EVAP delete - Mustang Evolution
Old 02-23-2016, 03:47 PM   #1
keeney35's Avatar
EVAP delete
I'm trying to delete all of the evap system. Both what's up front in the passenger fender well, and under the rear driver side bumper area.
I'm trying to find out how I can vent the tank so I can still fill it since it's got the check valve.
Obviously everything would need to be turned off in the tune.
Name:	ImageUploadedByMustang Evolution1456267486.421032.jpg
That's my tank as it sits.
2 lines run to the canister in the rear on the left and three lines come from the filler neck. One obviously being the filler going to the side of the tank.
I'm not concerned with the legality aspect, since it's not a "street car"
I found this on a forum but not sure if it would work. He's got the vent line dumped below the tank and the two lines going to the canister looped together with a hoseClick image for larger version
Name:	ImageUploadedByMustang Evolution1456267642.148944.jpg
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
2012 Evap canister delete, anyone done it? brianw64 2011-2014 Mustang GT 23 09-12-2017 12:29 PM
1996 Mustang V6 3.8l Evap Code xxxchaos 2.3 Mustang 0 07-30-2011 02:24 PM
1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve Brent Pre-2005 V6 Mustang 33 01-30-2011 08:32 PM
2004 GT EVAP Questions SSgt Dan 1996-2004 Mustang GT 16 09-25-2009 01:20 PM
Evap leak Small jmarcinko00gt 1996-2004 Mustang GT 6 09-03-2008 10:26 AM
02:08 PM
