clutch fork sqealing?? - Mustang Evolution
Old 03-15-2016, 07:29 PM   #1
Hey everyone. I have a 98 gt 4.6sohc. My throw out bearing was going bad. So I replaced the clutch since I had to drop the tranny. Now I have a chirping noise and no matter how much I adjust the clutch cable it is still there. When I put a little bit of pressure on the clutch pedal it goes away. I jacked up car and moved and the clutch fork has a little bit of play and I can hear it sqealing. Also is the throw out bearing supposed to be touching the fingers.??? Any advise would be great. Thanks
clean4.6gt is offline   Reply With Quote
Old 03-15-2016, 11:25 PM   #2
Yes. The TOB should be just barely touching the fingers on the pressure plate. That way, when you depress the clutch at high RPM's, the TOB is already spinning and doesn't have to accelerate from 0 RPM's to 5000 in a split second.
It sounds like your clutch fork and/or pivot ball may be worn out. It probably should be replaced as a maintenance item every time that the clutch is replaced.
Old 03-16-2016, 08:37 PM   #3
Is there supposed to be play in the clutch fork. Like up down movement.
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
Old 03-16-2016, 09:08 PM   #4
I suppose that a little bit of play could be expected, but it should not be an excessive amount.
Old 03-17-2016, 09:21 AM   #5
If you get the noise to stop when you press the clutch a little then you don't have enough preload on the tob. It will have slop in the fork if this is the case as well. You need to tighten the cable until the tob starts to spin with the car in neutral and motor running. Then about another 1/4 turn at the firewall adjuster.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 03-17-2016, 07:51 PM   #6
The clutch fork will wear over time, and the bolt that holds it in, he tip will mushroom over time also. I'm doing my clutch this weekend so I just got new ones of both.
Old 03-17-2016, 09:11 PM   #7
Yea I should of change the clutch fork. I did adjust the the cable with the firewall adjuster and the sqealing is gone I can hear it once in a while when I engage the clutch. I'm going to replace the cable this weekend. I didn't replace it when I put new clutch in.
Old 03-17-2016, 09:16 PM   #8
I don't know if this sounds crazy. This is another issue. My oil gauge on my gauge cluster isn't working. When I was looking at the clutch fork I decided to see what was up with oil pressure sending unit. And I don't have one by the oil filter. I see the line hanging that it should attach to but no oil sending unit. The car runs fine.
Sqealing/squeaking possibly crankshaft? merkdaddy Pre-2005 V6 Mustang 4 04-17-2015 12:08 AM
Clutch cable problems or fork maybe? 04gtdriver85 1996-2004 Mustang GT 18 11-22-2013 04:10 PM
Clutch Fork Rattle xhgwx SVT Mustang 5 11-05-2013 07:02 PM
Clutch fork counterweight? ab_mach1 1996-2004 Mustang GT 10 10-27-2012 04:44 PM
07:07 AM
