New stereo - Mustang Evolution
Old 03-22-2016, 04:10 AM   #1
dwbrand's Avatar
New stereo
Anybody running a double din Pioneer? I'm looking at AVH-X3800BHS.
This unit has a parking brake setup, which I've never dealt with before. There's a wire around on Amazon I was considering too- thoughts? Apparently grounding this wire doesn't work anymore...
This will be for my 03 Mustang, which is why I posted here and not the audio/video forum (I never look there anyway and didn't think it gets as much traffic)
Edited: here's the links to what I'm looking at
http://www.amazon.com/Pioneer-AVH-X3...ds=avhx3800bhs
http://www.amazon.com/gp/product/B00...A1AUFI5NHGNZ61
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 03-22-2016, 05:08 AM   #2
jeno's Avatar
Look at crutchfield.com probably get a better deal
Sent from my 2003 rocketstang using Mustang Evolution
jeno is offline   Reply With Quote
Old 03-22-2016, 05:12 AM   #3
dwbrand's Avatar
http://www.crutchfield.com/p_130X380....html?tp=20217
Actually, it's much higher at Crutchfield
1968 Mercury Cougar
Old 03-22-2016, 05:15 AM   #4
jeno's Avatar
Was just a thought but at least at cruthfield you get the wire harness and bezel free
Old 03-22-2016, 05:22 AM   #5
dwbrand's Avatar
Thanks!
I've got a Pioneer in my car now, so depending how good of job it was installed before (previous owner had it "professionally" installed) I might be alright on the harness. Gosh I hope so... I hate it when people cut factory plugs and I honestly have no idea if they goofed up the Mach 460 in any way.
1968 Mercury Cougar
Old 03-22-2016, 08:15 AM   #6
Westcoast408's Avatar
You can t beat amazon prices sometimes
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 03-22-2016, 09:33 AM   #7
keeney35's Avatar
I have a double din pioneer on my 04 but idk what the parking break deal is.
04 GT: CAI, 3.73's, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, Ported/Polished heads, Manley dished/notched pistons, MMR forged H beam rods, FRPP forged crank, BBK 75mm throttle body, MSD coils, 60lb EV6 injectors, Eddy Vic Jr intake, UPR coilovers in front, Steeda lowering springs in rear, Front strut bar, MM caster camber plates, UPR k member, 355lph walbro pump, MMR 8qt oil pan, ARP hardware, EGR delete, A/C delete, ABS delete, EVAP delete.
Honda weight with an American V8
keeney35 is offline   Reply With Quote
Old 03-22-2016, 09:37 AM   #8
dwbrand's Avatar
Something about DVD playback and maybe some other features don't work unless the brake is set.
I don't care about DVDs playing while I drive (or at all) but don't want it to affect what I want it to do.
1968 Mercury Cougar
Old 03-22-2016, 06:21 PM   #9
fenixignition's Avatar
its a ground wire. its supposed to ground when you have your parking brake pulled up. you can literally ground it to the chassis of the stereo or anywhere that is metal and grounded. at that point, it is up to you to be responsible not to be distracted by any videos playing while you drive. without it being grounded to anything, then when you play a video it will show a blank screen.
EDIT: should have read your whole post. it works on a kenwood. but do some more research. i always heard that the parts you can buy to bypass it are a waste. but without it being attached where its supposed to be should only disable videos.
2002 GT 5sp. 16x,xxx miles
Old 03-22-2016, 06:50 PM   #10
dwbrand's Avatar
I don't plan on ever putting a DVD in there... It's more like I wanted a CD player that was double din with a big screen haha
1968 Mercury Cougar
Old 03-22-2016, 07:34 PM   #11
dwbrand's Avatar
Anybody with satellite radio? Trying to decide where I'll mount the antenna... I have the SiriusXM kit that I might run tomorrow while I'm waiting for stuff to come in (I ordered the Pioneer unit)
1968 Mercury Cougar
Old 03-23-2016, 03:44 AM   #12
I put mine right next to the radio antenna. Routes easily behind carpet and to the door, up the panel and right on the metal of the fender. I wanted to put it on the trunk but unfortunately fiberglass isn't magnetic.
