Spark plugs in 4.6 - Mustang Evolution
Old 02-25-2016, 07:17 AM   #1
XxBadfishxX's Avatar
Spark plugs in 4.6
I'm getting confused, does the fuel rail need removed in order to get to the spark plugs?
Sent from my SM-P900 using Mustang Evolution mobile app
XxBadfishxX is offline   Reply With Quote
Old 02-25-2016, 07:19 AM   #2
Mile high JDF's Avatar
No. It makes things easier but is not necessary
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-25-2016, 07:28 AM   #3
Lol no. Spark plugs take an hour to do max. Maybe a little longer in a 99-04 car because of the stupid COP retaining bolts. On a 96-98 its silly easy.
Old 02-25-2016, 09:10 AM   #4
It's a 2002, but it looked like the fuel rail was in the way, just trying to confirm
Old 02-25-2016, 09:21 AM   #5
Remove the COPs, rebuild them while they are out ($30 boot and spring kit) and you get the spark plugs out with a magnetic spark plug socket and an extension. I've found a 10" extension with a wobble end is really good for this. Cheap at Harbor Freight.
Old 02-25-2016, 09:22 AM   #6
Ok, COPs do you mean the leads?
Old 02-25-2016, 09:28 AM   #7
No, the COPs are the coils... when you do the plugs you should always do the boots/springs on the COPs as well. Its basically like doing the wires on a 98-down car.
Old 02-25-2016, 09:30 AM   #8
Ok, thanks. Good info. I feel like if I replace these spark plugs I'll have better response time and better idle, I have a suspicion that they are fouled
Old 02-25-2016, 09:33 AM   #9
When you do, make sure you are using the correct plug, check the gap, use anti-seize and USE A TORQUE WRENCH. 12-15ft lbs WITH ANTISEIZE for these heads.
Old 02-25-2016, 09:36 AM   #10
Is there a spec page somewhere that states the correct spark plug gap? Not sure if these will be the correct gap that is in there already. They are not original.....at least I hope they are not
Old 02-25-2016, 09:40 AM   #11
Get Autolite APP104 plugs. Gap them to .054 if you are stock.
Old 02-25-2016, 09:41 AM   #12
Ok thank you
Old 02-25-2016, 02:00 PM   #13
XSlashDashX's Avatar
Yeah make sure to torque to spec with antiseize or you will strip them out. I know for experience lol
Old 02-25-2016, 02:21 PM   #14
Lol that would suck, hard to find an easy out for that
Sent from my SM-P900 using Tapatalk
Old 02-25-2016, 02:52 PM   #15
fomoco4life's Avatar
Why do u suspect they're fouled? Is it missing? Probably one of the cops, not plugs if it is. They're notorious for fouling up, however, if u want better throttle response, you'll need to change ur tb/plenum
Old 02-25-2016, 02:57 PM   #16
Yeah I would like a new tb, still stock
I have a nice cold air intake though
Old 02-25-2016, 03:39 PM   #17
04beautyGT's Avatar
Yeah, if you can afford them, go ahead and replace the COP's...if not, be super easy on them while taking them out. If they stretch too much, they can become porous, which will make your car misfire
Sent from my LGL22C using Mustang Evolution mobile app
Sadie- '04 GT Auto- RMR#4837, 4-Point-SEXY
04beautyGT is offline   Reply With Quote
Old 02-25-2016, 03:40 PM   #18
Ok thanks
Old 02-25-2016, 03:49 PM   #19
Anyone can afford it. Its $30 to rebuild them. No reason to ever buy new ones really, the electronic part almost never goes bad especially OEM Ford ones.
Old 02-25-2016, 03:50 PM   #20
Yeah, I'm having trouble trying to locate a rebuild kit
Old 02-25-2016, 03:52 PM   #21
http://www.amazon.com/Denso-671-8110...ype=automotive
Old 02-25-2016, 03:53 PM   #22
Thank you!
Old 02-25-2016, 03:53 PM   #23
There is one reason....it's the one I used.....straight up lazy with $$ to spend...ironically, I found the bad one when replacing them all, leaving me with 7good cops, and a $500 hole in my pocket.
Yup, just rebuild em (or I'll give u a deal on some used)
Sent from my HTC One using Tapatalk
Old 02-25-2016, 03:54 PM   #24
Ok cool, will do!
Old 02-25-2016, 06:14 PM   #25
I got 8 mint ones with the 2V pullout motor I got with 39k on it. So I have 8 spares now for my Expy and Stang. Just rebuilt the ones on the Expy tho. 140k and they are rocking.
As far as lazy factor... I dunno it literally takes 10 seconds to rebuild one. Pull the boot right off, spring pulls right out and they go right back together.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 02-25-2016, 06:45 PM   #26
04beautyGT's Avatar
$45 is a lot sometimes...they are easy to replace...so I just assume to be careful and reuse them, if I have a problem then simply unscrew 8 coils and fork out the money if I have to...if no problem, then I saved $45 plus my time. It's not like the car won't run with a couple of them with a slight misfire.
Old 02-26-2016, 08:25 AM   #27
Im trying to understand how a slight metal fatigued coil will cause a misfire, it seems like it is pretty contained in the pack to almost always have conductivity
Old 02-26-2016, 09:42 AM   #28
Slater2111's Avatar
Fatigued metal has high resistance. High resistance means no current flow. No current flow means no spark/weak spark. No spark/ weak spark means misfire.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 08:42 AM
No spark in the spark plugs 94GTpony 1979-1995 Mustang GT 7 10-30-2012 01:20 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
Spark Plugs Stang01 Pre-2005 V6 Mustang 19 07-18-2003 04:55 PM
03:32 AM
