?? Justin 1979-1995 Mustang GT 6 11-16-2006 09:03 AM
My Alternator I polished 97Stallion Pictures and Videos 13 05-03-2005 09:00 PM
Brand New Alternator for 5.0 v6stanger Mustang Parts for Sale and Wanted 0 09-22-2004 11:51 PM
Alternator Whine Kessler Mustang Audio & Video 4 01-22-2004 09:44 PM
96 GT alternator Rellik Pre-2005 V6 Mustang 8 11-19-2003 12:12 PM
09:16 AM