Sent from my SM-G920V using Mustang Evolution mobile app
Old 03-23-2016, 04:11 AM   #13
dwbrand's Avatar
1968 Mercury Cougar
Old 03-23-2016, 07:29 AM   #14
Screw satellite radio. Its losing money and might not be around in 5-10 years anyway. Just get a stereo with a mirror setup for iphone or android (whatever you use) and mirror your phone to the double DIN screen. Then use your streaming service of choice or load a bunch of music to your phone and stream directly over Bluetooth. Or get something with a front USB and get a low profile 64GB USB drive and there is your entire music library.
That's another dead tech TBTH... optical media. No need for CD/DVD in anything anymore. At all. My new computer I just built doesn't even have one and I never used the one in my last setup after 2010.
Old 03-23-2016, 08:11 AM   #15
dwbrand's Avatar
I have a pretty large CD collection... Mostly in storage but if I can buy the CD for the same price as digital and upload it to my iTunes, I'll typically do that.
Since we have Sirius for my wife's new rig, I might as well be taking advantage of it. I'm paying for it, right?
I don't care to stream audio on my phone. Verizon has a way of screwing data usage over and I don't give them the chance- I go with wifi almost all the time.
1968 Mercury Cougar
Old 03-23-2016, 09:31 AM   #16
I switched to T-Mo as soon as VZW jacked the grandfathered unlimited data from $30 to $50/mo. They paid for all my switching costs. Back on unlimited with a better package for less $$$.
And you don't HAVE to pay for Sirius, I'm sure you can cancel. And CDs can all be ripped to MP3s easily enough.
But whatevs. I mean you do you obviously. Lots of automakers are actually stopping with CD players in stereos. I know the F150 is doing that.
Old 03-23-2016, 09:53 AM   #17
dwbrand's Avatar
Well we got a few months free and then a few more months at a bargain price... So in October we'll have to decide what we are doing.
I looked at a couple double din units that didn't have CD players and considered trying to find a CD changer to mount in the trunk but that got to be a more expensive project than I wanted.
1968 Mercury Cougar
Old 03-23-2016, 09:56 AM   #18
Changers... why... 1992 called, they want their tech back... You have iTunes, just burn everything to iTunes and then if you have a home server setup you can stream directly to your phone and into the stereo. Your new car does not have iCar or whatever its called?
Old 03-23-2016, 09:59 AM   #19
dwbrand's Avatar
Yes 1992 called haha
1968 Mercury Cougar
Old 03-23-2016, 10:05 AM   #20
And for streaming/music/whatever... highly recommend switching to an unlimited data plan. Sprint is horrible but T-Mo is really good and you can get it on ATT too if you have DirecTV. Before the cost of the phones I pay under $100 for 2 lines, unlimited everything, 7gb of tethering per phone, free Rhapsody premium service and they really expanded their network and speed over the last year.
Anyway...
Old 03-23-2016, 10:17 AM   #21
dwbrand's Avatar
We are stuck in a contract for a little while longer... And then I want to make some changes.
T-Mobile sucks around here. I had Sprint for seven years and liked them but then I moved up Western Kansas for work and had no service there.
1968 Mercury Cougar
Old 03-23-2016, 10:21 AM   #22
Even after the new tower rollout? And no stuck on contract now, any other carrier will buy you out up to $650 per line.
Old 03-23-2016, 10:26 AM   #23
dwbrand's Avatar
Yeah... I'd be fine switching to AT&T but my wife is convinced the service at her parents will suck. AT&T is the only service that works where she teaches and I'd like to switch just for that reason alone.
1968 Mercury Cougar
Old 03-23-2016, 12:25 PM   #24
Do you both have iphones? Do her parents have wifi? iphones will call over wifi just like over the towers. So will all T-Mo phones because they load the program onto Androids. I get LTE outside my house but for some reason it is a black hole inside so we just jump on the wifi and good to go.
