Front axle - Mustang Evolution
Old 03-22-2016, 12:52 AM   #1
xrsfx's Avatar
Front axle
I think my front wheel is a little to close to the back of the fender. I rub everytime I turn the wheel. I'm thinking that axle is messed up. My question is if this is true what wheel size would fit the best
xrsfx is offline   Reply With Quote
Old 03-22-2016, 02:30 AM   #2
bucko's Avatar
Why do you think the axle is messed up? Sounds like your current tire/rim setup is too large. What size are the rims and tires you are running with?
Old 03-22-2016, 10:34 AM   #3
keeney35's Avatar
Or you've bent a suspension component and the the alignment out of whack
04 GT: CAI, 3.73's, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, Ported/Polished heads, Manley dished/notched pistons, MMR forged H beam rods, FRPP forged crank, BBK 75mm throttle body, MSD coils, 60lb EV6 injectors, Eddy Vic Jr intake, UPR coilovers in front, Steeda lowering springs in rear, Front strut bar, MM caster camber plates, UPR k member, 355lph walbro pump, MMR 8qt oil pan, ARP hardware, EGR delete, A/C delete, ABS delete, EVAP delete.
Honda weight with an American V8
keeney35 is offline   Reply With Quote
Old 03-22-2016, 10:53 AM   #4
Strange Mud's Avatar
A new wheel won't help a bad axle.
2012 V6 with suspension, shifting, stopping and sound mods.
Old 03-22-2016, 05:20 PM   #5
xrsfx's Avatar
Name:	ImageUploadedByMustang Evolution1458685226.155697.jpg
Old 03-22-2016, 05:21 PM   #6
xrsfx's Avatar
That's how it is
Old 03-23-2016, 01:23 AM   #7
Steve96's Avatar
Yeah that does look to close to me. I would think someting is bent in there
1996 GT
Old 03-23-2016, 01:30 AM   #8
xrsfx's Avatar
Where do I go to check something like that ? A mechanic or a body shop or what
Old 05-08-2016, 01:00 AM   #9
Revvv's Avatar
A frame shop and a suspension specialist is needed according to the pic,
Old 05-08-2016, 11:55 AM   #10
keeney35's Avatar
Just jack the car up and look underneath it, take some pics and post me I'm sure we can spot something bent, it should be obvious with it sitting like that
Old 05-08-2016, 12:25 PM   #11
Revvv's Avatar
It would also be a good idea to remove the wheel and the wheel well liner. Then we can easily see the damage. I am certain there is something wrong with the sub frame.
Old 05-08-2016, 02:12 PM   #12
phillip433's Avatar
Have you taken the k member off or any work done to the front end recently?
phillip433 is offline   Reply With Quote
2013 V6 Rear Axle FULL ASSY Swap to 2013 GT Rear Axle FULL ASSY sprdave 2011-2014 V6 Mustang 2 06-16-2015 01:14 PM
For Trade: Roush Axle-Backs for 13+ GT500 Axle-Backs SecretAgent Mustang Parts for Sale and Wanted 3 06-07-2014 07:41 PM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 06:12 PM
does the hub on the rear axle have a gasket between it and the axle? stangcobra Pre-2005 V6 Mustang 15 11-06-2012 05:16 PM
Stage 3 roush front OR keep 01 cobra front? SpectorV Mustang Audio & Video 16 11-27-2004 01:17 AM
11:44 AM
