Power Steering Leak - Mustang Evolution
Old 03-14-2016, 06:04 PM   #1
thump's Avatar
Power Steering Leak
Hey guys I could use your advice. I believe I have power steering leaking but trying to find out which line it's coming from.
Check out my video if you have time. I hope it's clear and understandable.
thump is offline   Reply With Quote
Old 03-14-2016, 10:11 PM   #2
I recommend using some Simple Green and getting that all cleaned up under there, so you can find exactly where the leak is coming from.
Is it a bad leak?
Does it leave a puddle when the car is parked?
Old 03-14-2016, 10:34 PM   #3
thump's Avatar
No puddle. It's somewhat a slow leak. I don't drive it often but when I do drive it I notice oil is all over the lines and hoses
Old 03-14-2016, 10:38 PM   #4
Yeah, the power steering hoses are under a lot of pressure.
You may get lucky, and it is just a loose fitting.
Old 03-14-2016, 10:55 PM   #5
thump's Avatar
Ok ill diagnose them again tomorrow thanks
Old 04-24-2016, 02:55 PM   #6
Tardis Traveler's Avatar
I have the same leaking issue at the pump where the pressure hose passes through the fitting. The fitting cannot be tightened any more than it is (without resorting to hammer blows [ahh!]) Will a 'simple' hose replacement fix the leak? Also; will this require bleeding the system after replacement? One more thing...Could a leak of this nature cause any unusual noises (ie. like an empty pumping sound after turns?)
Tardis Traveler is offline   Reply With Quote
Old 04-24-2016, 03:00 PM   #7
thump's Avatar
Do you know for sure it's coming from this line?
Old 04-24-2016, 03:16 PM   #8
Yes. Air in the system can cause a noisy pump.
Power Steering Fluid Leak JimmyMosqueda Pre-2005 V6 Mustang 6 05-11-2014 11:36 PM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
Rack & Pinion steering leak. jmartinezoce 1996-2004 Mustang GT 3 04-09-2013 08:33 PM
1973 Mustang Power steering box leak? What needs to be done? kang29 Classic Mustangs 3 12-14-2011 09:38 AM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
02:02 AM
