Suspension upgrades. - Mustang Evolution
Old 03-09-2016, 10:53 AM   #1
phatspeed7x's Avatar
Finally got my state tax refund back and I ordered some upgraded suspension parts. Ordered a pair of Steeda rear lower control arms. TJ recommended the standard steel ones for my application.
Also saw American Muscle had Ford Racing lowering springs on sale so I grabbed a set of them.
Looking forward to getting rid of some wheel hop and the 4x4 stance.
How the car sits now.
Sent from my LG-H900 using Tapatalk
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 03-09-2016, 11:01 AM   #2
Sterlingbeast5.0's Avatar
cant wait to see the after!
Old 03-09-2016, 11:58 AM   #3
Cool! Car looks real clean. Always liked that color.
Can ditch the factory quad shocks after installing the new LCA's.
Which FRPP Springs did you go with? C's?
Old 03-09-2016, 12:20 PM   #4
Yes. Went with the C springs. After sale price and discount they were $165.
Old 03-09-2016, 02:13 PM   #5
Nice. Those will tighten up some of the fender gap but aren't so extreme that you need to revamp the entire suspension.
Old 03-10-2016, 09:32 AM   #6
Ordered some energy suspension spring isolators since I'm sure the factory ones are pretty much gone. According to the product info they should lower the car about an inch on all 4 corners. Will I need to purchase adjustable cast/camber plates to make my alignment good after the drop? Some people say I should be OK. Some say I should buy them just in case.
Old 03-10-2016, 09:40 AM   #7
Well, every car is different. The general consensus in the 99-04 community is that 90% of the time a drop less than 1.375-1.5" won't require aftermarket plates, despite the factory plates having virtually no adjustment built in.
You could do it two ways.
1. Buy the CC plates to be safe. Take the car in for an alignment and see if the shop can get into spec without them. If so, you can simply return the plates.
2. Or you can roll the dice, hold off on the plates and get the alignment. If the shop cannot get into spec you'll have to buy them and pay for another alignment. Worst case is you are out whatever the first alignment cost.
If it were me, I would pick up a set of plates to be safe. If you buy them from a reputable vendor, there should be no issue with returning them N.I.B.
Old 03-10-2016, 03:57 PM   #8
do it once, do it right. Get a set of plates. Plus then you can add in some custom specs for it to handle a bit better without sacrificing drivability or tire life.
Old 03-10-2016, 11:07 PM   #9
Steve96's Avatar
I dont think you will need the plates with a 1" drop, unless you want them for adjustability or performance reasons later on. If you get plates, do yourself a favor and get the MM ones. Dont try to save a little bit of money buying another brand, ask me how I know!
1996 GT
Old 03-10-2016, 11:13 PM   #10
Steve96's Avatar
Im starting to question the way now I was going to lower my 03 soonish. I was going to go 1.5" maybe with no isos as well, new ball joints, alignment, and call it good. But now with the sale on Koni STR.T products Im changing it up I think. Going to get new Koni struts, maybe Eibach Sportlines (off of craigslist new in box for 150-175), or another flavor of springs a little lower than 1.5", new ball joints, CC plates, and alignment. Roll with the new shocks in the back for now since they are easy to change later on and I'll have more funds too. But I question driveability on my crap roads and maybe should still stick with the SRs for the 1.5" drop, decisions, decisions. Its tough to decide!
1996 GT
Old 03-11-2016, 12:38 AM   #11
I still have some time to figure out what I'm going to do. There is still 2 feet of snow blocking the garage door to where my mustang is stored at. According to tracking information the control arms will be here next Tuesday. The springs are still waiting for pickup from American muscle according to that tracking number.
I also plan on adding new rear shocks in the rear and eliminating the quad shock.
Old 03-11-2016, 08:41 AM   #12
As someone who has a mustang with a 2" drop and one with a 1.5" drop I can give some real world feedback lol.
03: Super Sports, Tokico HP's, MM 4 bolt CC plates, X2's, no isos.
- 2" drop, stiffer ride. Usually avoid crap roads with potholes and severe crowning. Avoid steep entryways to save chin spoiler. Is not a daily so these "inconveniences" don't bother me.
04: SR Springs, Factory Tokicos and CC plates, no isos
- 1.6" drop, soft, stock like ride. Can still clear steep entryways with my chin spoiler and doesn't bottom out everywhere.
Lowering height is like exhaust, it's subjective. Some guys prefer slammed, others prefer stock height etc.
While the ride height on the Mach is a bit more convenient, I absolutely love the killer stance a 2" drop gives. So much so I am switching my Mach over to the same setup in about 4 hours lol. Only I went with Koni Yellows (Sports) over the HP's and STR.T's because I wanted adjustability. The STR.T's are an excellent choice if you don't need adjustability. I'd choose them over Tokicos.
Old 03-12-2016, 05:14 PM   #13
Ordered the rear spring isolators. American muscle had their SR performance ones for cheap. I'm sure they will work just fine.
