327 or 373's with twin turbos - Mustang Evolution
Old 02-24-2016, 06:12 PM   #1
bwright1973's Avatar
That's my question in its self I have 373's car is auto with 327's hauls *** would 373 help or hurt..... Looking for any input
bwright1973 is offline   Reply With Quote
Old 02-24-2016, 09:37 PM   #2
jeno's Avatar
Higher gear would limit your top end but with the tq your getting now why do gears
Sent from my Nexus 6 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 02-25-2016, 02:37 AM   #3
Jeno that's what was going thru my mind! It move well now can was thinking the 373 would make it spin worse. It spins the wheels bad in second at times but it's still moving the car well 373 would bring that spin on sooner and Iam thinking will hurt it more than help it. Hell I don't know lol
Old 02-25-2016, 04:41 AM   #4
jeno's Avatar
I would say it would unless your doing 1/4 mile only then with you power I would stay with the 327
Old 02-25-2016, 07:50 AM   #5
3.73s would be stupid with that setup, sorry to be blunt. If you don't already, you should be looking into a Circle D converter.
Old 02-25-2016, 08:33 AM   #6
Scott I have a converter already it's not in the car yet was waiting till I rebuild it to throw it in.
Old 02-25-2016, 08:43 AM   #7
And the rebuilds coming sooner than later! No slipping but it occasionally looses 1st and reverse! Lol
Old 02-25-2016, 08:45 AM   #8
Just find a low mileage 4R75w out of an 04 GT or Mach. Swap that in with the new converter and you are golden. Way cheaper than a rebuilt crazy one.
Old 02-25-2016, 10:52 AM   #9
I have a buddy that will rebuild mine with Kevlar band good clutches harden stubby shaft pa valve body and the converter for 1500.00
Old 02-25-2016, 11:15 AM   #10
Hmmm you can get a solid 75w for 1/4 of that price if you look. And it'll hold 600+. But I mean do what you need to do. If you are planning on 700+ later on it might be a good idea.
Old 02-25-2016, 11:25 AM   #11
Curiosity kills me how the 373 would be as opposed to the 327! Hate to change it and it not be as strong or spin worse
Old 02-25-2016, 11:44 AM   #12
Well what you don't want is to run out of 3rd gear before the 1/4 mile pole. Also on street tires you are just going to torch them with an auto.
Old 02-25-2016, 12:16 PM   #13
If you are loosing traction in the first two gears now, why are you considering making it worse by going to 3.73's? The 3.73's would feel better on the highway when you want to pass without a downshift, but that does not sound like what you are after here at all.
Have you done a dyno run on your car with the current setup? If you have, take a look at your torque curve -- I'd be willing to bet that you have 90% of your torque all in below 2,400 rpm or less.
3.73's are just going to make the car difficult to drive as you will be too busy steering when the rear tires go up in smoke all the way through 1st and 2nd gears.
Old 02-25-2016, 03:13 PM   #14
It spins thru drive now first is easy about the time the boost comes on its almost time to change into second about that time it's moving the car well but spinning pretty damn hard. I am curious about the track with good tires 373's would be better or the 327 still load the turbos harder and pull better.
Old 02-25-2016, 03:25 PM   #15
Grabber Blue5.0's Avatar
The 3.27's are a better choice since they will put a load on the car which helps build boost.
Old 02-25-2016, 03:39 PM   #16
I do not see a problem with 3.73 gears. Get the car on some good tires and better suspension parts. I tell you it will be quicker with 3.73. Unless you are running 130 plus you will not run out of rpms. With a tighter convertor it tends to bog the motor. So the gear will help keep the motor accelerating.
7secmod is offline   Reply With Quote
Old 02-25-2016, 03:50 PM   #17
Uh....
Old 02-25-2016, 04:16 PM   #18
Less gear is a band aid for lack of traction
Old 02-25-2016, 04:26 PM   #19
Less gear on a turbo car puts a load on it and builds boost faster.
Old 02-25-2016, 04:29 PM   #20
Thats not what it is all about. A properly sized turbo will enhance spool up. And reduce lag.
Old 02-25-2016, 06:09 PM   #21
These are my opinions based on my experience and observations. Just my two cents.😆
Old 02-25-2016, 06:22 PM   #22
What the hell do you know??? You only build and drive 2,000+ horse power cars!
Old 02-25-2016, 06:39 PM   #23
I was just curious about others opinions. The 327's pull damn good
Old 02-25-2016, 09:41 PM   #24
jeno's Avatar
Eh I still say you should stay 327 unless this Is a 1/4 mile monster only
Old 02-26-2016, 04:41 AM   #25
Name:	ImageUploadedByMustang Evolution1456486884.664976.jpg
Old 02-26-2016, 04:42 AM   #26
TRACTION!!! the struggle is real!!! Lol
Old 02-26-2016, 04:45 AM   #27
jeno's Avatar
Attachment 197505
Love it
Old 02-26-2016, 04:53 AM   #28
Lol I was laughing my *** off! Spinning ain't winning but damn it's fun!
Old 02-26-2016, 02:48 PM   #29
how about a good set of Steeda aluminum lower control arms.would that help or do you already have some good rr arms installed?
newedge01 is offline   Reply With Quote
Twin turbos Rexxy03 SVT Mustang 17 01-12-2013 09:49 AM
Twin turbos Blackcat 2011-2014 Mustang GT 54 12-01-2011 08:17 AM
? about twin turbos Z-EATER 1979-1995 Mustang GT 5 08-22-2007 08:58 PM
Ford Bringing Twin Turbos into the Lineup in 08 bluemustang General Car Discussion 31 07-19-2007 10:35 AM
Great Oppurtunity...I think. Twin T3 Turbos. Dom Pre-2005 V6 Mustang 7 01-14-2004 04:01 PM
» Members Mustangs
Stacy
BayyGT
Airika
dwood63
Add your Mustang
04:10 PM
