New clutch - Mustang Evolution
Old 03-22-2016, 04:02 PM   #1
keeney35's Avatar
New clutch
Ordering a new clutch, is the clutch adjuster really necessary? My old clutch was aftermarket and I didn't have one so do I need one wth the new clutch?
04 GT: CAI, 3.73's, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, Ported/Polished heads, Manley dished/notched pistons, MMR forged H beam rods, FRPP forged crank, BBK 75mm throttle body, MSD coils, 60lb EV6 injectors, Eddy Vic Jr intake, UPR coilovers in front, Steeda lowering springs in rear, Front strut bar, MM caster camber plates, UPR k member, 355lph walbro pump, MMR 8qt oil pan, ARP hardware, EGR delete, A/C delete, ABS delete, EVAP delete.
Honda weight with an American V8
keeney35 is offline   Reply With Quote
Old 03-22-2016, 07:55 PM   #2
keeney35's Avatar
Any insight? I wanna know so I can order it if necessary
Old 03-22-2016, 09:39 PM   #3
If you have the stock quadrant no. If you have an aftermarket quadrant yes. You should also ensure you have an OEM/MM cable and not some aftermarket one.
Old 03-22-2016, 09:54 PM   #4
keeney35's Avatar
Stock quadrant and stock cable as far as I know.
So if they are both in fact stock an adjust quadrant isn't necessary?
Old 03-23-2016, 05:55 AM   #5
The stock quadrant is self adjusting. I would verify they are OEM tho. The stock quadrant is plastic and has a pawl that takes out the slack in the cable.
Old 03-24-2016, 04:57 PM   #6
infamous281's Avatar
Just do the clutch Change , and leave the rest alone
If you need or want a new cable , just get one @ ford.
Don't buy those junk aftermarket ones.
Sent from my SM-N910T using Mustang Evolution mobile app
Clutch adjuster, clutch, or tranny Elcobrachingom SVT Mustang 3 09-05-2012 06:32 PM
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 09:37 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 04:44 PM
Dual Clutch Vs Single Clutch 504 Stang Rida 1996-2004 Mustang GT 7 11-29-2011 07:22 PM
10:20 PM