Old 03-23-2016, 01:34 PM   #25
dwbrand's Avatar
We both have iPhones but her parents do not have wifi. They don't have a computer, printer, Internet, etc. 😳
1968 Mercury Cougar
Old 03-23-2016, 01:49 PM   #26
Well you could always pick up a $10 used att flip phone and then buy a prepaid ATT sim and throw it in there and see what happens at her parents house. Otherwise just stick with the overpriced suck that is VZW. And not able to stream music to your car.
There is also Slacker Radio that lets you cache your stations with a premium subscription so everything refreshes on your wifi overnight and then you can listen to your music as much as you want with no data usage or even when you have no signal.
Old 03-24-2016, 06:44 AM   #27
dwbrand's Avatar
Slacker Radio? Never heard of it, I'll have to check it out.
1968 Mercury Cougar
Old 03-24-2016, 06:58 AM   #28
Its a competitor to Pandora and all them. Its the most like satellite radio I have found. Has set stations for anything you can think of and if you are a premium member you can set up "station caching". It actually does not take up a ton of storage space and if you have like 10 stations cached you can listen to them even with zero service. Also means no data usage if you are not on an unlimited plan. I used to have mine set to auto update every night at like 2 AM even tho I had unlimited data. Convenient if out of a coverage range or in a building etc...
Old 03-25-2016, 04:19 AM   #29
dwbrand's Avatar
Name:	ImageUploadedByMustang Evolution1458901090.191920.jpg
Installed!
I have more work to do, need to hide some wires (USB, sat antenna, phone mic) but it was cold and dark when I got the radio in last night.
1968 Mercury Cougar
Old 03-25-2016, 04:30 AM   #30
I routed the usb wire up into the glove box. Auxiliary cord is still just hanging from the side. And satellite wire is tucked behind the carpet on the passenger side by the firewall.
Old 03-25-2016, 06:39 AM   #31
dwbrand's Avatar
I was thinking about taping the antenna kinda behind/above the rear view mirror on the windshield and hiding wire along the headliner.
I hadn't thought about the glove box for the USB... I bought a panel dash mount USB that I thought I'd drill a hole and put in by my cigarette lighter. Come to think of it, I do like that glove box idea. I'll ponder it 👍🏻
I didn't run a 1/8 stereo auxiliary, didn't think I'd ever need it. I could've gotten a USB with the stereo plug in also.
1968 Mercury Cougar
Old 03-25-2016, 09:05 AM   #32
GTGirl's Avatar
Looks nice! - I have a Pioneer 8100NEX - the installer hid the mic where they synch mic was and put the gps under the dash where the gps that came with my Mustang was and he ran USB's to the console so no hanging wires. But I have the navigation etc - but I LOVE the stereo the music sounds great - the loudest I can put it is 1/2 or I would blow out my speakers and myself out of the car. LOL. Enjoy!
2 2014 Mustang GT/CS Premium California Special Race Red 1 Convertible Black Top
1 Coupe with Panoramic Roof and Navigation System
Vert Pioneer's 8100NEX and back-up camera
Both Vert and Coupe 6 speed Corsa Sport Axleback GT500 Quad Exhaust, comfort package
GTGirl is offline   Reply With Quote
Old 03-25-2016, 09:16 AM   #33
dwbrand's Avatar
Thanks! Your setup looks good! I think I'll do a pretty good job hiding wires, I used to do installs at a place I worked in college and some on the side. And I'm picky.
1968 Mercury Cougar
HELP!!!! new stereo installation for 2000 mustang aminohelix Mustang Audio & Video 50 01-26-2012 11:34 AM
New Stereo 06REDF1RE 2005-2010 V6 Mustang 36 10-04-2011 01:59 PM
New stereo Sonofjarell Mustang Audio & Video 20 03-08-2011 07:11 PM
New Stereo installed MC770 Mustang Audio & Video 13 02-06-2011 06:22 PM
So I got a new Stereo again.... Brent The Bar 8 09-20-2006 03:38 PM
02:44 PM
