New wheels !! What about tires? - Mustang Evolution
Old 03-23-2016, 05:27 PM   #1
smsstang's Avatar
So I just got new wheels and they are 18x8 in front and 18x10 in rear .
I can't figure out what sizes to run . I was thinking 265 in front and 285 in rear . I want to Mabey go bigger in rear but don't know about rubbing issues . Anyone have suggestions ?
smsstang is offline   Reply With Quote
Old 03-23-2016, 05:35 PM   #2
Mile high JDF's Avatar
On an 18X8 I wouldn't go any wider than a 255. On the rear you can fit up to a 305 on an 18X10 pretty easily without rubbing.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-23-2016, 06:10 PM   #3
smsstang's Avatar
That's what I was thinking on the front but I looked at American muscle and that's what they recommend on the tire size ? I have a 285 on the rear now on 17 fr500 and I like it but I don't know if bigger will be better ?
Old 03-24-2016, 06:47 AM   #4
Get on tirerack.com and find BFG Comp 2 tires.
275/40/18 out back, 235/45/18 up front. Back will have a slight bulge, front will be flush. These BFG tires run very wide for their size. Grip is fantastic, zero road noise all around spectacular tire.
Exact combo I had on my old blue car that was lowered about 1.5" all around.
You will need to recalibrate your speedo since you are going to be running a taller rear tire at 26.7" which will give you more sidewall for better grip and fill up your wheel well a little better. Up front will be 26.3" tall and will not rub even lowered.
http://www.tirerack.com/tires/tires....e+Sport+COMP-2
Old 03-24-2016, 09:34 AM   #5
AM tire recommendations are a bit wonky. They put a 275 on a 9" and then 285 on a 10"
10" id go 295 or 305
8" id go 245 or 255
That's for most brands, BFG like Scotty used do run much wider than normal.
Old 03-24-2016, 10:14 AM   #6
PARTSFROMERIK's Avatar
I'm running 315 on a 10"
Sent from my SM-N920V using Mustang Evolution mobile app
PARTSFROMERIK is offline   Reply With Quote
Old 03-24-2016, 11:52 AM   #7
smsstang's Avatar
If I decide to go nitto tires what should I run cause I have a 285 on the rear right now on 17-101/2 ? The wheels are MMD 551c? But yes I will get in tire rack do they have like a dimension calculator on there that helps ?
Old 03-24-2016, 11:54 AM   #8
smsstang's Avatar
Are the BFG more than nitto in price ?
Old 03-24-2016, 11:55 AM   #9
What's your location
Old 03-24-2016, 01:02 PM   #10
I sent you a link, go look up the prices.
IIRC the 275s are $200 shipped each and the 235s will be in the $150-$160 range each shipped. So yes likely cheaper and you get more sidewall and a better tire than the 555s if the 555s are what you are looking at.
Old 03-24-2016, 01:06 PM   #11
smsstang's Avatar
Location is Texas around Houston area
---------- Post added at 01:06 PM ---------- Previous post was at 01:05 PM ----------
Texas , Houston area
Old 03-24-2016, 01:08 PM   #12
smsstang's Avatar
Well where I work I can get prices at cost from my company I just really want the sizing to good and look good you know ? And yes nitto is what I'm looking at but I never tried the BFG before
Old 03-24-2016, 01:17 PM   #13
If you look at the size tire you want on tirerack an click on "specs" it'll show you tread width and section width. Remember that your rim width is measured inner rim lip to lip so you need to tack on about 1" total section width on top of the rim width. This is why the 235/45/18s fit great on a 8" rim because they have a 9.1" section width. Or something right around there.
Tirerack does not sell Nittos so I dunno. Nittos just usually run narrow tho. I think there are Nitto specs on the actual Nitto website. For a Nitto on a 10" wide rim I would go 295/35/18 if available. Or a 305 if you can get it. But the 275 BFG will be cheaper.
Old 03-24-2016, 01:19 PM   #14
smsstang's Avatar
The rear doesn't scare me it's just the front getting the width and height down cause I don't want no rubbing lol but thanks Scotty
Old 03-24-2016, 01:23 PM   #15
The 235/45/18 tire on a 8" rim will not rub at full lock even on a lowered car. I mean if slammed it might but on that blue car I never had any issues at all.
If you wanted to stick with an OEM tire diameter vs a taller tire like that then get 245/40/18 and 275/35/18 and that is 25.7" diameter on front and back, both will fit fine.
