Help!!! - Mustang Evolution
Old 03-01-2016, 09:10 AM   #1
Help!!!
I have a 2004 mustang gt built with Bbk valve covers that need to be removed due to leaking now I got all the bolts out both sides they are both loose but get hung up I can't get them off I need help thank you
Matt1867 is offline   Reply With Quote
Old 03-01-2016, 10:40 AM   #2
jeno's Avatar
Getting hung up on what or they just feel stuck ?
Sent from my 2003 rocketstang using Mustang Evolution
jeno is offline   Reply With Quote
Old 03-01-2016, 04:40 PM   #3
keeney35's Avatar
They should be tight, pry em off with a flat head
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 03-01-2016, 07:20 PM   #4
XSlashDashX's Avatar
I heard the bbk valve covers were huge. So barely any room to remove.
Old 03-02-2016, 03:23 AM   #5
Maybe unbolt the motor mounts and jack up the motor to get a little more clearance? Dunno. No idea why ppl replace the perfectly good stock covers...
2000 Mustang GT Steeda #0048
Old 03-02-2016, 08:25 AM   #6
Wow wat a pain
I got the bbk valve covers off the master an brake booster was in the way an from sheer size it's just tight but thanks for everyone help
Old 03-02-2016, 10:58 AM   #7
Replaced my stockers because previous owner cracked the back of the cover causing it to leak.
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 05:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 07:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 12:37 PM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 02:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 05:35 PM
02:43 PM
