18inch wheels - Mustang Evolution
Old 03-21-2016, 08:01 AM   #1
TruBluStang03's Avatar
18inch wheels
Is there any changes you need to make to the car in order to properly use 18inch wheels on the car. I also have the car dropped 1.5 is that a problem at all?
TruBluStang03 is offline   Reply With Quote
Old 03-21-2016, 09:11 AM   #2
Biggest change would be adjusting speedometer if your tire diameter changes. If you manage to stay the same or fairly close you'll be fine. It's easy enough to adjust if you already have a tuner.
I am running 275 NT555s as steer tires with a 2" drop and I have no rubbing issues. I don't even rub the sway bar at full lock. They do tend to run a tad narrower than other brands though.
I have 295/35 NT05's on the rear and 315/35 Sumi HTR's on the rear of my 03 and neither have rubbing or clearance issues. Both are lowered ~2" in the rear. You should be fine unless you go with a 335 rear tire or something.
Old 03-21-2016, 09:44 AM   #3
No. Just make sure you understand proper tire fitment/diameter and that sidewall numbers are percentages, not fixed sizes.
Old 03-21-2016, 09:46 AM   #4
Ok thank you, just debating whether to get 17x9 or 18x9 all around
Old 03-21-2016, 09:52 AM   #5
There is no performance benefit to 18s unless you need to get around bigger brakes which 99% of ppl will not.
17s are cheaper, tires are cheaper and they are lighter. 18s are pure looks.
That said, 18s do look better IMO. But if you lower the car enough 17s look great too.
Old 03-21-2016, 10:27 AM   #6
^Agreed.
For most people 18's are purely an appearance choice. If they had offered the wheels I recently got in 17's I would have chosen them over an 18" option.
You have to decide whether the extra inch is worth the extra cost, weight etc.
Old 03-21-2016, 11:05 AM   #7
I am only considering 18s because the Y2K Cobras are my favorite wheels and only available in 18s. That and I'm looking at a square setup and like the 9.5" wide all around.
All that said, easy and cheap with great street performance is a staggered set of 17s with Mickey Thompson rubber for $1150.
Old 03-21-2016, 11:27 AM   #8
Those Y2K wheels are nice. Don't see a lot of cars running them anymore, which is a good thing. Something different.
Old 03-21-2016, 02:51 PM   #9
Might just get a wheel and tire kit from AM
Old 03-21-2016, 05:34 PM   #10
Steve96's Avatar
I just got a staggered set of MMD 551Cs in 18". I wouldnt have got 18" if they werent on a ridiculous sale through AM, I would have went with 17s because of tire price and a lot more options. In my case Ill be under $1k for wheels/tires, mount, and install. It should be somewhere between $800-$900 when all said and done. Debating on tires now. I will probably be going 26.3" tall front tire, and a 26.7 tall rear tire, from what I can tell I shouldnt have any issues with rubbing. Will be lowering at least 1.5" around the same time as well. Too bad you didnt get in on the sale. Depending on what wheels you want you should check out OEWheels.com, they are a little cheaper and the same quality as AM. Then order your tires from Tirerack and you should save yourself some money.
1996 GT
Old 03-21-2016, 06:14 PM   #11
fomoco4life's Avatar
I couldn't afford to change 18" tires every two years just for looks, that's why I'll never do it, there's a major price difference. Something to consider if it's ur DD. Staggered 17's with a drop look sweet to me, but its really all preference and cost.
I have heard if you do 10" 18's you may have to roll your fenders depending on your drop and the tire
Old 03-21-2016, 06:16 PM   #12
I have heard if you do 10' 18's you may have to roll your fenders depending on your drop and the tire
That's 10" 18's out back, not 10'
Old 03-21-2016, 06:27 PM   #13
Depends on the brand of tire. You get some Sumis and they are $110-$125 a tire depending. The HTRZ III tires I hear are actually pretty good. A big wide Mickey is going to be $225 or so. For straight line... yeah 17s are kind of where its at.
You do not need to roll your fenders for a 10.5" rear rim unless you try to stuff a fat tire back there like a 325 M&H Drag Radial or something.
