03 GT Getting Rearend Rebuild - Good Gears???? - Mustang Evolution
Old 03-23-2016, 08:22 AM   #1
Hello All,
I am having my rear end rebuilt on my 03 GT 5sp with 116,000 miles and am going from the stock 3.27 gear to a 3.73 gear with the full install kit and clutch packs. My question is, what are some good brands? The shop that is doing the work is building an estimate now and I want to know the brand prior to them ordering so I can confirm they won't be whining or low quality. What are some companies that make quality, quite 3.73 gears? I don't have the cash to afford another rebuild in the near future and don't have the skills to do it myself so I want to make sure it's done with quality parts. Also, what kind of warranty should I push for? This shop doesn't seem to thrilled on a giving a warranty on a rear end for a sports car.
Thank you everyone for your help!
AnthonyG1562 is offline   Reply With Quote
Old 03-23-2016, 09:40 AM   #2
Get the Ford Racing kit from American Muscle. Also get 4.10s. The 4.6L needs more help down low and the 02-04 GTs have a deeper overdrive gear so its not too much for the highway.
Old 03-23-2016, 10:59 AM   #3
Thank you for the input. I did strongly consider the 4.10 and was originally going to go with them but the more I researched the more I realized 3.73 might be best for what I plan on doing with the car. For me, this car is mint, I mean underneath and under hood, zero rust, dings, scratch, or even cracks in the leather seats. I am going to 75% cruise, 25% get on it. My 93 GT had a 4.10 and for cruising, I had to shift at 3000 to keep up with traffic and its a lot of shifting for around town. Since this isn't just a car to race and will be doing more cruising than racing, do you still think the 4.10 is a good choice?
Old 03-23-2016, 12:29 PM   #4
Your 93 had a .68 overdrive, your current car has a .62. It would be similar to having 3.73s in your 93.
The difference between 4.10s and 3.73s is not as drastic as many would lead you to believe.
But if you are going to be doing mostly highway I'd get 3.55s or just leave it at 3.27. If you do plan on getting on it at all tho you will want 4.10s. Hell I was going to get 4.30s for my last NA 4.6L...
You can also jump up the tire size out back too if you feel your RPM are still too high. I ran a full inch taller than stock spec out back on my last car. Plenty of room.
Old 03-23-2016, 01:42 PM   #5
Westcoast408's Avatar
I just got 3.73 gears installed yesterday but i haven t driven it enough to see all the excitment lol
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 03-23-2016, 03:59 PM   #6
Definitely stay FRPP with everything you get. Not sure if the kits come with bearings but at 116k miles I would strongly recommend replacing them too.
Also, any shop that isn't willing to warranty their work would have me questioning whether I should take my car there. I see you're in Belvidere, that's not that far from Milwaukee. I'd highly recommend Marv at C&M Automotive Performance. He did my 4.10's and 31 spline upgrade. He uses all FRPP products and guarantees his work.
I have not been nice to my rear since the upgrade, and I've had zero issues, whining, grinding or anything.
C & M Automotive Performance
Old 03-24-2016, 12:07 AM   #7
phatspeed7x's Avatar
I got 4.10 in my 2004 GT. Ford racing gear set and the install kit from American muscle. Performance is pretty insane compared to the factory 3.27 gears. At 70mph the motor is turning about 2350rpm and with my race tune I'm still getting about 21mpg.
Sent from my LG-H900 using Tapatalk
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 03-24-2016, 07:03 AM   #8
sonicpony03 - Thanks for your feedback! I am doing the full install kit with clutch packs because I don't want to deal with this rear end in the near future. I took the car in because it was making a whom whom whom. The tech should know since that is why I took the car in I don't want any noisy gears. Plus, I called the shop before they ordered the parts and wanted to make sure they weren't going to throw the cheapest parts in there and that I would pay extra for quality parts so hopefully their good an quite.
Old 03-24-2016, 07:06 AM   #9
sonicpony03 - Also, the shop the car is at, the tech I talked to who does their rear end rebuilds has an 01 with 800HP and said he has changed the rear end multiple times. The owner confirmed the story when I dropped off the car and also added the techs brother has a 11 second Z28. The fact that the tech who is doing the work has done this job on the same car makes me think it will get done correctly and also, he should know good gears.....I hope.
Old 03-24-2016, 07:08 AM   #10
Well hopefully they do it right then... Still say you should be doing 4.10s but its obviously your car.
Old 03-24-2016, 08:37 AM   #11
Well it sounds like you have confidence in them. I am the type that puts confidence in a written and signed document over someone's word but to each his own. Also I've found that just because someone has a fast car doesn't always mean they know what they are doing. Fingers crossed they are legit and aren't blowing smoke.
I second the 4.10's...don't fear the gear! But again it's your car and if you feel you'll be happier with the 3.73's then go for it.
Old 03-24-2016, 02:17 PM   #12
Final Results!!!
So, shop agreed to a 1 year warranty and put in Motive gears. Should pick it up by this weekend!!! They did say to take it easy on it for the first 500 miles so that will be tough. Thanks everyone for your opinions!!!
Old 03-24-2016, 04:55 PM   #13
infamous281's Avatar
410 or 430 , 373 are a waste
Sent from my SM-N910T using Mustang Evolution mobile app
Old 03-24-2016, 04:56 PM   #14
You don't necessarily need to drive 500 miles before stomping on the throttle .. if gears are properly installed .. you should be able to stomp on the throttle when you get back on the road.
Old 03-25-2016, 02:39 PM   #15
So..Got Car back....
Shop called and said car was finished with a but...the clutch packs they received were upgraded clutch packs with an extra clutch plate or shim, not exactly sure what made it different than normal, but tech said the rear end was very tight and when you turn the when as much as you can at and turn at a slow speed the wheel hops. He said the it may loosen up or I can come back and have it adjusted. Does this sound normal???
Old 03-25-2016, 02:43 PM   #16
Adding an extra clutch is actually an upgrade you can do to a stock diff. Normal. Have them set it up how you like it.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 03-25-2016, 02:45 PM   #17
What are the advantages of having it "tight"??
8.8 rearend swap with 4:10 gears Sluder4 Pre-2005 V6 Mustang 21 09-15-2013 07:36 PM
rebuild of a recent rebuild Black99Snake SVT Mustang 12 08-20-2011 05:24 PM
Looking for a good book that will help me rebuild my 1967 mustang? nell Classic Mustangs 3 08-19-2009 02:17 PM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
3:73 Gears for 7.5" RearEnd drummerstang98 Mustang Parts for Sale and Wanted 3 08-09-2004 11:03 PM
» Members Mustangs
Nightmare
1998
Tonka
Borii
Add your Mustang
10:54 PM
