2002 GT Fuel Tank Filler Neck/Tube - Mustang Evolution
Old 03-16-2016, 01:32 PM   #1
Michael.s.king's Avatar
Region: Maine
One of the tubes on my fuel tank filler neck rusted off, right up near where you put the gas nozzle.
Is there a cheap fix for this? Like a hose and a few clamps I can put over the hose that is still there? Would that not work?
Don't feel like paying $100 just for the neck/tube
Michael.s.king is offline   Reply With Quote
Old 03-16-2016, 02:08 PM   #2
keeney35's Avatar
You mean one of the evap hoses?
04 GT: CAI, 3.73's, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, Ported/Polished heads, Manley dished/notched pistons, MMR forged H beam rods, FRPP forged crank, BBK 75mm throttle body, MSD coils, 60lb EV6 injectors, Eddy Vic Jr intake, UPR coilovers in front, Steeda lowering springs in rear, Front strut bar, MM caster camber plates, UPR k member, 355lph walbro pump, MMR 8qt oil pan, ARP hardware, EGR delete, A/C delete, ABS delete, EVAP delete.
Honda weight with an American V8
keeney35 is offline   Reply With Quote
Old 03-16-2016, 04:16 PM   #3
Region: Maine
Yep!
Yep! Exactly!!
Old 03-22-2016, 08:17 AM   #4
Region: Maine
Dropping the Tank
Can you replace this whole thing without dropping the tank?
Old 03-22-2016, 09:31 AM   #5
keeney35's Avatar
It would be tough because the metal part of the filler neck goes about 5-6 inches into the tank and you don't have that much room to pull it out without dropping, those two hoses are for the evap system.
They are just vents for fuel vapors.
I deleted my evap so I don't really need em but if it's not vented it will cause your tank to vapor lock.
Some pics would help if you have any
Old 03-22-2016, 10:11 AM   #6
Region: Maine
I think it is an EVAP hose, especially since it is throwing a code (small evap leak ha).
It is deff not the main gas hose, but it does leak gas only when I'm pumping.
I will try to get some pics up tonight!
Old 03-22-2016, 10:43 AM   #7
keeney35's Avatar
It's an easy fix but you do need to drop the tank to do it. Run the gas low then drop it, it's easy brotha, like 3 sensors to unplug and 4 bolts
Fuel filler neck seal Ckennedy121 1996-2004 Mustang GT 5 05-15-2013 03:34 PM
Fuel Neck Filler??? Mustang1804 1996-2004 Mustang GT 6 12-21-2011 03:56 AM
fuel tank filler neck seal advice. HaulinTwinz 1979-1995 Mustang GT 11 03-26-2011 10:01 PM
Big Problem with the gas tank/filler neck/fuel etc runvsofthisbull Pre-2005 V6 Mustang 4 08-16-2010 08:30 PM
Fuel Tank/filler neck Scut95 1979-1995 Mustang GT 8 11-26-2008 01:15 PM
04:19 PM
