Overdrive - Mustang Evolution
Old 03-06-2016, 12:50 PM   #1
Overdrive
Is it OK to drive with the overdrive off?
04sonicgt is offline   Reply With Quote
Old 03-06-2016, 01:00 PM   #2
natestang07's Avatar
Pointless but yes.
Old 03-06-2016, 01:41 PM   #3
I drive highway with it on but when I drive city or traffic I turn mine off..
lyonschoice is offline   Reply With Quote
Old 03-06-2016, 02:22 PM   #4
jeno's Avatar
If you have a problem with your overdrive the turn it off the only trade off will be higher rpms so in hand more gas used but that's negligible not much of a difference I drive with it off sometimes lol
Sent from my 2003 rocketstang using Mustang Evolution
jeno is offline   Reply With Quote
Old 03-06-2016, 02:48 PM   #5
Region: Oregon
I kill it for quick starts, passing and when I just wanna have fun. Other than that your just drinking more gas.
Edainn is offline   Reply With Quote
Old 03-06-2016, 02:50 PM   #6
/\ none of that makes a difference. When you stomp on it the car will downshift regardless.
Old 03-06-2016, 03:34 PM   #7
Zero need to turn it off. The car will shift into the gear that is best suited for your driving. It will rarely shift into overdrive if you are just in the city at lower speeds. Like Nate said, if you press harder on the gas it just downshifts and goes.
Old 03-06-2016, 07:01 PM   #8
Turn it off at the 1/4 mile or if you own a Lightning or if you are towing. Those would be the only reasons.
Old 03-06-2016, 10:44 PM   #9
When automatic overdrive transmissions came into popular use in the early 80's, the biggest complaint amongst consumers was their constant shifting from 3rd gear to overdrive and back to 3rd, when driving at around the 45 mph range. The auto manufacturers fixed this inherent problem by providing a way to disable the overdrive via the shift lever, on early mechanically shifted transmissions, or a switch, on modern electronically shifted transmissions.
Scotty mentioned some other driving conditions where it may be beneficial to turn off the overdrive. Another situation, when I turn off the overdrive, is while descending steep grades, so I can take advantage of the engine braking.
There are several situations where turning it off can come in handy.
Turning of Overdrive, does it go into “Performance Mode”? Renegade 800 Pre-2005 V6 Mustang 13 06-27-2008 05:58 PM
overdrive Mustang GT HO 1996-2004 Mustang GT 4 05-04-2008 11:19 PM
Using OVERDRIVE jaredp Pre-2005 V6 Mustang 16 01-27-2007 12:36 PM
Overdrive question didnt know where to put this 95 DrOpToP Pre-2005 V6 Mustang 4 02-08-2005 08:36 PM
Question about Overdrive light Twitch Pre-2005 V6 Mustang 6 02-11-2004 04:05 PM
» Members Mustangs
Ruby
JAC20
my gt
dcox7178
Add your Mustang
04:52 AM