Old 03-24-2016, 01:25 PM   #16
smsstang's Avatar
I'm looking at them now and are you talking about the Gforce comp 2 or sport comp 2?
Old 03-24-2016, 01:28 PM   #17
Literally the exact ones I linked you to in the blue link above the pics I posted.
Old 03-24-2016, 01:31 PM   #18
smsstang's Avatar
Okay sweet I can get those for 175 for the rear each ! If that setup will look good and it will sit flush with fenders then I'm probly gonna try out these BFG tires man
Old 03-24-2016, 01:35 PM   #19
Well an 8" rim is not going to sit flush with the front fender lip on a New Edge. Wider fenders on the NE=9" rim up front for that but the 8" will still look good and honestly on a staggered setup there is not any benefit going to 9" over 8" except for looks. Actually putting a narrower tire up front is probably better for a straight line car anyway.
Out back, the 275s will bulge out slightly, it really is a perfect fit on a 10" wide rim.
Again, if you want a taller tire that'll ride a little better and fill up the wheel well more than 235/45/18 front and 275/40/18 back. If you want the OE diameter of 25.7" then get 245/40/18 up front and 275/35/18 out back.
Old 03-24-2016, 01:37 PM   #20
And the BFG tires kick ***. VERY high quality tire, great grip, ZERO road noise from the tires and they look great.
Old 03-24-2016, 03:46 PM   #21
smsstang's Avatar
Probly gonna go with what you suggested earlier with the 235/45/18 front and 275/40/18 rear
Old 03-24-2016, 04:09 PM   #22
Im running 245/45/18 on my front 18x9s, and 275/35/18 on the back 18x10s. Front are a bit stretched but the back look perfect
wawanesa5speed is offline   Reply With Quote
Old 04-11-2016, 09:37 PM   #23
Steve96's Avatar
What brand tires did you go with?
1996 GT
Old 04-11-2016, 09:39 PM   #24
smsstang's Avatar
Haven't bought any yet the wheels are still in the shop lol I had to buy new intake and some other goodies. But I'm gonna go with what Scotty suggested above .
Old 04-11-2016, 09:43 PM   #25
Steve96's Avatar
Thats what Im thinking too. I planned on having the tires already mounted a long time ago but just havent bought them yet. Keep waiting for a sale lol. I will do some kind of BFGs due to the fact that their performance oriented tires all run wide. Check out the 275 40 18 BFG G Force KDW, on a site called Superbuytires.com. They are like $115 per before shipping. Shipping from them from CA to me in MI is around $50 for the 2. Then I was going to order a Sumi for the front in a 265/40 18 but I do have 9" wide wheels. I may choose a diff size for the fronts though.
1996 GT
Old 04-11-2016, 09:46 PM   #26
smsstang's Avatar
Yeah man that's a pretty good deal but I get my tires at cost from my work and free shipping so I got a pretty good gig going lol
Old 04-11-2016, 09:48 PM   #27
Steve96's Avatar
Sounds like it....I need a gig
1996 GT
Old 04-11-2016, 09:52 PM   #28
smsstang's Avatar
It's not like incredible but every dollar counts lol ... And yeah I can't wait to get the new wheels on the old ones probly gonna get sand blasted and coated
Old 04-12-2016, 12:57 AM   #29
Steve96's Avatar
That is true, thats why Im shopping so hard for stuff to save some money so I can do more things I want to do. Getting the wheels as cheap as I did helped a ton. Should be under $900 total for wheels, tires, installed approx when all is said and done.
1996 GT
Old 04-12-2016, 12:59 AM   #30
Steve96's Avatar
Wawa what tires did you get? Brand and size?
1996 GT
Will 205/75-14 tires fit 14x7 wheels? will 225/45-17 tires fit 16x8 wheels? baudier Classic Mustangs 4 03-29-2016 08:25 PM
Wanted: GT500 wheels and tires or 19inch wheels and tires 2014_MCA_Vert Mustang Parts for Sale and Wanted 1 02-28-2015 07:25 PM
New wheels and tires off my new 2014 bodon Mustang Wheels & Tires 2 03-06-2014 07:32 AM
How much are my stock wheels and tires worth? Less than 1500mi on the tires... Bwillingham10 2011-2014 Mustang GT 24 05-30-2013 09:38 PM
01:33 AM
