Possible head gasket leak? - Mustang Evolution
Old 03-05-2016, 04:10 PM   #1
robin_gt's Avatar
Hey folks,
so today i noticed a burnt plastic kind of smell and light smoke while parked and popped the hood to see what was going on, the smell came from the drivers side of the engine, i just got home and jacked the car up to see what was going on and it seems like there is a reasonable amount of oil leaking from the back of the engine, drivers side, onto the long tube headers(see picture). It seems like the leak is where head and block meets so could this be a head gasket issue or just something as simple as the valve cover gasket where the oil just drips down. I tried to take a look at the back of the valve cover gasket but i did not see anything, there are lots of things in the way like firewall, master cylinder etc. It is a 2002 gt so it has a romeo block. Thanks
robin_gt is offline   Reply With Quote
Old 03-05-2016, 04:48 PM   #2
natestang07's Avatar
I could be way off on this but I think these things have leaky intake manifolds. Might be worth looking at.
Old 03-05-2016, 08:13 PM   #3
Man_tlac00's Avatar
Region: Delaware
If it is anything like the 5.4 tritons and the 4.6 roms that are in the 98 to 01 or maybe up to 02/03. They have some screwed up defects from Ford. That they [Ford] claims doesn't effect the reliability of the motor. I am not sure if the Mustangs have the same issues but I think they may. My 98 expedition is having this issue now. Rear passenger and front driver. Driver side mostly goes back into motor. Not sure if I want to fix or upgrade.
Like nate said check the intake bolts first. Tighten them up a half turn or to spec, which ever one helps you sleep at night. Then check back for leaks after she has warmed up.
Sent from my SM-N900P using Mustang Evolution mobile app
Man_tlac00 is offline   Reply With Quote
Oil Pan Gasket Leak SLiM2775 Pre-2005 V6 Mustang 4 03-03-2014 05:40 AM
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
gasket leak help shustwit Pre-2005 V6 Mustang 0 06-13-2011 01:00 PM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
08:38 PM
