Hydro boost leaking - Mustang Evolution
Old 03-06-2016, 05:36 PM   #1
robin_gt's Avatar
Hydro boost leaking
My hydro boost is leaking right where it bolts up to the piece that is bolted to the firewall. It's dripping right onto my longtubes and it smells horrible. Should i replace the hydro boost unit only or also replace the MC? is it possible to replace the gasket? Thanks!!
robin_gt is offline   Reply With Quote
Old 03-06-2016, 07:13 PM   #2
There is probably a seal inside of the booster that has failed, so you will have to replace it.
It really depends on the mileage on the car as to whether the master cylinder should be replaced as well. They typically last a long time, and when they do fail, only half of the brakes (front or rear) are affected, so it gives you some warning when it needs to be replaced.
Old 03-06-2016, 07:42 PM   #3
robin_gt's Avatar
Do you know if i can just open the hydro booster up and replace that one seal that is leaking, or just buy a new one? The reason why i am asking is these things can be pretty complex inside and i don't want to mess anything up.
Old 03-06-2016, 08:56 PM   #4
I'm not aware of any rebuld kits to repair the booster so you will probably have to buy a new one.
But who knows? You might find something that is easily repaired once you remove the booster and give it a closer inspection.
Old 03-09-2016, 05:53 AM   #5
Roguestang's Avatar
I had the same issue on my 2000. I never found a "rebuild" kit for it. I just replaced the whole thing. Had to take my old hydrobooster in for a core charge too.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 03-17-2016, 06:09 PM   #6
fenixignition's Avatar
Lame. Mines leaking just like the one in the picture. Is it a pretty straight forward install for a new booster?
Sent from my SM-G920V using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Hydro boost brakes ?? ebourd 1979-1995 Mustang GT 9 08-24-2015 03:21 PM
Brakes? Hydro boost? HELP?! BlacK02 1996-2004 Mustang GT 24 08-22-2015 01:06 PM
Hydro bushing KARgt13 2011-2014 Mustang GT 0 10-03-2013 06:27 AM
Boost line for boost gauge TooSlow4U 2011-2014 Mustang GT 0 07-20-2012 09:34 PM
hydro dip S197Miller 2005-2010 Mustang GT 9 01-16-2012 05:59 PM
04:29 PM