Old 03-14-2016, 11:35 PM   #14
Springs showed up today.
Old 03-15-2016, 10:47 PM   #15
Control arms showed up today.
Old 03-16-2016, 02:37 PM   #16
Sweet! Are those Steedas?
Old 03-16-2016, 02:38 PM   #17
They sure are!
Old 03-16-2016, 02:41 PM   #18
Awesome. Have to let us know how well they installed and perform. I plan on getting a set of LCA's this summer.
Old 03-31-2016, 10:47 PM   #19
Westcoast408's Avatar
Have you installed the lowering springs yet?
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 04-01-2016, 07:25 AM   #20
PARTSFROMERIK's Avatar
Also has to do on your location, I know for a fact you won't see a car slammed up north like you would in South Florida lol.I'm on KW coils with CC plates about a 3" 5" rear drop and love it lol
PARTSFROMERIK is offline   Reply With Quote
Old 04-01-2016, 08:44 AM   #21
I have them on the current car and I had them on the blue 98 GT. I had MM LCAs on my 95 Cobra. The Steedas are every bit as good for less money.
2000 Mustang GT Steeda #0048
Old 04-01-2016, 03:31 PM   #22
Oh there are cars with a drop like yours up here. But it's mainly the import crowd, not mustangs. I have seen a couple S197 Coyotes slammed on coils/bags at a few shows but not nearly as many as down there.
Good to know. I am partial to MM, they make very good products, however I am not opposed to other quality products, especially if they're less money!. The Steeda products I currently own have all been excellent.
Old 04-01-2016, 04:04 PM   #23
I'm partial to MM as well but I'm not a brand loyal zealot lol. Not saying anyone here is. I honestly may UPR K my car as much as I nutswing on MM.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 04-01-2016, 08:01 PM   #24
rdwelch's Avatar
Sonic, how hard is it to do a 1.6" drop on a 2003 GT vert?
rdwelch is offline   Reply With Quote
Old 04-01-2016, 09:18 PM   #25
Steve96's Avatar
Im not Sonic, but he said to achieve a 1.6" on his Mach 1 he used SR lowering springs, no isos just use elec tape on the first 6" of the coil on both ends. That is anywhere between 1.6-1.7 lower. He had the stock Tokico dampners on the Mach.
1996 GT
Old 04-01-2016, 09:22 PM   #26
BLASPHEMY
Go take a time out in the corner and think about what you just said.
Old 04-01-2016, 09:24 PM   #27
BLASPHEMY
Lol for a street only car its fine. For road race/autox, no way in hell.
Old 04-01-2016, 09:29 PM   #28
At least get Team Z if you are going that route.
Being a street car is even more of a reason to get MM IMO. It is built the strongest out of all of them.
Old 04-02-2016, 12:40 AM   #29
I haven't gotten the parts installed yet. Mother nature played a nasty April fools joke. Dropped 3" of snow. My driveway is never gonna harden up.
Old 04-04-2016, 12:47 AM   #30
xrsfx's Avatar
Do you run in the front by any chance ?? What tire size do you have
---------- Post added at 12:47 AM ---------- Previous post was at 12:47 AM ----------
Rub
xrsfx is offline   Reply With Quote
Old 04-04-2016, 02:35 PM   #31
Rub
245/45ZR17 front
275/40ZR17 rear (not mounted in this pic)
Old 04-05-2016, 12:09 AM   #32
Steve96's Avatar
Rub
Shouldnt rub with a 245 45 17 unless you are like 2.5" or more lower, from what I have seen. Phatspeeds fronts dont look like they have a crazy amount of gap tho in that pic? Maybe its the angle or the way its parked? Usually 17" wheels with stock tires it looks like much more gap, like mine currently, haha.
1996 GT
Old 04-05-2016, 06:24 PM   #33
Got the springs installed. Went with energy suspension isolators. Car looks a little lower. I'm sure once it settles it will look good. Install took about 4hrs with just basic hand tools and my buddy Kirk watching most of the time. Lol
Old 04-05-2016, 06:41 PM   #34
Old 04-05-2016, 07:00 PM   #35
How much is the drop on those springs?
Sent from my SM-G920T using Mustang Evolution mobile app
What Suspension Upgrades? helloWorld 2011-2014 Mustang GT 8 08-18-2012 10:28 AM
Suspension Upgrades? mchilliard28 Pre-2005 V6 Mustang 4 03-04-2012 04:33 AM
Exterior upgrades and maybe performance upgrades RedToplessPony 2011-2014 V6 Mustang 34 12-26-2011 05:09 PM
68 suspension & brake upgrades? Jpeverini Classic Mustangs 14 07-06-2008 10:44 PM
Break down upgrades to suspension in STAGES for me please! ASSEMbler Pre-2005 V6 Mustang 27 12-26-2003 11:39 AM
12:33 PM
