Humming noise - Mustang Evolution
Old 03-18-2016, 06:37 AM   #1
PARTSFROMERIK's Avatar
Humming noise
Good morning guys, I get a loud humming noise from the engine bay while Im in the car a/c off, just sitting at a light after maybe 5 minutes pass by, than it goes away until I turn off the car and start it after 8 hours or so? It doesn't go away if I turn a/c on or rev up the car a bit. It only last maybe 5-10 secs.
PARTSFROMERIK is offline   Reply With Quote
Old 03-18-2016, 08:06 AM   #2
Strange Mud's Avatar
not a clue and that intermittent will be a pain. All I can suggest is a length of hose 2-3' makes a good mechanics stethoscope.
good luck
Old 03-18-2016, 08:10 AM   #3
good luck
Lol I know, I've changed the belt thought it was that, cleaned out the IAC but to no solution D: I'll try this weekend and see what it is. It has no issues with the car at all revs fine doesn't drop a/c works fine.
Old 03-18-2016, 11:46 AM   #4
The plunger inside of the IAC can become worn, and begin to vibrate, and it will make a sort of low humming noise intermittently. It is frequently accompanied by the symptom of an erratic idle and stalling every once in a while.
Cleaning an IAC doesn't usually help. I believe that if they are old enough to need cleaning, they are likely worn out and need replacing.
Old 03-18-2016, 11:53 AM   #5
The car runs and idles perfect and has never stalled on me "only from highway speeds and pressing the clutch in" so I changed the IAC last year because of this. The humming noise only comes on once the car has been ran for around 5 minutes and only lasts 5-7secs with no other symptoms.. I can change it again the IAC and see if that helps..
Old 03-18-2016, 12:02 PM   #6
If it idles fine, I wouldn't change the IAC until doing some further diagnosis to determine the source of the noise. I was only suggesting a possible place to look.
Old 03-18-2016, 12:18 PM   #7
I understand lol, I appreciate the input but I will look into it further this weekend see if I can leave it parked on the lift over night and sunday morning crank it up and let it warm up.
Old 03-18-2016, 12:35 PM   #8
WAG after thinking. The loud and only on cold starts maybe something expanding and getting to a spot that resonates.
shielding on exhaust/intake?
When you try to replicate it have a piece of wood handy to press on items to see if that stops it.
Old 03-18-2016, 12:43 PM   #9
WAG? got me there.
Old 03-18-2016, 02:40 PM   #10
wild _____ guess
Humming Howling noise from pass fender runvsofthisbull 1996-2004 Mustang GT 20 03-19-2016 01:08 PM
Humming noise, please help! 99redbeast General Mustang Discussion 1 11-21-2011 07:18 AM
A humming noise Blackedout Pre-2005 V6 Mustang 0 11-04-2011 11:45 AM
humming noise during idle robertoortiz85 1996-2004 Mustang GT 6 10-23-2011 02:12 AM
Humming noise in car fastfreddy 1996-2004 Mustang GT 11 08-13-2005 12:40 PM
01:37 PM
