Lash adjusters? - Mustang Evolution
Old 02-21-2016, 08:33 PM   #1
superdrift's Avatar
Lash adjusters?
Car is fine untill the engine warms up then it makes a faint tapping noise in the engine bay but underneath the car has the most noise. I somehow managed to get the noise on video. But the car runs normally like nothing is wrong and when the engine is revved its still there but very very quietly.
https://youtu.be/AZzcBva1Wgs
superdrift is offline   Reply With Quote
Old 02-21-2016, 09:06 PM   #2
Listened to it a couple times. Sort of hard to pinpoint exactly where the noise is coming from which is probably a good thing because that means is most likely a lash adjuster.
I first thought it might be a tensioner but it would be most noticeable towards the front for obvious reasons.
Old 02-21-2016, 11:03 PM   #3
superdrift's Avatar
I would say the most noise is actually coming from under the car but if its a lash adjuster i was told that is allot cheeper to fix than allot of other things possible so i guess thats good
Old 02-22-2016, 04:36 AM   #4
Slater2111's Avatar
Sounds like a lash adjuster. What weight oil are you running?
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 02-22-2016, 07:59 AM   #5
superdrift's Avatar
5w30
Old 02-22-2016, 08:20 AM   #6
Slater2111's Avatar
Try going to 10w30 and see if that doesn't quiet it down some. I have 2 lash adjusters that need to be replaced. A heavier oil is a bandaid that will keep the lash adjuster primed longer.
Old 02-22-2016, 08:27 AM   #7
superdrift's Avatar
Ahh ok, is there a good brand that i should use?
Old 02-22-2016, 08:51 AM   #8
Slater2111's Avatar
Lash adjusters?
Valvoline full synthetic high mileage. I use that with a couple ounces of Lucas TB ZDDP additive.
Old 02-22-2016, 08:53 AM   #9
Slater2111's Avatar
Name:	ImageUploadedByMustang Evolution1456156413.565570.jpg
Although if you still have cats don't put this in your car.
Old 02-22-2016, 08:58 AM   #10
superdrift's Avatar
Attachment 197345
I do still have cats
Old 02-22-2016, 09:22 AM   #11
Slater2111's Avatar
Try the oil first. Like I said. It won't fix the worn out lash adjuster. It will help it hold its prime and not deflate as bad.
Old 02-22-2016, 10:00 AM   #12
superdrift's Avatar
Ok it wont affect anything else on the car right?
Old 02-22-2016, 10:09 AM   #13
Slater2111's Avatar
Only a slight drop in MPG.
Old 02-22-2016, 10:45 AM   #14
superdrift's Avatar
Lol mpg, but is it safe to drive the car is all im wondering
Old 02-22-2016, 11:02 AM   #15
Slater2111's Avatar
Yes but like I said it's a bandaid.
Old 02-22-2016, 11:18 AM   #16
superdrift's Avatar
Ik not planning on keeping it like this way but its my daily so it will eventually get repaired
Old 02-24-2016, 02:56 PM   #17
superdrift's Avatar
Well now the noise isnt noticable but a zap like noise is back under my car? Any ideas?
Old 02-24-2016, 03:20 PM   #18
Slater2111's Avatar
A zap like noise?
Old 02-24-2016, 04:02 PM   #19
superdrift's Avatar
A zap like noise?
Thats the best way i can describe it. It doesnt sound electrical but its like a zap
Old 02-24-2016, 04:05 PM   #20
Slater2111's Avatar
I have no idea man. You got me.
Old 02-24-2016, 04:11 PM   #21
superdrift's Avatar
Im hoping there is an exhaust leak. I want some headers and a new midpipe lol
Old 02-25-2016, 08:42 PM   #22
Steve96's Avatar
A while back when I listened to it, sounded like an exhaust leak or rattle.
1996 GT
Old 02-25-2016, 09:11 PM   #23
superdrift's Avatar
Well today i drove it about 15miles to a meet, i got there and the car made no noises, let it sit for 2hrs then i crank it up and drive it 5miles and the noise is back. Ive been told a knock and lash adjusters cant go away and come back so any other ideas than an exhaust leak?
Old 02-25-2016, 09:24 PM   #24
Slater2111's Avatar
I can't think of anything under the hood that sounds like a zap while malfunctioning. Any possibly video? I know the AC system can make a whirring noise somethings.
Old 02-26-2016, 03:42 PM   #25
superdrift's Avatar
https://youtu.be/EV7wCcyCe7w
Hopefully you can hear it, now that i hear it, it sounds like something very tiny rattling
Old 02-26-2016, 04:01 PM   #26
Slater2111's Avatar
I can't hear anything like you're talking about man. It's very hard to diagnose noises over the Internet.
Old 02-26-2016, 04:09 PM   #27
superdrift's Avatar
Yeah ik, the noise doesnt get louder when reved
Old 02-26-2016, 06:28 PM   #28
Steve96's Avatar
Thats what I heard like a week ago, thin metal rattle like a cat or some sort of exhuast peice
1996 GT
Old 02-26-2016, 08:27 PM   #29
superdrift's Avatar
So im guessing i should come back after i get an offroad midpipe? Lol
Old 02-26-2016, 08:49 PM   #30
Steve96's Avatar
That may fix the noise your hearing. Run the heavier oil like suggested, go to an exhaust shop, most give you a free estimate Im sure. They will be able to tell you if you have something like that going on. My 96 has a slight thin sounding (the only way I can describe it "thin") noise that I get at a certain rpm. Its when Im in traffic and I let the clutch out but only moving about 15 mph and Ill hear it. Normal driving I dont. Its something on my exhuast rattling or a trans mount or something making slight vibration noise. Could even be vibrating linkage somehwere, I dont know. But they should be able to give you an idea. At least that way you can not worry about it
1996 GT
Old 02-26-2016, 09:12 PM   #31
superdrift's Avatar
Yeah ima goto a shop and get em to see if its a leak and try to find the problem
Old 02-26-2016, 09:23 PM   #32
Steve96's Avatar
It may be something that can be done cheaply
1996 GT
Old 02-26-2016, 10:00 PM   #33
superdrift's Avatar
Im hoping so, im also hoping that the noise somehow doesnt magically go away when i take it cause this has happened a couple of times with my v6 lol
Old 02-26-2016, 10:12 PM   #34
Steve96's Avatar
That has happened to me a few times in my life. Maybe not a noise but an issue or whatever wont replicate itself
1996 GT
Old 03-10-2016, 03:48 PM   #35
superdrift's Avatar
Put seafoam in my oil and it went away after a little bit
Headlight adjusters won't work StangerBanger04 1996-2004 Mustang GT 8 02-12-2013 08:54 AM
Headlight adjusters? WhiteCobra94 1979-1995 Mustang GT 2 10-04-2012 08:53 PM
3.8 valve lash settings 408stroker 1996-2004 Mustang GT 0 04-09-2012 06:31 PM
Replacing 1996 cobra lash adjusters due to ticking? proberts 1996-2004 Mustang GT 1 03-18-2011 06:19 PM
» Members Mustangs
GT
MHochhaus
Mia
Vinny
Add your Mustang
02:40 PM
