Rebuild or New engine - Mustang Evolution
Old 02-29-2016, 12:32 PM   #1
xrsfx's Avatar
I have a blown head gasket. The engine has 150k miles on her. Would it be better to just rebuild the engine or to swap it out. For the 04's I was told I can just swap it for an engine off a GM or a crown vic. I found a GM engine for 755 with shipping off LKQ and that has a warranty. I was quoted for 1500 to 2200 depending on if I want to upgrade the pistons when I rebuild it. The GM engine has 71k miles on it. IMO that is very little mileage so itll be like brand new for me. I plan on Keeping the car and eventually go turbo.
My mechanic told me he'll swap the engine for 500. so rebuild could be up to 2700 vs the 1255 for the complete engine swap from the GM. Is the GM good enough or would it be better to just do a rebuild on the engine.
xrsfx is offline   Reply With Quote
Old 02-29-2016, 01:05 PM   #2
4.8, 5.3, 5.7?
Adventure till you drop.
Old 02-29-2016, 01:28 PM   #3
Your mechanic is going to do all the labor to LSX swap you for $500?
Um... ok.
Old 02-29-2016, 01:41 PM   #4
What do you mean by "GM"?
Old 02-29-2016, 02:02 PM   #5
BLKBETTY13's Avatar
I think he may mean Grand Marquis?
BLKBETTY13 is offline   Reply With Quote
Old 02-29-2016, 02:46 PM   #6
Ah...
Rebuild will be new... 71k is not a ton but... not brand new either.
I found a Marquis engine with 39k on it for $575 to my door. I'd try to find a lower mileage one than 71k TBTH.
Old 02-29-2016, 04:02 PM   #7
xrsfx's Avatar
Um... ok.
Is that too much? He's a buddy of mine so I didn't argue.
I'll keep looking.
---------- Post added at 05:02 PM ---------- Previous post was at 05:02 PM ----------
4.8, 5.3, 5.7?
4.6 l v8
Old 02-29-2016, 05:03 PM   #8
Sorry thought you meant GM as in General Motors.
Old 02-29-2016, 05:12 PM   #9
Steve96's Avatar
LSX swap??? JK!! Look for a lower milage one, if you look around and have the time to do so more importantly youll find one. But for $500 to swap it, that sounds like a great price to me. Typically its from $1200-$2000 to swap a motor at a reputable shop. Does that price include the engine too? If so but Im sure that cant be, but I would take that deal with 71k miles anyday!
1996 GT
Old 02-29-2016, 06:50 PM   #10
There is no way its $500 with engine. But $500 to swap the motor is a really good price as long as its not Uncle Jimbob.
Old 02-29-2016, 07:53 PM   #11
xrsfx's Avatar
It's not with the engine, I have to provide it.
Old 02-29-2016, 07:55 PM   #12
xrsfx's Avatar
Yea 500 to swap motors. He changed my clutch, motor mounts, rear main seal, flush out the radiator, change the spark plugs for 240
Old 03-01-2016, 12:41 AM   #13
Steve96's Avatar
I need to drive there and get some work done then if thats the case. Good price and if you trust him I say find a motor and let him have at it.
1996 GT
Old 03-01-2016, 12:43 AM   #14
Steve96's Avatar
I used to know a mechanic that worked out of his personal garage and his prices were like this. He would do an engine swap for 350-600 depending on what it was. He was very good too. Lost contact though and I dont know if he still does that kind of work.
1996 GT
Old 03-01-2016, 01:36 AM   #15
xrsfx's Avatar
If you're in Southern California he's the place to go to. So 500 is a good price that's good to know, I trust him so I never argue with prices unless I'm low on funds then he'll let me make it up to him or pay him in payments.
Old 03-01-2016, 04:10 PM   #16
Steve96's Avatar
Yes $500 is one hell of a deal. I would say most places would charge at least double that
1996 GT
Old 03-02-2016, 04:07 PM   #17
I take GM as General Motors too
But I have a dumb question though. Do you need get a new transmission to work with the swapped engine or your original transmission can handle it?
alfaromeo is offline   Reply With Quote
Old 03-02-2016, 05:23 PM   #18
He won't have to do the trans unless something is wrong with it. A pi motor is a pi motor.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 03-02-2016, 05:38 PM   #19
Rapinator126's Avatar
Don't even bother with a modular swap. Do it right and go lsx
LSX 408 FTW
Dragging your a$$
Old 03-03-2016, 07:55 PM   #20
xrsfx's Avatar
Ah...
Where did you find this engine ? I'm having trouble finding any engine that's not lkq. Started reading that they tend to send dirty engines.
Old 03-04-2016, 03:36 AM   #21
www.car-part.com
Old 03-04-2016, 06:38 PM   #22
xrsfx's Avatar
Thank you. found a 2011 crown vic for a good deal.
Old 03-04-2016, 07:57 PM   #23
LSX 408 FTW
Dragging your a$$
Does anybody make a kit to install one in a Mustang, and still be emissions legal?
Old 03-04-2016, 11:34 PM   #24
The LS1 almost bolts right up to our K members, just needs DIY adapter plates or I think UPR makes a kit. Or just buy a K member with LS1 mounts setup already. After that most ppl run the GM ECU and go mechanical gauges or there have been a few ppl who really know their **** who have machined up some parts to use the Mustang ECU to run everything. Or go carbed or megasquirt or something.
Seems the most common thing is to run the GM ECU and then figure the gauges out later. The problem with OBDII emissions is that when you plug in they also scan your door for the VIN (at least here) and the VIN must match the computer. You have to use HP Tuners to change the VIN if you need to pass OBDII emissions. I don't think EFI Live has that feature or if they did they added it recently.
Trying to think what else... mostly "gotcha" stuff. Fuel, random electronics, AC, power steering etc... If you hit up ls1tech or some other forums there is a ton of info on building a "hybrid". Swap headers are available as well as a lot of the stuff for the swap already pre-fabbed since people like to drop LS1s into everything. Real holy ****balls cheap fun fast as all hell car is a FC RX7 with a LSx in it. The FD is probably nicer but just a roller for those in good shape is $$$$. Although my personal favorite is a real nice E36 BMW with a LSx in it. Best of every world there and Samberg makes a full swap kit for it.
Old 03-06-2016, 12:30 AM   #25
Yeah, doing engine swaps on computer controlled vehicles is a lot more difficult than back in the carburetor days! Lol
I suppose that is why a lot of people in California favor pre-1976 vehicles to heavily modify. There is no emissions testing on those cars.
I think that an LS powered Pinto would be pretty cool. Sort of a copy of the Pro-stock car that Bob Glidden used to race in the 70's. Only Chevy powered! Haha
I'm usually not a fan of bastardizing cars by mixing makes like that, but it's difficult to dismiss an engine that will handle the power, in stock form, like an LS will.
Old 03-06-2016, 12:54 AM   #26
Lol yeah living in Cali I'd be all about finding a classic. And like REALLY classic like a 1951 Mercury chop top.
rebuild of a recent rebuild Black99Snake SVT Mustang 12 08-20-2011 05:24 PM
Engine rebuild north of Chicago ? Rewbeez Classic Mustangs 1 07-23-2011 01:10 PM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
Recommend a shop for engine rebuild or swap In2dreamingbig 1996-2004 Mustang GT 2 09-27-2005 01:56 AM
engine rebuild tire Pre-2005 V6 Mustang 12 02-27-2004 06:54 AM
04:55 PM