Old 03-21-2016, 11:26 PM   #14
Steve96's Avatar
I agree with Scotty from what Ive seen on friends and familys Mustangs with 18" wheels you shouldn't have any rubbing issues. Now if your lowered like 2"+ and run a slightly taller tire you may have some issues. Only issues I have seen with these cars is on the front during full lock you may rub if you have a 275 40 18 on the front cause of it being 1/2" to 3/4" taller than a 35. Milehigh JDF has 275 40 18s on the front I believe which are 26.7" tall and he had a slight rub with H&R SS springs but it was on full lock, and he had no issues with the fender well. But, he did say he needed a slight camber adj to tuck it under the fender some, but not enough to make the tires uneven etc as far as I know. The tires I want are 26.3" front and 26.7" rear and should fit well even when I lower it. Also Ive heard of people having to reverse their quad shock to fit a 315 wide tire at times, but thats not a big deal. If you have worn out dampners and are running a fairly wide tire I guess I could see an issue there with rubbing the fender well in the rear as well. But most should be fine going 18" and dont have anything to worry about usually.
1996 GT
Old 03-22-2016, 12:54 AM   #15
Mile high JDF's Avatar
I never needed to roll my fenders on my old mustang with either wheel setup that it had. With my current ride I don't need to roll anything either but as Steve said, I do rub the fender liners a bit on full lock. However my tires are close to a full inch taller than the factory size so there is that to take into account. I'm all for gong with 18s, they look way better in my opinion and I haven't had issues finding tires for a decent price. With a 1.5" drop you won't have to worry about any sort of wheel clearance.
ID:	198599   Click image for larger version
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-22-2016, 06:07 AM   #16
I had to flip quad shocks on a 10.5" rim but not a 10" rim. Or just remove them if you run aftermarket LCAs.
After seeing this I might go for a 275/40/18 all around. What brand is that? I had BFGs but those ran really big for a 275 and they might cause more issues up front. I did see a 265/40/18 HRTZ3 for $125 a corner which would work well on a 9 or 9.5" wide rim which is what I am going for anyway and is 26.3" which I know fits.
Old 03-22-2016, 07:07 AM   #17
These are tires Nitto 555s. They bulge ever so slightly on the front and as mentioned earlier they do scrub the fender liner at full lock, but that problem is easily remedied.
Old 03-22-2016, 10:15 AM   #18
Ah, 555s run narrow. That is going to be more like a 255 or 265 in "real" size. No way a 275 BFG would fit under there. Not a Comp 2 anyway. A Comp 2 will bulge slightly on a 10" rim lol. Gives a good baseline for sizing tho because I can pull actual section and tread width specs off the interwebs and bump that against other brands on tirerack.
Just for comparison, a 285/35/18 Nitto 555 bulges like a stock tire on a 9" rim and does fit up front on a lowered New Edge. But that is a 26" tall tire, not 26.7" although it is wider.
Old 03-22-2016, 11:06 AM   #19
Diehard's Avatar
When talking wheel/tire fitment, always make sure the wheel offset is considered.
If comparing with someone else's good or bad fitment experience, make sure offset is not left out of the picture. nough said!
Old 03-22-2016, 09:09 PM   #20
Generally tho, ppl are going to be getting "Mustang" wheels from AM/LRS/OE Replicas etc... Pretty much just plug and play.
18inch rims gqsmash Mustang Wheels & Tires 0 04-25-2012 07:27 PM
roh zr6 wheels or roh syper wheels wanted 2300turboford Mustang Wheels & Tires 0 12-23-2011 05:40 AM
New wheels for my 2011 5.0.Vossen Wheels CV3's 5.0newage 2011-2014 Mustang GT 21 11-17-2011 09:47 PM
Looking to trade my wheelzz saleen wheels!! Wtt 4 blk wheels saleenman Mustang Wheels & Tires 12 08-27-2009 11:41 AM
What brake upgrades work with stock 18inch Bullet wheels? 07GT 2005-2010 Mustang GT 3 05-12-2007 01:54 PM
06:54 AM
