How to install c clip in rear axle - Mustang Evolution
Old 03-07-2016, 12:35 PM   #1
cstyle408's Avatar
Im replacing my rear axle in my 98 gt 5 speed and have the old one out, putting new one in but for the life of me i can not get the c clip in. Anybody know of any tricks or advice? It was super easy getting it out of course but getting it back in is a PITA. Its starting to rain so i am limited on time also. Thanks for any help. I appreciate it
cstyle408 is offline   Reply With Quote
Old 03-07-2016, 07:06 PM   #2
Slater2111's Avatar
Insert axle push all the way into the splines push c clip in slots that's about it.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 03-07-2016, 08:37 PM   #3
cstyle408's Avatar
I wish it were that easy for me. I think that s shaped thing shifted a little not allowing the axle to go all the way in to where i can put clip on and its preventing the pinion pin to go all the way in. How do i move this thing around so i can get the axle all the way on and pinion back in?
Sent from my LGMS345 using Mustang Evolution mobile app
Old 03-09-2016, 11:11 AM   #4
cstyle408's Avatar
I got the axle put back together. The problem was that s shaped spring thing in the middle shifted back preventing the axle to be pushed in all the way and also wasnt lined up so the pinion pin couldnt be pushed back into place. I rotated the axle 180 degrees and tapped it into place with a rubber mallet. Easy fix. This is was my first time changing axles or working on a rearend in general. So i didnt know what to expect.
Old 03-09-2016, 12:04 PM   #5
Slater2111's Avatar
Learning has occurred! Yea that's the biggest challenge with changing gears. Other than that it's pretty straight forward.
Old 03-10-2016, 10:36 AM   #6
olerodder's Avatar
Region: Oregon
Just one reason why using "C" clip eliminators is so helpful...........the other is that if/when the C clip breaks or the axle breaks.......the wheel/tire/axle/brakes and all leave in a hurry.......
2013 V6 Rear Axle FULL ASSY Swap to 2013 GT Rear Axle FULL ASSY sprdave 2011-2014 V6 Mustang 2 06-16-2015 12:14 PM
Axle c-clip ? 94_2valves 1979-1995 Mustang GT 2 03-31-2014 07:56 AM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
does the hub on the rear axle have a gasket between it and the axle? stangcobra Pre-2005 V6 Mustang 15 11-06-2012 04:16 PM
S clip rear end installation 88gt209 1979-1995 Mustang GT 7 08-27-2012 10:16 PM
03:06 AM
